Experimenting with Focus Stacking
Started Dec 2, 2015 | Discussions
Denjw
Denjw Veteran Member • Posts: 6,853
I have been doing some more experimenting with focus stacking, particularly which is the best focus differential point and where to set initial focus.
Nothing very scientific or a real closeup/macro ,but just to see how it works.
Mounted my E-M1 and 40-150mm on a tripod at about 45 degree downward angle.
Subject is a tape measure on a table. Note tape measure is not completely flat on table as it bends between the edges. Set initial focus point on the numeral 10 at a focal length of 150mm.
Set camera to Manual, SS 1/250 sec, ISO 200, WB Cloudy (Indoor shed with skylight above on a dull cloudy day), A f5.6, , Noise Filter Off.
Sample shots:
Initial focus frame
Focus stacked image narrow setting 1
Focus stacked image narrow setting 3
Focus stacked image mid range setting 5
Focus stacked image wide range setting 10
My observations:
  • I found that focus differential point 3 seemed to give the best overall result with most numbers in focus across the range.
  • As the focus differential point goes wider the range increases but there a gaps in focus, see wide range setting 10.
  • When the images are being taken in focus stacking mode the focus point initiallymoves foward at Frame 2 from the initial focus point. Then moves back slightly foward of the initial focus point. See images below.
Frame 1 with narrow setting 3
Frame 2 with narrow setting 3. See how focus is now near numeral 4.
Frame 3 with narrow setting 3. Focus has now moved back slightly to near numeral 5.
I put together a GIF of the 8 images to see how the focus points change. Hope it works.
This is GIF of the 8 frames changing focus.
Hope this helps and any comments/thoughts on my unscientific experiment are welcome.
Cheers
Dennis
 Denjw's gear list:Denjw's gear list
Olympus E-300 Olympus E-30 Olympus E-5 Olympus E-M1 Olympus E-M1 II +17 more
Olympus E-M1
Denjw
OP Denjw Veteran Member • Posts: 6,853
Comparison between in-camera and PsCS
Put the same image through the Load Files into Stack and used Auto-Align Layers & Auto-Blend Layers to compare with the in-camera result.
In- camera stacked image with narrow 3 setting
Stacked image using PsCS6
Bit hard to tell any difference. What do you think?
Martin.au
Martin.au Forum Pro • Posts: 14,336
Re: Experimenting with Focus Stacking
Lovely. Nice to see some confirmation of my results here:
Stacking - Apertures and Differentials.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Garry Schaefer Veteran Member • Posts: 3,348
I appreciate your effort and contribution toward our much clearer understanding of how all this works.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +8 more
