Oly 17mm f1.8 or Oly 25mm f1.8
Started Dec 6, 2015 | Discussions
kevinboyer Junior Member • Posts: 46
I just received my new O-Md E-M10 Mark ll a few days ago and want to add a new Oly lens to my arsenal. I have the Oly 45mm f1.8 already, and love it. My other prime lenses consist of a Sigma 30mm f2.8, OLy 12-50 f3.5-6.3, Pany 14mm f2.5 and a Pany zoom lens, as well as 3 legacy lenses. Taking those lenses into account, which of the 2 lenses I mentioned in my title would be a good fit?
Kevin.
https://www.flickr.com/photos/106345762@N04/
 kevinboyer's gear list:kevinboyer's gear list
Olympus OM-D E-M10 II Sony a6500 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +8 more
Olympus OM-D E-M10 Panasonic Lumix G Macro 30mm F2.8 Tamron SP 45mm F1.8 Di VC USD
Michael M Fliegel
Michael M Fliegel Veteran Member • Posts: 3,683
Re: Oly 17mm f1.8 or Oly 25mm f1.8
The 17.
 Michael M Fliegel's gear list:Michael M Fliegel's gear list
Olympus E-520 Olympus PEN E-PL2 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 +13 more
OP kevinboyer Junior Member • Posts: 46
Michael M Fliegel wrote:
The 17.
Thanks Michael. That's what I am leaning towards.
Kevin.
Stan Powers
Stan Powers Veteran Member • Posts: 4,777
Kevin.
I really like using the 17 f.18 on my EM-10II  - it depends on which field of view you like - go out and limit a day to just using 17 or just 25 on your 12-50 zoom - sooner or later you'll get them both!
Shoot First - Ask Questions Later...
www.flickr.com/akasrp
 Stan Powers's gear list:Stan Powers's gear list
Olympus Air Olympus OM-D E-M10 II Olympus PEN-F Fujifilm X-T2 Olympus E-M1 II +20 more
Merks Forum Member • Posts: 74
I have both. I think the 17 is more useful even though I like the sharpness on the 25mm a little bit more. I almost think I might trade in my 25 for a 45 just because they are so alike sometimes. If in a pinch and I want to just bring one prime, I usually lean toward the 17 though.
 Merks's gear list:Merks's gear list
Nikon D5300 Olympus OM-D E-M10 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Sigma 17-50mm F2.8 EX DC OS HSM +4 more
K25 Regular Member • Posts: 296
The 17.
+1
(have both, consider the 17 as necessary and the 25 as good-to-have)
Impulses Forum Pro • Posts: 10,039
This is a pretty subjective thing, to the point that other's opinions might be meaningless... The 17 does slot in more neatly between your other two slower primes; giving you 28, 34, and 60 in EFLs (bigger difference between the former two than between 50/60 IMO). But if you tend to gravitate more towards the 30mm for instance, then you may very well prefer the 25mm.
Some people like their 15-20mm primes better, some like their 25mm... Doesn't seem like there's a ton who use both equally but I'm sure they probably do exist. I prefer my 20mm over a 25mm most of the time, though not always, and I do borrow a PL25 occasionally (although in large part for reasons unrelated to FL).
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
RSTP14 Veteran Member • Posts: 6,370
Neither perhaps...
Given what you have already, the 60 or 75 would perhaps make more sense? If you have to have either the 17 or 25, then I'd favour the 17.
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
EarthQuake Veteran Member • Posts: 3,240
Kevin.
The 17 if you want to replace the 14, the 25 if you want to replace the 30. Both of these lenses are too close to lenses you already have to simply add range, you'll likely find you stop using one of your current primes. So which one are you looking to replace?
I've owned both the 17/1.8 and the 25/1.8, both are great lenses, which to get would come down to what focal length you want to shoot with more so than any other factor, so set your 12-50 to 17mm for a day, and to 25mm for a day, and figure out which you like better.
(unknown member) Contributing Member • Posts: 946
I chose the 25mm F1.8
Kevin.
But that's me.
Since the 25mm lens is a longer focal length, you get more background isolation ability. The 50mm equivalent field of view is considered a standard. If it's not wide enough, you take two steps back or two shots and stitch them together. The 25 is sharper as well. In fact, it's ding dang sharp!
If I was you, I'd keep the 45/1.8, get the 25/1.8, get the 12-32 and sell the rest of your lenses, they are useless. But that's me.
Flickr Photostream
I am who I was.
daleeight Veteran Member • Posts: 3,199
All 5 star reviews of the 17mm Oly on the Oly site. Here is the only non 5 star review on the Oly site for the 25mm f/1.8, and it is a bit misleading or oddly worded...
Pros: Faster than the 12-40mm f2.8 pro
Relatively cheap
Light, your EM1 feels like a Point and Shoot with this lens
Cons: Sharpness is not better than the f2.8 pro
DOF is not better than the f2.8 pro
Bottom line: if you already own the f2.8 pro, do not buy this one.
I purchased this lens along with the OMD-EM1 and the 12-40mm f2.8 pro. Before I got this lens, I also test the Nikon 50mm f1.4 on the Nikon D750 body. I really enjoy the DOF of the Nikon combination and was hoping to achieve the similar effect by using this prime lens. However, the result was quite disappointed. This lens is just not fast enough to get close the isolation effect like the Nikon combo. It is not much different than the f2.8 pro lens at 40mm. In term of sharpness, it is as good as the f2.8 pro but not better. Now to the pros, it does faster than the f2.8 pro so you do not have to rely on higher ISO to shot indoor photos.
Dale
 daleeight's gear list:daleeight's gear list
Olympus E-M1 III Nikon Z7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +6 more
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
I don't think it is very surprising that an f1.8 lens on MFT does not give you the same thin DOF as an f1.4 lens on full frame.
To the OP - you already have a 14 and a 30 prime. Why do you do you want to add the 17 or 25? Faster? Better? Just bolstering your lens collection?
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
Re: I chose the 25mm F1.8
Peter Mathews wrote:
Kevin.
But that's me.
I agree with the above. If you have one body, unless you love swapping lenses, you're going to choose a favourite in a range, and not use the other. The 30/2.8 won't have a use if you chose the 25, and likewise for the 14 if you choose the 17. The 12-50 is slow and awkward, with the 12mm end and the close focus ability (and weather sealing) about the only redeeming qualities for me. I sold it and got the 12-32. You have the 45 for the long end, which is light years ahead of the 12-50 at the long end, and the 12-32 will match or beat the 12-50 in its range, at 1/3 the size and weight.
Plus, if you get the 12-32, you still have a pancake when you want the small size, so the 14 can go, regardless of if you choose the 17 or 25. (again the 12-32 will easily match the 14). The 12-32 can be found for $250 or so, new or nearly new on ebay. The 17 is harder to find, at around $300, so probably better to buy new, same as with the 25.
But first, do as others have suggested and force yourself to use each FL on your 12-50 for a day, then compare results.
All of these are good lenses, and no choice is permanent, so you can't really go wrong.
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
Johnny The Greek Regular Member • Posts: 251
In terms of optical quality, the 25mm wins hands down.
In terms of usefulness, to me they are about even, but I switch to the 17mm when I have less space indoors.  As one other person says, it really depends on what you like to shoot.
 Johnny The Greek's gear list:Johnny The Greek's gear list
Olympus PEN E-PM2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +10 more
yoyosm New Member • Posts: 16
Kevin.
Sell everything (you may keep the 45mm) and buy the Oly 12-40 2.8. Since I have the 12-40 I never miss the 17 or 25 primes
 yoyosm's gear list:yoyosm's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS Olympus M.Zuiko Digital 17mm F1.8 +4 more
EddieinNiseko Junior Member • Posts: 30
I have an omd em5 and panasonic gm1. I got rid of the 12-50 kit lens long ago as i didnt like the zoom ring feel, awkward length and slow f-stop.
As such now I have the 12-32 zoom, 17mm f1.8 and 45 f1.8 as well as the bodycap fisheye.
I know a lot of people complain about the 17mm sharpness but I find it more than sharp enough and absolutely love its handling. The manual focus clutch with focus peaking on the gm1 is fantastic. It does feel like a "premium" lens unlike the 25mm.
I like this guy's ramblings on the 17mm f1.8
...."oor or at least not "stellar" sharpness reviews became over time an irrelevance, and a bit of a lie. A bit of sharpening brings out lots of nice detail in a pleasant, non jarring way and the lens is very focus forgiving due to its bokeh rendering (above). It's not "snappy" sharp (well usually not, but it surprises) like its longer siblings, but it is "honest" sharp like film would be and it produces good sharpening for prints."
http://photokensho.net/thoughts
"On lens reviews October 26th"
Henry Richardson Forum Pro • Posts: 21,959
Kevin.
I've got the O 45mm and P 14mm too. I also have the O 25mm. I like that trio.
Henry Richardson
http://www.bakubo.com
2 * 14 and 3 * 14
Kevin.
Not that it is particularly important, but 25 is about 2 * 14 and 45 is about 3 * 14. Just a nice sequence of focal lengths, IMO.
Henry Richardson
DP13Photo Veteran Member • Posts: 6,307
I wouldn't get either. I'd get the Panasonic 15/1.7 and the Panasonic 25/1.4 to go along with your 45/1.8.
Dave
 DP13Photo's gear list:DP13Photo's gear list
Sony a7 III Sony a7C Sony a7 IV Sony FE 28mm F2 Zeiss Batis 85mm F1.8 +15 more
addlightness Veteran Member • Posts: 3,641
Kevin.
I have the P14mm and O25mm (to duplicate my 35mm film Zuiko 28mm2.8 and 50mmf1.8).  Those are my favorite FL's.   I have a wide-converter for the 14mm giving me ~10.5mmf2.5.
I also have the pancake O17mmf2.8(I don't have the f1.8) for street photography with my GM1 when the 14mm is too wide and the 25mm too narrow.
However, I use the 14mm and 25mm much more than the 17mm.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
