What FL would you choose for outdoor family portraits?
Started Nov 24, 2015 | Polls
diness Veteran Member • Posts: 3,758
Hey all,
What focal length would you choose for outdoor family photos (4-6 people) most often (obviously you would potentially use multiple, but we're talking most frequently here) and why?  I have used my 85mm some for outdoor family photos, but I find the working distance to be a little too much, whereas the 85mm is pretty perfect for just one person.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
POLL
35mm
18.8% 3  votes
50mm
56.3% 9  votes
85mm
12.5% 2  votes
Other (please specify)
12.5% 2  votes
  Show results
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: What FL would you choose for outdoor family portraits?
As you say, an 85mm might be a little long for family portraits, especially if you use the self-timer and need to scamper into position! This is one of the few times where I would recommend a 50mm.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
BAK Forum Pro • Posts: 26,020
I'd probably start by thinking about how I would like the shot to look.
I'd probably start by thinking about how I would like the portrait to look.
Would I like the 4 - 6 people side by side, standing by the fence, leaning on the top rail, with the shorter family members peeking between the rails?
That's pretty wide; a horizontal shot.
Or would I like grandma and grandpa sitting side by each on a park bench. Son and daughter in law standing behind the bench. Two grandchildren sitting on grandparents laps.
That's pretty narrow; a vertical shot.
Or, perhaps, there are family members hanging upside down from a tree branch.
Before you pick a lens, or the focal length of a zoom, think like a real photographer.
What's the shot you want?
What equipment do you have, or can you borrow, that lets you get the shot?
And most good photographers have several ideas, although Karsh seemed to nail a lot of shots with one pose and a couple of sheets of film.
So what are the other shots you want?
An 18-55mm Canon kit lens, or, a newer 18 - 135mm Canon kit lens, are wonderful family portrait lenses because they match a wide range of ideas, visions and concepts.
BAK
Last two I shot
The last family portraits I shot were two sessions, both of two people, or two people and a dog.
Shot on a Fuji X-30, which has a lens marked in 35mm full frame focal lengths, and the shots were between 35mm and 100mm.
In one session, very impatient subject so whole session was about two minutes; second session had a man restricted to a chair, limiting poses.
BAK
OP diness Veteran Member • Posts: 3,758
Re: I'd probably start by thinking about how I would like the shot to look.
BAK
Lots of good ideas, thanks.  I should have specified full frame and I do have a 24-105 that I use often taking pictures of families.  Biggest issue is that it's at it's sharpest at more like f5.6, and I would probably prefer to have the shots taken in the f2.8 to f4.5 range if possible.  So I'm thinking I will use that lens as the zoom, have the 85mm handy and also another prime.
sillette Regular Member • Posts: 381
Unless you are intending an avant garde, creative approach, the 50mm is perfect. Should be free of distortion, sharp and able to offer reasonable out of focus.
Portrait, wedding and fashion  photographers have relied on "standard" focal length lenses for years, because they do the job.
(unknown member) Veteran Member • Posts: 9,509
diness wrote:
Hey all,
40 2.8 STM for small groups and 50 and 85 for individuals.
Andy Blanchard Senior Member • Posts: 1,349
This would be my first thought too. It's a family group, so the typical approach is to go for a tighter group to indicate "togetherness" which brings the required field of view down a bit, e.g. parents at the back, kids at the front. I like nice bokeh as well, so probably of the options given 85mm would probably be closest to the mark in practice, but depending on the background and available working distance I'd be considering anything from 50mm to 100mm+ as a starting point.
Andy
jayboo Senior Member • Posts: 2,366
Generally for that I would just stick with my 24-70 2.8, as it sounds like you are talking informal style shots, family get togethers etc, always find the zoom works well for those situations.
 jayboo's gear list:jayboo's gear list
Leica CL Canon EOS R6 Leica M10-R Canon EOS R7 Leica Elmar-M 24mm f/3.8 ASPH +11 more
brightcolours Forum Pro • Posts: 15,885
35mm or wider
And place the more corpulent family members on the sides, so they appear extra fat due to the wide angle stretching in the borders. That will give them incentive to change their unhealthy eating pattern.
Keith Z Leonard Veteran Member • Posts: 6,134
It depends on a lot of factors, honestly.  I voted 50mm and I stand by it being my most often used focal length for these types of things.  I have shot 135 f2 wide open for one before, it all just depends upon the look you want to get and the room you have available.  I've shot 35mm for some as well, but I wouldn't generally want to go wider than that, for sure.
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM Canon EOS 400D +16 more
Rock and Rollei Senior Member • Posts: 2,916
BAK
With groups, unless thy're all in a line (which is unlikely to be that interesting!) you'll need more DOF than you'll get at f4.5 anyway, so you probably already have the ideal lens in your 24-105 - especially as you really don't need great sharpness for portraits unless you're using perfect models with perfect make-up. Just stay clear of the edges at 24mm wide open and you'll be fine.
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
