Maximum bulb time for the various MFT cameras?
Started Nov 28, 2015 | Discussions
Big Ga Forum Pro • Posts: 18,623
Hi Folks,
I couldn't find a list of the maximum bulb time available for the various MFT cameras so I thought I'd start a thread asking to save me trawling through dozens of manuals and/or spec sheets
It'll be good to have this all in one place.
If you happen to know for sure the max time for a particular camera, any chance you can fill it in below? (or add any cameras I've left out if) I'll try and compile a full list later on for easy reference.
TIA
EM1
EM5MkII
EM5
EM10
EM10MkII
GX8
GX7
GH4
GH3
GH2
G7
G6
GM5
GM1
Fri13 Veteran Member • Posts: 3,115
Re: Maximum bulb time for the various MFT cameras?
If I remember correctly the E-M1 and E-M5(2) had 6 hours max bulb. You will run out of power before that if not swapping battery in grip when it goes empty.
Digital Dick Senior Member • Posts: 1,910
The max timer setting for the Live Time / Bulb for the E-M5 and E-M5 MII is 30 minutes. Time lapse can go longer.
Dick
 Digital Dick's gear list:Digital Dick's gear list
Olympus OM-D E-M5 Olympus E-M5 II
Alan WF
Alan WF Senior Member • Posts: 1,746
GM5 60 seconds (T shutter speed - press to start then press again to end).
Alan
 Alan WF's gear list:Alan WF's gear list
Panasonic Lumix DMC-GM5 Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS +15 more
jim stirling
jim stirling Veteran Member • Posts: 7,356
Big Ga wrote:
Hi Folks,
TIA
EM1
EM5MkII
EM5
EM10
EM10MkII
GX8
GX7
GH4
GH3
GH2
G7
G6
GM5
GM1
The GX8 is up to 30 mins when you press the shutter at bulb
The GX7 is up to 2 mins when you press the shutter at bulb
The GH4 is up to 60 mins when you press the shutter at bulb
 jim stirling's gear list:jim stirling's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Nikon D810 Panasonic Lumix DMC-GH4 +12 more
Mark Thornton Veteran Member • Posts: 4,151
GX1 is about 120 seconds (2 minutes)
 Mark Thornton's gear list:Mark Thornton's gear list
Panasonic Lumix DMC-GX1 Panasonic Lumix DC-GX9 Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 +6 more
OP Big Ga Forum Pro • Posts: 18,623
Curious. We seem to be seeing a trend where the Sony sensors are a fair bit cleaner at long exposures compared to the Panasonic ones (which I imagine is why the GX7 is limited at a fairly short 2 min!).
But if the GH4 figure is correct, that seems to fly against conventional wisdom?
Or might it be another issue - battery life or something ?
What's the GH4 output like at really long exposures ?
cameron2 Veteran Member • Posts: 3,432
Doesn't the GH4 use a Sony sensor?
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
GV27 Regular Member • Posts: 324
Alan
ditto for GM1
 GV27's gear list:GV27's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DC-GX9 Nikon AF Nikkor 24mm f/2.8D Panasonic Lumix G 25mm F1.7 ASPH 7artisans 7.5mm F2.8 Fisheye +5 more
Martin.au
Martin.au Forum Pro • Posts: 13,250
Big Ga wrote:
Hi Folks,
TIA
EM1 - 30 mins (3 hours live composite)
EM5MkII - 30 mins (3 hours live composite)
EM5 - 30 mins
EM10 - 30 mins (3 hours live composite)
EM10MkII - 30 mins (3 hours live composite)
GX8 - 30 mins
GX7 - 2 mins
GH4 - 60 mins
GH3 - 60 mins
GH2 - 2 mins
G7 - 2 mins
G6 - 2 mins (reported as 4 mins on http://www.photographyblog.com/reviews/panasonic_lumix_g6_review/image_quality/)
GM5 - No bulb mode. Max shutter ~ 1 min
GM1 - No bulb mode. Time mode/Max shutter - ~ 1 min
Think that's it.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Panasonic Lumix G Fisheye 8mm F3.5 +7 more
Martin.au
Given the GH4 is a 4K beast, I suspect it's really, really good at dissipating heat from its sensor. That may explain it.
mrc4nl Regular Member • Posts: 366
Re: gx7 bulb time
its been i a while ive tested it, its about 210 seconds. just a little more than 3 minutes
jim stirling
I have never taken a shot of anything anywhere near the 30min+ mark given the issues of shadow noise on every mFT camera I have owned .I would not expect very good image quality
No.
Why would the sensor generate (excessive) heat when all its doing is collecting photons?
Martin.au wrote:
Big Ga wrote:
Hi Folks,
TIA
EM5 - 30 mins
GX8 - 30 mins
GX7 - 2 mins
GH4 - 60 mins
GH3 - 60 mins
GH2 - 2 mins
G7 - 2 mins
Think that's it.
Ok, that's useful info. If correct
I actually suspect most of it is right, but we do have a few anomalies.
1. Fri13 seems to think the Oly cameras have a MUCH longer bulb mode than the 30 min above.
2. I'm still confused about the discrepancy between the GX7 and GH4, despite conventional wisdom saying they use the same/similar sensor.
3. And why so short? Some other manufacturers don't seem to have a limit. Why do ALL the MFT cameras, some of them seemingly ridiculously short? (when compared to 'infinite').
Can someone check the EM1 and EM5II times?
I've been checking my various cameras when I've had a chance.
I can only get the EM1 and EM5II bulb times to be a max of 8min. (forget any fancy live this or that for now - just straight bulb mode).
Is there a setting I have wrong that I need to activate to extend the time?
Big Ga wrote:
Martin.au wrote:
Big Ga wrote:
Hi Folks,
TIA
EM5 - 30 mins
GX8 - 30 mins
GX7 - 2 mins
GH4 - 60 mins
GH3 - 60 mins
GH2 - 2 mins
G7 - 2 mins
Think that's it.
Martin.au
Re: Can someone check the EM1 and EM5II times?
How do you have non-live bulb mode on an E-Mx?
Never mind.
cog menu e -> bulb/time timer.
Pikme Senior Member • Posts: 2,176
Yes
Sorry I don't have either the camera or the manual with me, but I know there is something in the menu where you set the maximum time allowed for bulb exposures.
Roberto M.
For the EM5, it is in the 'E' menu (Exp/ISO)
Roberto M.
