Experiences in home cleaning your samsung sensor
Started Nov 26, 2015 | Discussions
mordor_74 Contributing Member • Posts: 622
Hi,
i take good care of my cameras, so i dont need a cleaning very often and usually the incam cleaning do the job. In the past i made use of payd service if it was needed.  but...
i've just bought an NX20 at a very good price and in very good condition but with some dust on the sensor. I dont like the idea of part with the newcomer right now so i wondering if some here did the job itself and if any damage was ever done during that job.
In past i've seen pictures of sensor heavily damaged by a wrong cleaning operation and i wonder how sensible can be a modern samsung sensor.
Thank you all
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
Samsung NX20
zipcode Regular Member • Posts: 312
Re: Experiences in home cleaning your samsung sensor
Try with a dust blower at first. I had some bigger dust (like small thin fabric thread) that I removed with a soft brush and nothing (bad) happened. I knew it was there after I got a whole batch of pretty much ruined pictures, because it showed in the pictures a lot more than one would expect.
VisualFX
VisualFX Senior Member • Posts: 1,241
 VisualFX's gear list:VisualFX's gear list
Fujifilm X-E3 Fujifilm X-E4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR +4 more
Glass is quite strong and not likely to be damaged unless one is very creative and reckless at the same time. Then again, people do all kinds of fun things with best intentions, personal story follows.
Borrowed camera to one friend, he apparently got some dirt or dust on sensor, saw it and wanted to remove it so he blew into sensor. Several miniature drops of spit landed on the sensor and dried up. I had to clean the sensor. First try blower, it did not help me but could remove loose particles. Then apply cleaning swabs (wet ones for dried liquids and similar) like VisualFX already said. This should clean the sensor up.
I know people who use microfiber cloth for cleaning everything, but I prefer blower + swabs.
Whatever you do don't blow from your mouth and don't use canned air (it can contain various particles, grease or oil in small quantities). Use cleaning products made for cameras.
MGJA
MGJA Regular Member • Posts: 477
I've used microfiber cloth infused with Isopropyl alcohol wrapped around the line of a twin-legged toothpick for sensor cleaning across a variety of sensors, among them Samsung's, for years. Never had any issues. Use a blower first, then sweep carefully in one direction. Infuse so that the cloth is moist, but not dripping. Do not press hard. Feed the cloth along between each sweep so that a new fresh part is used. Normally do two-three sweeps, then wait, then do another two-three, then wait, then finally do one or two more, now with dry cloth.
MatthewWebb New Member • Posts: 1
yes i do agree with your suggestion
BopBill Forum Member • Posts: 74
This could be good tool for removing small dust particles from sensor. I bought myself the SensorKlear II although I haven't used it yet. Enough light for to see the particles and some sort of loupe and steady hands required.
http://www.lenspen.com/?cPath=_1&products_id=SK-2-A&tpid=323
 BopBill's gear list:BopBill's gear list
Canon EOS M Samsung NX 30mm F2 Pancake Samsung NX 20mm F2.8 Pancake Samsung NX 18-200mm F3.5-6.3 ED OIS Samyang 8mm F2.8 UMC Fisheye +4 more
Kaziklu Senior Member • Posts: 1,301
mordor_74 wrote:
Hi,
Thank you all
I use a blower first and then swabs as has been suggested. I had to clean my sensor when I was shooting the falls because I made the mistake of using a non weather sealed lens.. and changed lens even though I thought it wasn't too bad.. left it pretty bad.
Just take your time and be patient with the cleaning and it works fairly well. You shouldn't need much pressure. The swabs usually come with a cleaning solution. I actually keep a couple in my bag with a small thing of solution, just in case.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
OP mordor_74 Contributing Member • Posts: 622
I bought a cheap kit to start with when i started removing the dust with the swabs i found a lot of dust behind the metal frame that is around the glass in front of the sensor. It think that this is a side effect of the blower. Fortunately there was a stick with an adesive material in the kit. I moved the dust to the center of the sensor and removed with the adesive. I did all the operation very slowly, it tooks me over 2 hours, but the sensor is now perfectly clean and most important thing now i know how to do it by myself!
There are a lot of things that i learned after i switch to samsung and this is another, very important one!
PS: I found my self very comfortable with the sticker method. What i really need is a magnifier with led lights to help the process!
It may depend on the way the blower is used. I hold it upside down and blow from a distance. I then slowly swabbed as well. took me about 45 minutes.
What ever method works for you though.. I don't think there is a right or wrong way.. (well there is a wrong way but I don't think either of us are doing the wrong way )
nx200USER1 Senior Member • Posts: 1,097
Whilst doing research before I started cleaning the sensor on my nx200, I was surprised to find out that some cleaning solutions are not reccommended for certain camera sensors. I was safe with the nx200, however some sensors have a special coating/filter that can be damaged if using a strong/incorrect solvent cleaning solution.
If dust gets in the sensor chamber and finally resides on your sensor due to electromagnetic attraction (static electricity), removing the dust particle as early as possible is reccommended employing the in built camera sensor cleaning method or using a blower. If the dust is allowed to remain on the sensor for a prolonged period of time, temperature and humidity fluctuations bond the dust particle to the sensor as moisture from humidy accumulates. This then requires a solution cleaning approach.
Particulate matter on the sensor is easily observed when the aperture setting is at f22 and a photo of sunny blue sky or strong lighting conditions indoors on white paper. Everything is revealed.
I tried this Sensorklear II by Lenspen. I do not recomment it. I had similar issues as this guy had:
http://www.dyxum.com/dforum/aargh-stay-clear-of-lenspens-sensorklear-ii_topic91515.html
lamer01 Junior Member • Posts: 48
I just cleaned my NX1. I made the mistake of blowing on it to get rid of some dust and I caused a dozen more spit particles to stick to the sensor. I ordered the blower and the APS-C cleaning wands with the solution. The blower did get rid of some things but when I did 2 passes with the cleaning wands (3 drops of fluid on each), the sensor got completely clean. No more spots.
cookedraw
cookedraw Senior Member • Posts: 1,970
Lens pen, blower and glass wipes for glasses worked good for me. The sensor is covered in glass so avoid pressure and only use clean stuff. I cleaned both ends of the lens and the mount too to remove any dust from the inside, and it is perfect since.
The sensor is covered by glass so use common sense and make sure you do not scratch sand on it, glass is pretty strong but sand is stronger and can easy scratch it.
check if it is clean by out of focus shots on the sky and any dust will be easy spotted.
I did spray water in the air above the table first to make dust in air fall down, use a clean environment.
