how to print on a microscopic scale
Started Dec 11, 2015 | Discussions
EscapeTheClassroom New Member • Posts: 1
As a teacher occasionally I would love to lock up mystudents. And I will. We are developing Escape the Classroom. Biology students will be locked up and through a series of puzzles they.might find a way to escape. On of the clues is that they find a microscopic slide. Under the microscope they can read a code on the slide.
But how to make this microscopic slide? How to print something which can't be read by the naked eye? But is has to be transparent/see through. Who has an idea?
Martin.au
Martin.au Forum Pro • Posts: 14,339
Re: how to print on a microscopic scale
Cool idea.
I would ask your nearest university very nicely. Most decent size universities will have a microscopy centre, that will include capabilities such as laser ablation for mass spectrometry. Laser ablation plinks lots of little, targeted holes into a sample - eg: samples = shells, rocks, all sorts of things.
There will be a bit of effort involved, but I suspect that someone at such a place would be interested in helping out.
I'll think about it and see if I can think of anything easier/better.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Martin.au
A much simpler solution may be to use a really good printer (perhaps a photo printer, for the detail) to print a really tiny message on a transparent sheet (or perhaps something like tracing paper, that light can shine through - I'm assuming you don't have reflected light microscopes, but instead the more traditional transmitted light microscopes), Then glue it to the slide with a clear glue.
(unknown member) Regular Member • Posts: 484
Basically you want to make a microdot like in the old spy movies. It is possible with a good quality 35mm film camera. Google something like "How to make a spy microdot".
Here is one simple explanation: https://imgur.com/EgFVCp5
J
D Cox Forum Pro • Posts: 32,980
Use film.
Print your text on paper, normal size, in white on a black background, so that it comes out black on clear on the negative.
Photograph the printed text on the finest grain black-and-white film you can find. B&H list a good selection, including Rollei Ortho and Adox CMS 20.
Any film camera with a good sharp prime lens will do. If it won't focus close enough, print your original bigger.
Sigma fp
OpticsEngineer Veteran Member • Posts: 7,828
"How to print something which can't be read by the naked eye?"
Here is what I do.  I make test targets this way to test systems we build for machine vision.  Use Windows Paintbrush to make a file that has the text you want or any other pattern you may dream up.  Save the file as a bitmap or JPEG.  Send it to www.gammatech.com to have it printed as 35 mm slide film.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
Dr Wilcox New Member • Posts: 1
Have you tested this out? Do you have film recommendations that are clear/ transparent so that the image can be seen under a brightfield microscope?
petrochemist Veteran Member • Posts: 3,619
Photographic printing is used in the manufacture of computer chips with the right set-up it will certainly be able to give the resolution you'd need.
Any B&W film negative can be viewed via a brightfield microscope. The suggestion to use a slow film was to reduce grain size & so improve resolution. Colour negatives are not as good having a distinct orange cast in the background areas but would also be viewable on normal microscopes.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
