Recommendation for External flash for 1200d
Started Dec 2, 2015 | Discussions
Dunlop96 New Member • Posts: 1
So i bought the yognuo yn565ex ii. i was told it works for the 1100d so will probably work for the 1200d. but once attached the flash doesn't fire when a picture is taken. maybe someone can help me there.
but in the other hand will probably get another flash that will work properly for the 1200d anyone got any recommendations for this camera, maybe something they are using? thank you.
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50) Canon EOS 1200D (EOS Rebel T5 / EOS Kiss X70)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Recommendation for External flash for 1200d
I assume you've checked that you haven't inadvertently set the speedlite or the 1200D's menu to disable flash
Yongnuo, like Sigma, has struggled to correctly backward engineer Canon's ETTL flash autoexposure system.   Myself, I just pay the extra for a Canon EX speedlite and have no worries about compatibility.
IMHO, YMMV.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
dleemans Regular Member • Posts: 130
Do yourself a a favor and get a Canon 430ex or 430exII. It will work flawlessly on your 1200D.
 dleemans's gear list:dleemans's gear list
Canon EOS-1Ds Mark III Canon EOS 550D Nikon D600 Nikon D610 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +5 more
msowsun
msowsun Contributing Member • Posts: 740
Are you using Liveview? 3rd party flashes don't work if you are in Liveview with "silent shooting" enabled. Just go into the menu and disable "silent shooting".
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
007peter
007peter Forum Pro • Posts: 12,933
$95 Aperlite YH-700C | Work 100% with Ease, HSS + Wireless
I had two Canon 430ex and a Canon 90ex (wireless master), and I sold themafter I bought an Aperlite YH-700c.  Its a more powerful flash with much quieter & faster recharge time:  my canon 430ex makes an annoying high-pitch sound recharging between shots.
What I LOVE about the YH-700C is the ease-of-use.  I never did read the Manual, I just pop the camera into my hotshoe and everything works.  Want High-Speed-Sync, no problem.  Wireless flash with Aperlite is also super-easy: press zoom button once, then up/down arrow, select Wireless slaves and you're good to go.  You do need a cheap Wireless Master (like 90ex) if you want to try wireless flash.
I love wireless flash setup.  Avoid mounting Big/Heavy flash ontop of my camera is liberating.  I love the new freedom of movement and flexibility that wireless flash provides.  Once you gone wireleess, its hard to go back to using hotshoe.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
photonius Veteran Member • Posts: 6,895
Re: $95 Aperlite YH-700C | Work 100% with Ease, HSS + Wireless
i cant hear my 430ex II
*** Life is short, time to zoom in *** ©
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
007peter
@photonius - 430ex II don't make sound like EX (1)
We're talking about 2 different flashes.  The original Canon 430ex has a very LOUD recharge sound.  The II fix this problem.
Re: @photonius - 430ex II don't make sound like EX (1)
well, just wanted to point out that the argument against the 430ex does not apply to the markII version (the one which is sold nowadays).
shekinahrj New Member • Posts: 1
Hi, I was wondering if you need any triggers or remotes for the 430ex?
I also have a 1200d and am in the market for an external flash, but have only been recommended kits of over £200. I just need a simple flash I can connect to my camera
JPAlbert Senior Member • Posts: 1,296
I agree with dleemans above.
I picked up my Canon speedlite from their online refurbished store.
It was like new and saved some money as well...
