Panasonic GX8
Started Dec 8, 2015 | Questions
JPG73 Forum Member • Posts: 51
Panasonic GX8
I currently own an Olympus OMD E-M5 and have been considering purchasing a Panasonic GX8. as an upgrade. A have the Panasonic/Leica 25mm 1.4, Panasonic 14mm 2.5, and the original Olympus  kit lens. I have also been using a number of mfl lenses with adapters. After looking at the DXMark comparison of the sensors it does not look like I would be gaining very much as far as evf range or image quality.
I seldom make prints to over 11x14 and try to compose so that I do not have to do a lot of cropping. I am getting on in age so auto focusing accuracy is really important to me as well anti shake or image stabilization. Are there any features such as focus peaking  that would still make the GX8  a worthwhile upgrade or should I wait for the next generation of micro 4/3 cameras.
Panasonic Lumix DMC-GX8 Panasonic Lumix G 14mm F2.5 II ASPH
BJN
BJN Veteran Member • Posts: 5,119
Re: Panasonic GX8
Focus peaking is poorly implemented on the GX8. It's okay when it works, but it isn't always easy to see the peaking color. You can change color and the strength of the effect, but those don't entirely fix the issue.
I think you'd be disappointed by the handling of the GX8 compared to your Olympus. At least for some users like me, the right hand back controls are very easy to accidentally activate.
The battery capacity on the GX8 isn't stellar, nor do I care for having the battery and the SD card behind the same door on such a large MFT body.
BJ Nicholls
SLC, UT
 BJN's gear list:BJN's gear list
Panasonic Lumix DMC-GM5
bradevans
bradevans Senior Member • Posts: 1,029
Re: Panasonic GX8
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
tesilab
tesilab Veteran Member • Posts: 3,004
Re: Panasonic GX8
Oddly yellow isn't one of the peaking choices. I find it shows up the best on Sonys. The peaking is much more visible though when you enable the Panasonic B&W preview feature. Then the peaking color is the only color on the screen. The nearest equivalent on other cameras (which I use) is to switch to an actual B&W mode, which still allows color photos in raw, but screws up the embedded JPEG previews.
Olympus offers better stabilization. I think the ease of use of the Panasonic is a bigger factor. I'm also a big fan of aperture rings, which you can use on a nocticron with a Panasonic body.
 tesilab's gear list:tesilab's gear list
Sony RX1R II Panasonic Lumix DMC-GX8 Sony a7 III Panasonic Leica Summilux DG 25mm F1.4 Sony FE 85mm F1.8 +1 more
Kevin Barrett
Kevin Barrett Senior Member • Posts: 1,536
Re: Panasonic GX8
It doesn't seem that you're altogether unhappy with the OMD-EM5. You might be better of waiting for the next gen Olympus models.
I have a GX8. The dual-stabilization and DFD focusing currently works with a limited assortment of Panasonic lenses, of which you do not have. With you're current lenses, you will not realize that benefit.
I cannot comment on how the GX8 compares to Olympus in terms of handling. But the GX8 handles great.
Video doesn't seem to be of interest to you, so... again. Wait for the next crop of Olympus bodies to come out.
I believe that we'll see the EM1-Mk2 in 2016!
Kevin Barrett
Lowell, MI USA
www.kbfoto.com
 Kevin Barrett's gear list:Kevin Barrett's gear list
Canon EOS 5D Canon EOS 7D Sony a7 IV Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM +8 more
martinib Forum Member • Posts: 98
Re: Panasonic GX8
I upgraded from E-M5 to GX8 a couple of months ago. After a little acclimatisation, I much prefer the general handling and ergonomics of the GX8.
Regarding the EVF, I certainly find myself using it much more often than I did on the E-M5. The placement to the side works for me and I often tilt it up about 15 degrees or so as I find that more comfortable. Resolution is noticeably better - I had high expectations so wasn't blown away at first but going back to the E-M5's EVF would hurt now.
For my uses, I have found the IBIS in the GX8 to be perfectly adequate. I haven't tested it as such but have definitely not noticed it to be a retrograde step from that in the E-M5 - it really isn't anything I think about. Note I also have the PL 25/1.4.
It's also true what people say about the menus being better - think I know my way around the GX8 better now than I did my E-M5 after 3.5 years.
 martinib's gear list:martinib's gear list
Panasonic Lumix DMC-LF1 Olympus PEN E-PL5 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH +6 more
trevthebrit Regular Member • Posts: 198
Re: Panasonic GX8 peaking
B&W preview is à Greet tip thanks
TrevTheBrit
I remember using slide film...
http://www.flickr.com/photos/trevthebrit
 trevthebrit's gear list:trevthebrit's gear list
Panasonic Lumix DC-GX9 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 Panasonic 12-35mm F2.8 II Panasonic 9mm F1.7
IanYorke Veteran Member • Posts: 5,266
Re: Panasonic GX8
I also find yellow the best choice for peaking and it is available on the GX8
Ian
