G5X Dimensions
Started Dec 1, 2015 | Discussions
Macro
Macro Senior Member • Posts: 2,758
G5X Dimensions
G5X User Guide has the following dimensions...
I'm trying to determine if the G5X will fit in the case I use for my G11.
Can someone confirm whether or not the Depth measurement (44.2mm / 1.74 in.) includes the viewfinder extending from the back... or only the body + lens depth?
 Macro's gear list:Macro's gear list
Panasonic Lumix DMC-FZ100 Canon PowerShot G5 X Sony RX10 IV Fujifilm X-T1 Fujifilm X-T2 +6 more
Canon PowerShot G11 Canon PowerShot G5 X
accupix Regular Member • Posts: 241
Re: G5X Dimensions
With the rubber eye piece, you are looking at a 2" depth front-to-back.
 accupix's gear list:accupix's gear list
Sony Cyber-shot DSC-R1 Sony RX100 III Canon PowerShot G5 X
Seedeich Veteran Member • Posts: 3,034
Re: G5X Dimensions
It’s 112 x 81 x 52 mm including the hot-shoe and viewfinder.
But it fits into the Lowe Pro pouch, that I used for my G11 with the strap wrapped around it - loose fit.
Jack Kennealy Regular Member • Posts: 269
Re: G5X Dimensions
Is the rubber eye piece easily detachable?
 Jack Kennealy's gear list:Jack Kennealy's gear list
Canon PowerShot G10 Canon PowerShot G5 X Sony RX100 VI +1 more
Adam Tow Regular Member • Posts: 325
Re: G5X Dimensions
Check out CameraSize.com to compare the G5X size with other cameras. It doesn't have the G11, but the G12 is similar in size.
http://camerasize.com/compare/#637,101
Re: G5X Dimensions
I tried with a little heft, and it didn't budge so I didn't explore further- it is pretty rigid so consider it part of the body.
Re: G5X Dimensions
I am getting a custom fitted case from Ripoffs Holsters in a day or two that will live on my belt. The Lowepro size that fits is still too big and the double zipper is too discouraging to get the camera out resulting in too many missed shots.
Re: G5X Dimensions
I'd love to hear how it fits, what it costs, and how happy you are with it!
Macro
OP Macro Senior Member • Posts: 2,758
Re: G5X Dimensions
Thanks for verifying.
camerasize.com depth dimensions indicate the GX5 is 4.1mm thinner than the G11. However, the top-view comparison visually shows the GX5 being thicker (assuming the photos are scaled correctly).
It appears Canon did not include the rear viewfinder extension in their 44.2mm/1.74" depth spec.
Macro
Re: G5X Dimensions
I checked Camera Size before starting this thread. Their depth dimensions indicate the GX5 is 4.1mm thinner than the G11. However, the top-view comparison visually shows the GX5 being thicker (assuming the photos are scaled correctly).
It appears Canon did not include the rear viewfinder extension in their 44.2mm/1.74"depth spec.
Macro
Re: G5X Dimensions
Thanks.  I wonder how Canon came up with a height of 76.4mm, perhaps not including the hotshoe?
