Problem Using Manual Settings G11
Started Dec 9, 2015 | Questions
boatphotog New Member • Posts: 9
Hi,
I just bought a used Canon Powershot G11 from B&H and I am having trouble setting shutter/aperture manually. When I turn the control dial to change the settings it's as if the connection between the dial and the camera is slipping. If I'm at a shutter speed of 1/1000 for instance and try to adjust to 1/60" by turning the dial the numbers will start to decrease to 1/500",  1/250", 1/125" and then suddenly reverse and begin going back up to 1/1000". I'm not sure why this is happening. Am I doing something wrong or is the camera broken? I must say that for a supposedly simple camera the G11 has one of the most complicated and convoluted user interfaces I've ever encountered and I've been a photographer for many years.
Thanks!
 boatphotog's gear list:boatphotog's gear list
Canon PowerShot G15 Nikon D700 Nikon D7100 Nikon D500
Canon PowerShot G11
(unknown member) Veteran Member • Posts: 5,400
Re: Problem Using Manual Settings G11
1/60th might be beyond the metering range at that light level and ISO.  Are you in full manual mode when this happens?
damian5000 Senior Member • Posts: 1,948
This happened to my S120 (after several hard falls). *If* it's a physical issue with the dial it should be happening in other places too... eg, in menus, or anything else that can be controlled by the dial. Check that.
 damian5000's gear list:damian5000's gear list
Canon PowerShot G7 X
Seedeich Veteran Member • Posts: 3,034
That’s what happened with my G11 too. That issue with the dial was discussed a lot in the G11 group on Flickr.
You can change aperture and shutter speed by holding down the S button (left upper corner of LCD) and then use the right or left arrows of the dial.
