GX8 v G6 long exposures at night
Started Dec 9, 2015 | Photos
xelnt Forum Member • Posts: 56
5
I took my new GX8 for its maiden run shooting Aurora's a few nights ago, and before finishing up I took a shot with both my G6 and GX8 with the same settings (2500iso, F1.8, 13 seconds). Imported and pushed the exposure by +3 (nothing else done) with the results below. Definitely less noise and more detail in the shadows (bushes on the left and the rail on the right) and things like the water and sky look more natural. The G6 seems to struggle with noise on left and right edges compared to the gx8.
It is certainly an improvement, however I do wonder if the G7 at 16mp may have been a better choice for this type of shot.
GX8
G6
 xelnt's gear list:xelnt's gear list
Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Olympus M.Zuiko Digital 17mm F1.8 +3 more
Comment & critique:
Panasonic Lumix DMC-G6 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX8
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Re: GX8 v G6 long exposures at night
According to the Imaging Resource G7 review, the GX7 and the G7 have the same sensor.
Comparing GX8, GX7 (proxy for G7) and G6 on DXO Mark , at manufacturer ISO of 2500, the dynamic range of GX8 and GX7 appears to be about the same.
Those are nice shots, the only way I can think of improving is to drop the ISO of the GX8 to ISO 1600, underexpose (don't want to increase your exposure time, nicely chosen) , then push in PP.
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
OP xelnt Forum Member • Posts: 56
I think the G7 has an "improved" GX7 sensor that handles higher ISO's better then the GX7. There is certainly a marked difference between the G6 and the GX8 and I'll have a lot more room to push the shadows compared to what I could do previously and they should clean up nicely.
Hopefully I can get a chance to process the shots soon, including some panoramas with the Aurora dancing above a bush fire (should test the dynamic range!).
Eric Nepean
I'm curious, are you using RAW or OOC JPEGs? Which noise reduction SW do you use?
Eric
These are RAW with no noise reduction and the exposure boosted to see how the cameras handle the shadows. Editing wise I normally use Photoshop Elements (fine for what I do) however I need to update due to needing GX8 compatibility. So I'm trying out Lightroom at the moment, however it is a complete dog when you are opening folders and RAW files off a file server. Ridiculously slow. And I hate the Creative Cloud pay per month model.
Eric Nepean
I have noticed that for high ISO images, the noise reduction in OOC JPEGs  in some cameras is hard to beat in PP, might be worth a look.
For noise reduction and raw conversion, you might want to have a look at the DXO SW. Its on sale until Dec 25th, and is reputed to have really good noise reduction, and pretty good RAW conversion. YMMV. There is atrial.  And it can work as a plugin to Lightroom, I understand.
Eric
IanYorke Veteran Member • Posts: 5,266
For u4/3 in particular where the lenses use design techniques which incorporate software correction DXO is the way to go.   Its drawback compared to LR is that it does not do local corrections but you could use Elements for that.
Ian
Astrotripper Veteran Member • Posts: 8,676
Thanks for sharing this. I was wondering how big of an improvement it is, and as expected, it's significant.
No, it would not. It would be roughly the same as G6 (probably a bit better, but not by much).
Those 16MP sensors from Panasonic exhibit really high levels of dark current, and that's probably the reason they do not have a real Bulb mode. GX8 does not have this problem. It can make 30 minute exposures, and behaves very well at long exposures. The only other Panasonic cameras that can handle long exposures well are GH3 and GH4.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Robiro Veteran Member • Posts: 6,813
GX8 v E-M10 II
I would love to see how GX8 fares against E-M10 II, which probably has the lowest high ISO noise among m43 cameras.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
Impulses Forum Pro • Posts: 10,039
You know you can still buy a standalone version of Lr right? For me buying LR PLUS Photoshop Elements is still cheaper than CC, since Lr isn't updated every year (so like $75 every ~2 for the upgrade version) and I only tend to grab every other version of PSE (usually on sale for like $80-100 for PSE + Premier Elements)...
That's like $160-170 every 2 years for LR + Photoshop/Premier Elements (or less depending on how much the Lr release schedule legs), vs what, like $240 every 2 years for just LR + Photoshop? I'm not opposed to CC on principle, but they'd have to sweeten the deal or kill their standalone software for it to appeal to me value wise.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
Yeah I'm aware of the standalone version, however what has put me off that is the deliberate crippling of the standalone version by stripping out features that they are adding to the CC version. That said I probably don't really need new features - its not as if Elements is updated between major versions so it shouldn't bother me anyway!
I need to play with lightroom more - however if it is going to be so slow even opening folders across a network to open a file I'll be giving it a miss. It seems to open every RAW file in the folder (say 20 meg each) just to render the thumbnail - annoying.
I haven't got around to DXO yet - not sure how well it goes with post processing however.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Interesting and instructive contrast, xelnt. Thanks for postring nt
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Interesting - thanks for that. This was the first time out under the stars with the GX8 so I haven't worked out how far I can push it - I know the limits of the G6 and now I need to figure out how far I can push the GX8.
And grab one of those rumoured 12mm F1.2 Olympus lenses...
Øyvin Eikeland Regular Member • Posts: 173
Or try raw therapee?
Hi,
I am also tempted by the DXO discount. I have been using photoninja+photo mechanic for a couple of years. I think I spend too much time pulling sliders to get the colours right in photo ninja so I am looking for something else. I just stumbled across raw therapee when googling DXO reviews etc. After just two days of testing Raw therapee I am able to beat photo ninja on a couple of my more problematic pictures. Thats quite Promising. I also like the white balance defaults and controls better than the ones in Photo ninja. You may want to check it out. Raw therapee is licensed under GPL and will be free forever.
http://rawtherapee.com/
Regarding your pictures:
I was hoping that the improvement from G6 to GX8 would be even bigger. I need more fuel for my GAS 8-)
BR,
Øyvin Eikeland
PS! Sorry for the off-topic, but you started it
 Øyvin Eikeland's gear list:Øyvin Eikeland's gear list
Sony Cyber-shot DSC-W300 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +6 more
Jorginho Forum Pro • Posts: 15,370
Neither looks good.
I understand you want to show us the differences and the differences are clear.
When I look specifically at the pics I would say it is overexposed. There is no need to see the beach and all other uninteresting things in the foreground. But with F1.8 and ISO2500 there was not much of a visible aurora to speak of clearly so we would probably see nothing if you exposed "right".
mFt sensors have not gained even 1 stop over the past 9 years when we look at noise. Not per DxO and not what we see here where G6 represents the typical mFT sensors 2008-2012. Of course this one was clearly better than the G1 but it was basically due to much better dynamic range.
The best mFT currently are almost identical to the Sony Nex3 from 2010 when it comes to noise. We have gotten us 1/2 a stop extra may be. For such photography that is simply not good enough, but in the end what hampered things the most in this case was the fact that it was merely a photographic aurora...
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
Re: Neither looks good.
So which is it?
This example really demonstrates the difference very clearly. Bump that exposure time even more, and the difference will be even greater (and amp-glow will start showing its ugly head as well).
DxO does not measure dark current, which is the predominant noise source at long exposures like that. And the differences between Panasonic and Sony sensors in this regard are huge, as demonstrated here. So an E-M10 for example, will perform much better at long exposures than most Panasonic cameras except the ones I mentioned earlier. And the difference is much bigger that what DxO or other noise measurements done in "normal" conditions would let you believe.
BTW, the Nex-3 you mention, is actually one of the best APS-C cameras in terms of handling dark current, and would leave both of the Panasonics in the dust for shots of this kind.
So which is it?
All mFts "is it".
I see a difference, I do not see 1 stop difference (subjective like hellof course).
I use G1, GH2, EPL5, GH4 and have used them all for either aurora borealis and noctilucent clouds. EPl5 and GH4 (Sony vs Panny) was actually a win for the latter in the exact same situation if only slight. I think the Panny retains colours and tonality a bit better (RAW) and noise too. It seems thought that beyond 15 seconds the Sony does better.
GH2, EPl5 and GH4 are reasonably similar for low light noise but EPl5 and GH4 indeed are somewhat better. I wonder if the difference reaches significance.
That is my personal experience which remains in line with DxO.
Nonsense. You cannot attribute this to Panny vs Sony since one uses 2010 tech and the other 2015 tech.
Well not for 8s exposures where EPL5 does not do anything better than a Gh4 and in fact does worse.
Beyond 15 seconds may be. At shorter exposures that is not the case.
So. How does this help mFts. A 2010 APS-c that does much better according to you....
I feel mFts can gain a lot when it comes to noise these days. May be new organic sensors will solve this, may be BSI tech or somehting else. I hope so.
I'm not sure you don't understand what I was doing here sorry - this was not about the composition of the photo or the Aurora - it is about how the cameras compared in long exposures and the shadow detail they picked up. The un-edited photo is by no means over exposed. In post I pushed the exposure by +3 to see how cleanly the shadow detail had been resolved.  And I'll disagree about foregrounds - in Aurora photography quite often it is just as much the foreground as the background that makes a photo.
I am sure it can be. But not in this case to my mind, the foreground is just a mess. Sometimes it can be very usefull, I agree.
