Oly 12-40 f2.8 Pro + 1.4TC - any good?
Started Nov 27, 2015 | Discussions
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
I am torn between getting an Olympus 12-40 F2.8 or a Panasonic 12-35 f2.8 to go on my Panasonic GX7 (which does have in-body stabilisation). But have a few questions that I hope some of you may be able to help me with:
1) Does the Oly 1.4TC (from the 40-150 F2.8 Pro) fit the Oly 12-40 as well?
2) Does the Oly 12-40 F2.8 focus quickly, on the GX7 (or any other Panasonic camera) ?
3) Which is generally sharpest across the frame at F2.8 at all zoom settings?
PS. I do need the F2.8 to shoot indoor fast sport, so stopping down is not a preferable option ... even though I realise that with a 1.4TC I will loose a full stop of light.
If anyone can help me with any of these queries I would much appreciate it.
Thanks.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Olympus 40-150mm F2.8 Pro Panasonic Lumix DMC-GX7
coldfire22x
coldfire22x Regular Member • Posts: 252
Re: Oly 12-40 f2.8 Pro + 1.4TC - any good?
Only fits the 40-150 f2.8 right now.  Should fit the 300 f4 once that is released.
 coldfire22x's gear list:coldfire22x's gear list
Olympus E-M1 Olympus E-M5 II Panasonic Lumix G Fisheye 8mm F3.5 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital 45mm F1.8 +6 more
Adrian Harris
OP Adrian Harris Veteran Member • Posts: 7,708
Oh that is a shame, as I already have the 40-150 + the 1.4TC the extra versatility would have swung the decision.
Skeeterbytes Forum Pro • Posts: 23,182
I almost hate doing this but will toss out the potential for pairing the 12-40 with the 75/1.8. Makes a great two-lens kit that excels in low-light.
Teleconverters seem to not be an easy thing in m4/3. The original 4/3 system has two great ones that can pair with many lenses.
Rick
jeffharris
jeffharris Forum Pro • Posts: 11,409
YES! On the GX1, GX7 and GX8.
The 12-40mm is a good match with the GX7.
I chose the 12-40mm over the 12-35mm for a few reasons. The extra reach, tests I've seen seem to indicate it's a bit sharper, the focus clutch is a nice feature, especially when coupled with it's close focus ability for near-macro shooting.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
robonrome
robonrome Senior Member • Posts: 2,334
Rick
it's a great combo that I use when traveling
 robonrome's gear list:robonrome's gear list
Olympus E-M1 II Sony a7R III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 35mm F2.8 +10 more
coldfire22x
The 12-40 has a little more reach and a closer minimum focusing distance but is bigger and heavier than the 12-35.
In the end, you can't really go wrong with either though.
Fri13 Veteran Member • Posts: 3,116
At wide open 12-40 is sharper 12-35mm range. Then at 35-40mm you need to stop down to f/4 to get its sharper.
Adrian Harris
My Dilemma - Re: Oly 12-40 f2.8 Pro on GX7
Thank you for all your advice, much appreciated.
Update: I got to road-test a GX8 today (with the 12-35)  and am keen to 'upgrade', But I really would prefer the Oly 12-40 (and that little bit of extra reach will be extremely useful for Roller Derby), but my agonising choice now is that The GX8 is currently being offered at a great price as a package with the Panny 12-35 f2.8 pro, so the Oly would end up costing me about £300 more if I bought the Gx8 separately
.....sadly I am not well off
If only one was rich (money-wise).
jeffharris
Re: My Dilemma - Re: Oly 12-40 f2.8 Pro on GX7
Get the GX8 kit with the 14-140mm II.
Or just get the GX8 + 12-35mm kit and sell the 12-32mm.
Zenodroid New Member • Posts: 18
The discussion on the 1.4 tc on 12-40mm f2.8 pro, died fast. Since we are in 2020 now, does it work together now? Will it give any benefit over the 12-100mm?
bluevellet Veteran Member • Posts: 4,169
7
No.
See you in 2025.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
No, and it never will. The TC needs to extend into the back of the lens. There's no space on the 12-40.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
Mottenhaus Forum Member • Posts: 72
Even if that would work. Who really needs 17-56mm Zoom lens, if 12-100 is possible with this incredible stabilized F4 lens.. ?
It wasn't necessarily clear when the MC14 came out that it was not a twin to the 4/3 EC14, which pairs with any and every 4/3 lens. That allowed for lots of flexibility and experimenting, and some decent options for traveling with a compact kit. One could imagine being able to mount the 75/1.8 on a TC, to pick a random example.
I doubt any of us were prepared for Oly and Panny TCs to not be cross-compatible.
Rick
Jeff Wahaus Contributing Member • Posts: 943
"I am torn between getting an Olympus 12-40 F2.8 or a Panasonic 12-35 f2.8 togo on my Panasonic GX7 (which does have in-body stabilisation).""
My view is that you would be better off getting a used Zuiko 12-60 f2.8-4 and m4/3 adapter.  I've been struggling with replacing this lens with a more modern m.zuiko lens but I have not been able to find a suitable replacement lens.  (so I'm keeping the 12-60 Zuiko for now).  My body is an OM-D M1 mkiii.
What can really replace the Zuiko 12-60?
The m.zuiko 12-40 f2.8 is a contender but it has less range and is arguably not any sharper than the 12-60.
The m.zuiko 12-45 f4 is also a contender but like the 12-40 has less range and is a full stop slower than the 12-60 on the wide end.
The m.zuiko 12-100 f4 is the closest to a replacement for a 4/3 to m4/3 lens.  It has better range, not sure about sharpness, and again is a full stop slower at the wide end.  It's not a small lens so the motivation of getting a m4/3 lens to replace the 12-60 with a more compact m4/3 lens goes away.  The 12-100 is just as big as the 12-60 with m4/3 adapter attached.
The only real advantage I can see with replacing the 12-60 with one of the above would be for shooting video.  The 12-60 does not support continuous auto-focus and I expect all of the above lenses would.
 Jeff Wahaus's gear list:Jeff Wahaus's gear list
Olympus E-M1 III Olympus OM-D E-M10 IV Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +6 more
Felice62 Veteran Member • Posts: 5,079
Thanks.
Why not thinking about the PL12-60?
Is the F/4 a showstopper ?
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
Will just note that once I became accustomed to constant-aperture zooms, variable aperture is a letdown. I still use a few but much prefer the former, even at the cost of lost zoom range.
My $0.02
Rick
jeffharris
I bought a 12-40mm f2.8 for my GX7 and had no issues. The GX7's IBIS was certainly adequate for that lens' range. If it were okay, I'd probably opt for the PL 12-60mm f2.8-4. Still, the constant aperture is more appealing than losing 2 stops at full zoom.
The adaptor adds cost and weight. That lens' AF would be sub-par compared to any of the modern, designed for M4/3 zooms mentioned above.
The 12-40mm's close focusing ability (plus the extra range) was one of the main reasons I bought it instead of the 12-35mm f2.8. The snap-back manual focus ring is a nice addition, too.
Both are rather unwieldy for a GX7, being essentially all-day lenses, although I happily used a 100-300mm with my GX7, but that was used more for targeted, short term shooting, not all day.
drj3 Forum Pro • Posts: 12,633
The FTs 12-60 SWD is a very good lens.  I used it as my wide/normal zoom until an Olympus trade in ($200 for any lens) plus $100 off sale price.  I really haven't used the 12-60 since I got the 12-100.  It is on my E-M1.1 in case there is a situation where I want the 12mm f2.8.  However, unless something is moving, the extra dual stabilization of the 12-100 more than compensates for the one stop aperture loss at 12mm.
The 12-100 is easily as sharp as the 12-60 and it focuses far more quickly and accurately, especially on anything moving.  The extra 40mm focal length makes it the ideal general purpose lens.  It is mounted on my E-M1.2 and only removed if I need the 50-200mm SWD for a telephoto zoom.  The 300mm f4 stays on the E-M1.3.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
