An Adapter's Guide to Camera Mount Register Distance
Started Dec 7, 2015 | Discussions
mapgraphs
mapgraphs Senior Member • Posts: 1,237
If you've been adapting, you probably already know about Stephen Westin's site listing register distances for most mounts. If not, here's the link. It's pretty much self explanatory:
http://www.graphics.cornell.edu/~westin/misc/mounts-by-register.html
Weogo Regular Member • Posts: 199
Re: An Adapter's Guide to Camera Mount Register Distance
Hi Mapgraphs,
Thanks for posting!
Good health,  Weogo
Lightshow
Lightshow Veteran Member • Posts: 6,662
That's the one I usually use, but there are others....
http://www.markerink.org/WJM/HTML/mounts.htm
http://camera-wiki.org/wiki/Lens_mounts
https://en.m.wikipedia.org/wiki/Flange_focal_distance
There are some mounts not listed in other lists, and some mounts have different values listed, so you have to use caution when using these values.
To explain the use of these, pick a lens mount(EF), all the camera mounts with a larger measurement will be impossible to mount that lens to and still reach infinity(modification or optics will be required), of the mounts that are shorter, a simple adapter is required that bridges the gap between the cameras register and that of the lenses, for example, a Canon EF lens(44mm) and a Sony E mount camera(18mm)
44-18=26mm thick adapter, well that's a theoretical number, in reality it will likely be just a fraction smaller so you can still reach infinity, as everything has a tolerance, or an amount of variation.
I don't have any AF lenses, so if I want a picture, I have to do more than squeeze a button.
http://www.flickr.com/photos/lightshow-photography/
My lenses:
http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow
You can't depend on your eyes when your imagination is out of focus.
-Mark Twain
Reputation is the shadow. Character is the tree
-Abraham Lincoln
####Where's my FF NEX-7 ?????
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Leica Elmarit-M 24mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +20 more
MOD Tom Caldwell Forum Pro • Posts: 35,954
Camera Mount Register Distance - some more information
Some extra crumbs of information:
The Samsung NX mount is one of the longer Mirrorless mounts as a result it only adapts to LTM (M39) with difficulty and, to my knowledge, LM requires permanent mount surgery (replacement).
Focal reducers require space between Lens and camera to fit their operating elements.  What is not often understood is that the process of focal reduction shortens the required adapter length.  Provided that it can be done, the shorter length of the adapters can be visually pleasing.
Focal reduction can give more light gathering ability (one stop for 0.71x) and improve lens performance (compression of image).  Older focal reduction adapters seemed also to make lens faults more obvious.  But Brian C stated that his design for the Metabones Ultra for M4/3 mount actually enhanced the performance of any lens mounted by it.  I have no reason to doubt his claims.
Rangefinder lenses have a short flange focal length - too short to make a focal reduction adapter practical.  Several (quite a few) RF lenses have a rear protrusion which makes it impossible to fit them inside many mirrorless mounts as they can hit up against internal baffles, electronic contacts, or even the sensor.
Lens throat diameter has a bearing.  If the host camera mount is wide enough then a small mount lens can be recessed into the adapter where the FFL (register) is shorter than the camera mount.  eg: C to M4/3.
There are practical difficulties.
A very wide MF lens may have its focus/aperture rings difficult to access.  Canon EF lenses can provide AF services via electronic adapters but there are so many of them (lenses) that the performance is variable across both lenses and differen brands of adapter.
Canon EF adapters in their more recent iterations seem to be coming of age and are more truly useful for quick accurate AF over a wide range of both Canon and other brand lenses in EF mount.
And of course if an adapter is badly made then there might be problems in focusing lenses to infinity.  But don't always blame the adapter as the lens itself might be at fault.
Tom Caldwell
Lightshow
Re: Camera Mount Register Distance - some more information
The Samsung NX mount is one of the longer Mirrorless mounts as a result it only adapts to LTM (M39) with difficulty and, to my knowledge, LM requires permanent mount surgery(replacement).
NX is nearly the same registration as Leica M & LTM, but the mount does not have a large enough diameter to accommodate the M mount, there is just enough room for LTM.
This was one reason NX isn't as popular as other mirrorless cameras.
I don't know of many that touch the sensor, maybe a few WA/UWA lenses that get very close to the film might be in danger to the shutter and a remote possibility that the sensor could be touched.
The body helps, the faster the camera handles the processing of the focus data, the faster the lens can be moved.
very true, always compare multiple lenses to confirm an adapter is causing issues.
Tom Caldwell
My lenses:
-Mark Twain
-Abraham Lincoln
Stephen H. Westin Contributing Member • Posts: 703
Alas, the Cornell address has gone dark. My lens register lists are now available at
http://stephen-westin.com/misc/mounts-alphabetical.html
and
-Stephen H. Westin
Lightshow
and
I assume you meant this link: http://stephen-westin.com/misc/mounts-by-register.html
-Stephen H. Westin
Thank you Stephen, very much appreciated, and I speak for a number of adapted lens users, it has been a very handy list to use for reference, especially the more uncommon lens mounts that don't have readily available adapters, so I'm very happy to see its return, I've had to use the Internet Archive since the original site started to return 404's.
I just bough my first camera, Best camera EVER!!!1
Interested in Adapting lenses? head here: http://www.dpreview.com/forums/1065
My shots:
My lenses:
-Mark Twain
-Abraham Lincoln
AudiiDudii Regular Member • Posts: 408
and
FYI, per the factory repair manual, the Contax 645 measurement is 64.00 mm.
E Dinkla Senior Member • Posts: 1,476
and
Thank you for the effort to make a list like that. They are a source for my mount conversions and the Wiki one does not cover all as adequately. The Markering one I used more often in the past but seems less often to show when searching now.
Met vriendelijke groet, Ernst
750+ inkjet paper white spectral plots: OBA content etc.
http://www.pigment-print.com/spectralplots/spectrumviz_1.htm
