finally have what we always wanted: HEVC support in Adobe Premiere!
Started Dec 2, 2015 | Discussions
blassox New Member • Posts: 6
5
Update your CC installation to 2015.1, take a deep breath, and start editing
Thanks adobe!
PS: first impression is very good, i7 5820K seems to work smooth with NX1 pro grade footage
Samsung i7 Samsung NX1
LiveM Veteran Member • Posts: 3,836
Re: finally have what we always wanted: HEVC support in Adobe Premiere!
Even more important is Lightroom supoort.
 LiveM's gear list:LiveM's gear list
Samsung NX1
Bubbleboy Forum Member • Posts: 94
Yep, Adobe always supports Nikon products
 Bubbleboy's gear list:Bubbleboy's gear list
Samsung NX1 Samsung NX500 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Samsung NX 20-50mm F3.5-5.6 ED +10 more
aLf4 Forum Member • Posts: 86
such big news for us... finally. It was a pain in the ass to have to convert to ProRes.. and the size of the files were huge!!
Bengaldad Junior Member • Posts: 28
The latest version of Lightroom does not support importing or playback of h.265 (HEVC). The latest version of Premiere Pro CC 2015 does, but not Lightroom.
Tom
 Bengaldad's gear list:Bengaldad's gear list
Canon EOS R5 Apple iPhone 12 Pro Apple iPhone 12 Pro Max
Which is ridiculous, isn't it?
Samsung NX1
MountaineerMan Regular Member • Posts: 134
I have adobe premiere pro CS6 is there a way to upgrade my version to get H.265 support without subscribing to CC?
P.S I am also looking forward to light room support of H.265
Absolutely and totally ridiculous!
CS6 is out of time for upgrades but it doesn't matter as Lightroom and Photoshop are only $10/month.
Samsung NX1
jwang88 Regular Member • Posts: 391
Wish FCPX could support the h265 file soon.
Happy Daze Contributing Member • Posts: 565
Crushed Blacks ..
For some reason the H.265 codec in Premiere appears to alter the contrast of the original file of the NX1 resulting in crushed blacks.
I have found that applying the brightness and contrast filter to all clips using these settings brings it back fairly close to the original exposure: brightness -3, contrast -15. (Video Effects, Color Correction, Brightness & Contrast)
Can not fathom how Adobe made such a basic mistake when they have been promising this support for months.
VisualFX
VisualFX Senior Member • Posts: 1,241
Re: Crushed Blacks ..
Sounds like you have something incorrectly set on your side of things? 709 color space?
 VisualFX's gear list:VisualFX's gear list
Fujifilm X-E3 Fujifilm X-E4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR +4 more
Melidonia Regular Member • Posts: 296
I have the same issue.
 Melidonia's gear list:Melidonia's gear list
Sony a7 II Panasonic Lumix DC-S5 Panasonic Lumix DC-GH6 Sony FE 35mm F1.4 Panasonic Leica DG 50-200mm F2.8-4 +3 more
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
do you use 0-255 or 16-235? I get better results with 16-235.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
No, I am just comparing a pre-converted file (Samsung Converter) to a direct import on the same timeline. The same file played directly as H.265 in other media players shows far less contrast than the same file played within Premiere.
I see a lot of discussion regarding this matter but I see little point in limiting the capture range or output range of video these days, most modern equipment can handle the full range in playback without an issue.
MikeDPR Regular Member • Posts: 241
Do you have a calibrated monitor? If you run a color profiled monitor, you can get different looks (e.g. colors, gamma) depending on which video player you use. I could be wrong but I believe Premiere Po is color managed while most free media players are not, Media Player Classic being a notable exception and my favorite.
Just throwing out an idea. I have the Premiere Pro CC but haven't tried it since the h265 update.
 MikeDPR's gear list:MikeDPR's gear list
Samsung NX300 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 85mm F1.4 ED SSA +2 more
Crushed Blacks A Sample
A sample:
Photo 1: 4K file converted with Samsung Converter (highest quality) and frame grab taken from Premiere time-line (no effects)
Photo 2: Same 4K file direct import to Premiere (same time-line) frame grab same as above (no effects)
Definite loss of shadow detail in the directly imported sample.
Re: Crushed Blacks A Sample - The scope View
Luma Scope: 4K file converted with Samsung Converter (highest quality) on Premiere time-line
Luma Scope: Same 4K file direct import to Premiere (same time-line and same frame)
In directly imported file Blacks and highlights are clipping.
I have two calibrated monitors which show exactly the same problem.
I have shown a sample in another post which I think is fairly conclusive.
Try it for your self, and let us know your conclusion.
