35mm f1.4L mk2, way better minimum focusing distance in practice
Started Nov 22, 2015 | Discussions
AdamWCohenVisuals Forum Member • Posts: 66
The manual states that the minimum focusing distance of this lens is 0.92 feet, which works out to approximately 11 inches.
I've been pleasantly surprised to learn that this is not the case in practice. I can't say that my experience is typical, obviously, but I'm consistently achieving focus at about 5 inches, which is dramatically different/better.
I'm not a professional lens-tester, but I know how to read a measuring tape.
Focusing about 5 inches away with the Canon 35mm f1.4L mk2
Focusing on my ring, a little under 5 inches away.
Focusing on ring at Canon's stipulated minimum focusing distance of ~11 inches.
So, that's a huge difference in terms of aesthetic possibilities. I called up Canon Professional Services and they suggested that this might be caused by the lens filter I'm using, but I've since reshot without the filter on and I'm getting the same results.
This is so far outside of Canon's mfd spec that it blows my mind. I was already loving the new lens, but this is a lovely surprise. Obviously, ymmv, but if you've got the lens, test this capability out!
"If there, do there." -my lovely wife
http://adamwcohenphotography.com
 AdamWCohenVisuals's gear list:AdamWCohenVisuals's gear list
Canon EOS 5D Mark IV Canon EOS R5 Canon EF 70-200mm F2.8L IS II USM Canon EF 35mm F1.4L II USM Canon EF 16-35mm F2.8L III USM +9 more
Lee Jay Forum Pro • Posts: 56,673
Probably not
The minimum focusing distance is measured from the front of the *sensor*, not from the front of the lens.
I'm going to go out on a limb and predict that, when you measure the distance from the front of your sensor (estimate it) to the front of the lens, you'll get about 6 inches.
Lee Jay
 Lee Jay's gear list:Lee Jay's gear list
Canon PowerShot SX50 HS Canon EOS 7D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III +10 more
OP AdamWCohenVisuals Forum Member • Posts: 66
Re: Probably not
I actually asked the Canon rep to clarify what mfd means and he was unequivocal about it being from the front of the lens and not the sensor.
Still, it's impossible to ignore that your suggestion makes more sense than my copy of this lens having superpowers.
Re: Probably not
I believe you proved the rep wrong.
Lee Jay
salamander1 Senior Member • Posts: 1,427
Re: Probably not
unequivocal? the guy was ignorant, didn't know what he was talking about. canon reps are not geniuses. distance is always measured from the sensor - always. that's precisely the reason  why you're getting these "supernatural" 6 inches focusing distance from the front of the lens.
Man learns what MFD is on the Internets
Lee Jay
Hey Lee, can we just keep this between the two of us? I'd really appreciate it.
Gah.
My bad
As much as I'd love to dump this brain fart entirely on the doorstep of the Canon rep, I'm the one who enthusiastically believed his incredulity about the "extraordinary" performance of my copy of this lens and eschewed thinking clearly about it before posting here.
Sorry for wasting your time, forum people.
MFD is measured from the sensor. Period. And humiliation is measured from here to infinity and beyond.
Re: My bad
no. you have a right to make an honest human mistake, after all we all love and adore our lenses,  whereas a canon rep should tell you right from the get go from where is distance  measured. it's his job.
