canon 50mm 1.8 stm chromatic aberration
Started Dec 10, 2015 | Questions
kuroda724 New Member • Posts: 1
I just got the lens and am confused at what I am seeing. Can someone tell me if this is normal? Shot with a canon 5ti
Original test image:
Zoomed in to 100%
should there be that much chromatic aberration? theres clearly a large green outline on the top and red on the bottom.
any and all help is appreciated. Thank you
Canon EF 50mm F1.8 STM
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: canon 50mm 1.8 stm chromatic aberration
Yes, this is normal. I've forgotten what this specific kind of CA is called, but it's normal at wide apertures to have one color on sharp edges beyond the plane of focus, and the other color in front of the plane of focus. It should be fairly easy to remove in a program like Lightroom.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
Abu Mahendra Veteran Member • Posts: 5,312
There's red, there's green, and there is purple (on the right, bottom).
>> I am already lovin' the Canon EF 35L II lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
brightcolours Forum Pro • Posts: 15,885
Longitudinal Chromatic Aberration (LoCA).
Indeed, it is normal to see magenta/red in front of the focus plane and green behind, with a lens like this. Some lenses show blue/yellow LoCA, but that is very rare.
Alastair
trulandphoto Senior Member • Posts: 1,019
Process RAW with DPP DLO and it should be pretty much dealt with.
 trulandphoto's gear list:trulandphoto's gear list
Canon EOS R Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F2 Macro IS STM Canon RF 50mm F1.8 STM +3 more
