Lens logic
Started Dec 8, 2015 | Discussions
iceypix Junior Member • Posts: 27
Lens logic
I have the OMD-EM1 and the 12-40 f2.8 and the 40-150 f2.8, so far so good (awesome even!)
But, after these it gets a bit murky. We have a fixed F4 300mm on the way and the Panasonic 100-400mm on the way, but they're not exactly what I want (yeah I know, this is where you'll all lay into me ;)). The 300mm is, well, too fixed, and the 100-400mm is a bit slow. Would anyone else out there much rather have a 150-300mm F2.8-4 or fixed F4?
Cheers, Levon
www.flickr.com/photos/noveli77
Canon EF 100-400mm F4.5-5.6L IS II Olympus 40-150mm F2.8 Pro
WazPhoto
WazPhoto Junior Member • Posts: 48
Re: Lens logic
Why not just use the TC on the 40-150 f/2.8?
 WazPhoto's gear list:WazPhoto's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro
OP iceypix Junior Member • Posts: 27
Re: Lens logic
I've got it, but that only gets me to 420mm equivalent.
I'd like 600mm Equivalent or more. I like the look of the Nikon D7200 + 200-500mm F5.6, but the weight is marginally too much. But maybe the lens I want would be equally as heavy
Astrotripper Veteran Member • Posts: 8,676
Probably a lot of people
I'm sure there are plenty of people that would welcome such a lens. If it supported TC, you could turn it into a 210-420 f/4-5.6 (or constant f/5.6). That sounds great.
The problem here, I think, would be the price. I think it's safe to say such a lens would be in the $3000-4000 range. The 90-250/2.8 for 4/3 system is a $5000 lens, for example. So while a lot of people would be glad to see such a lens, not many of them would actually buy it.
That price makes it a very specialized, niche offering. It makes more sense to start with lenses that have a higher chance of actually be sold in enough numbers to pay for their development and maybe even turn in a profit.
And I think those upcoming lenses have a chance of doing that. The 100-400 and 300/4 are both targeted at somewhat different audience. And hopefully, they will be reasonably priced. With some luck, their arrival will grow the MFT user base that wants/needs super telephoto lenses. Once there are more people using and needing toys like that, you can think of making more advanced lenses, aimed at really advanced and demanding users.
Something like that.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Re: Probably a lot of people
Grrr. So it's wait. And save my pennies. Drat!
TomFid Veteran Member • Posts: 3,999
Re: Lens logic
What we need is a 2x TC for the 40-150. It would be a bit slow, but it would give the same reach and speed as the xx-300 zooms, with better build and a tiny additional bit of kit.
Re: Lens logic
The 100-400 is also going to be a bit big for my taste:
http://www.43rumors.com/two-new-100-400mm-leica-mft-lens-pictures-from-casey-gutteridge/
It's sitting by a 70-200 2.8, which is almost exactly the same size as the Canon 100-400 L II. By eyeball, I'd say the Panny is smaller by about an inch or 1/8, about the same as the difference in front element size, so you might hope for it to be 1 to 1.2 kg.
There's no precedent for an xx-300 f4 zoom that I know of, but I think it would suit me better. The front element would actually be bigger, but it could probably be quite a bit shorter. I'd be happy with a 4.5, or even just a better-built version of the current 100-300.
Fri13 Veteran Member • Posts: 3,116
Re: Lens logic
Cheers, Levon
I would need a 150-400mm or 150-450mm f/4 PRO. It would be the compliment to the 40-150mm f/2.8 PRO and I would be ready to pay <12 900€ for that if delivers quality like 40-150mm f/2.8 PRO and it is compatible with even 1.4x teleconverter (210-560mm or 210-630mm f/5.6)
And I know almost two dozens from first hand who would buy it as well and many who would be ready to sell their every Canon/Nikon gear for just because that one being available.
300mm prime with f/4 is just not good. Even if it would be f/2.8 or f/2 it would not be usable. With longer focal lengths the primes comes far more limiting tools than with shorter focal lengths where just very small camera distance movements are required to change magnification.
So if I would need to choose between 300mm f/4 and 150-300mm f/4, I would take the zoom. Even if with double the price and with same aperture ratio.
Skeeterbytes Forum Pro • Posts: 23,182
Re: Lens logic
For my purposes (mostly sports) the 40-150 and 300 will pair perfectly.
If you don't mind a focus speed hit, the 50-200+EC14 will get you to 283mm and can be used wide open. A bargain alternative.
Rick
Re: Lens logic
Well, it could work as well, being a stop slower but with much lower contrast. And it would eventually require to stop down to f/6.7-8 range to get the highest contrast.
But it would give exactly the required 80-300mm focal length range that many would like.
Waiting customers to come to you when you are selling nothing to them, doesn't bring you anyway closer to get their money to get product out to sell it to them.
You need to get investors and just make a first small batch of the products that you want to be selling and then sell those and start making more batches to be sold.
That is how the business works, you need the money first to start it.
(unknown member) Veteran Member • Posts: 9,509
Re: Lens logic
Cheers, Levon
If you want it NOW with M4/3, you do actually have some choices with compromises.
Canon EF mount lenses and Metabones AF adapters (and there is the Kipon AF adapter too).
Narcosynthesis Senior Member • Posts: 1,832
Re: Lens logic
It is just a matter of time and money - Canon and Nikon have had decades to slowly build up lens portfolios and a solid foundation of high end users, which is something that mft is only slowly building up. In time there will be enough demand for the more esoteric high end lenses to make them worthwhile developing, but for the moment it just isn't really feasible to produce every high end combination of focal lengths, aperture and zooms to suit everyone.
I think the current plans for the 300mm f4 and 100-400mm make for a pretty well rounded system, but obviously they won't be to the exact preferences of every photographer out there (as neither will the Canon or Nikon lens lineups).
www.flickr.com/photos/narcosynthesis
www.illaname.deviantart.com
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Re: Lens logic
I bought a used 43 50-200 F2.8-3.5 SWD lens with 1.4x TC, cost me about $650US.
Also available new from B&H
The top end is 280mm F4.9 with the TC, that is 140-560mm equivalent and a pretty close FOV match to your Nikon lens.
The C-AF is very fast, some say a hair slower than the M43 50-150, I have no way to compare but definitely fast enough for me.
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
That's fine and dandy, but when the cost of bringing that product to the market is millions of dollars, you'd better have an actual market for it.
And there is probably no viable market for $4000 lenses for MFT system. It's really that simple. People that are willing and actually can spend that kind of money, probably already own such lenses for other systems. Those few in MFT that would actually buy it are not enough and it would end up being a loosing proposition for Olympus.
Of course, they can always sink money to try to create this market from nothing. By why not first release a lens that a lot of people will actually buy and are waiting for?
You can't just make a very expensive premium super telephoto zoom and say: "hey, look what we have here, drop your heavy stuff and come to us". Now, if they would be able to do that for <$2k, that would be another matter.
Anyway, if we're talking about bringing new people into the system. For most people, it makes no sense to buy into a different system for a single lens. It works both ways, actually. I'd love to have a Sigma 20mm f/1.4 and an FF body to match, but I'm not going to spend that kind of money for a single body and lens, no matter how good it is. I'd rather pay $1000 for native f/1.0 or f/1.2 UWA from Olympus. It's not going to be the same, but it will be cheaper and I won't have to deal with bulky DSLR, which I really dislike.
You really need to offer a comprehensive solution. And building that simply takes time. I'd love to see Olympus shift gears and bring those lenses faster, but what can we do.
In the meantime, that 90-250/2.8 will work on E-M1, and you can always pair it up with a teleconverter. So yeah, if you want an expensive, high quality super-telephoto zoom, it's actually available if you can afford it.
Re: Lens logic
I agree.
(unknown member) Veteran Member • Posts: 6,392
90-250 2.8 ED
Cheers, Levon
there is the available Olympus 90-250 2.8 ED. money is no object?
Thanks,
Paul
Re: 90-250 2.8 ED
It's a bit heavy and not quite long enough; plus it needs an adapter which is not ideal.
I'd rather have 300mm or more at long end and F4-ish to save weight.
Re: 90-250 2.8 ED
It's crazy big, heavy and expensive but if I ever encountered one at a low-low-low price I'd have to snag it. See "Calnature" Jeff's work with the 90-250, alone and with converters for some dazzling examples.
"Portable" isn't a word I'd describe it with. My biggest lens is the 35-100/2.0 and that's as much as I want to lug. Knowing what Oly can do with superteles should have everyone's appetites whetted for the new 300. Guarantee it will be spectacular.
Rick
cameron2 Veteran Member • Posts: 4,142
Re: Lens logic
Cheers, Levon
The Oly 300mm f4 will supposedly support the existing TC that works with the 40-150mm f2.8, making it a little less "fixed" for you!
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
