Minolta Vectis V to Sony E Monster adapter Review .
Started Nov 22, 2015 | Discussions
neilt3
neilt3 Veteran Member • Posts: 3,008
I've had the Minolta Vectis APS film SLR system for a number of years , Both the S1 and S100 film and V-mount DiMage RD-3000 DSLR from 1999 .
The film cameras are a nice lightweight rain proof system , which is why I bought it . I have been using them for over ten years alongside my A-mount film and digital cameras .
The system was released in 1996 and was a bit like the Minolta film equivalent to Sony's E-mount digital alternative to A-mount .
I think David Kilpatrik on Photoclubalpha was the first to try and utilise these lenses on a digital camera with more than 3 megapixels (!) though it involved duck tape.
I've started dismantling some of my spare Vectis lenses to see about providing power to them to make use , but hadn't got very far when this thread popped up .
Intrigued , I contacted the maker and three months later it arrived .
First of all , this adapter powers up the lens so that lenses that allow manual focus can be focussed manually .
two of the Vectis lenses don't allow this so cannot be used .
**This adapter does not support auto focus .**
The adapter enables aperture control the same as if a native E-mount lens is fitted , ie , via the cameras control wheel .
All exposure modes work as normal , P,A,S,M . Auto ISO works as intended .
The adapter reports the focal length to the camera , not 100% accurate as the 400mm reflex is reported as 405mm , The 50mm Macro reports 51mm and the 17mm is reported as 18mm .
Likewise the 22-80mm zoom is reported as 21mm .
Whether this is a quirk of the adapter or the true focal length of the lens , I don't know . This makes no difference in use , if your camera has image stabilisation , it will work automatically ,as normal . a mm or two out wont cause a problem.
Because the camera knows the focal length of the lens in use / set to in the case of a zoom , in A mode , with auto ISO , it will select a shutter speed and ISO to reduce camera shake as normal , the same as any A or E mount camera .
Like the Canon EOS lens to Sony E-mount adapter , there are a few minor issues to take into mind .For normal everyday use this adapter is perfect for my needs , doing everything I want it to do ( A/F would have been nice though !) .
Build quality is very good . This hasn't just been knocked up in someone's shed , it is very professionally made .
The maker had only had another six made , hopefully he will have more made as these will sell quickly .
A couple of people have contacted me via Dyxum and another via Flickr .
So , just a few things to be aware of ;
1;this adapter is not compatible with the original NEX 3 or 5 .
All later cameras seem to be supported .
2;On some cameras , if it is set to continuous advance , or a rapid succession of single shots are taken , the camera / adapter can freeze . This might only be an issue on higher end cameras .
On my NEX 7 and John's a7 this happened after between 5 and 8 shots . On an a3000 and an NEX 3n , you could shoot without any problem until the cameras buffer was full .
This made no difference whether the camera was set to JPEG or RAW .
In normal use this does not effect me (YMMV).
3;on the NEX 7 , if the onboard flash is raised , when a shot is taken on about 3 out of 5 shots the camera would freeze .
When using the HVL-F20AM flash unit , it improved to only 1 out of 10 shots would result in the camera freezing .
With the a3000 , there was no issues with using either on board flash or a separate unit .
As John does not have a separate flash , he is unable to test on the a7 .
So between us , these are the only three issues found .
Non of these issues are a concern to me , as it enables me to use my lenses in a way that meets my needs .
Although the adapter was expensive , having the full range of lenses has made it worth while .
The Lenses ?
I'm very pleased with the Vectis lenses , almost all my A-mount lenses are Minolta , from a 16mm fisheye to a 300mm f/4 plus a load of zooms , plus Minolta SR lenses .
So I'm well aware of the quality of Minolta lenses .
I've used the Vectis lenses on the S1 and RD-3000 for years too , and have always been happy , though never enlarged too much . APS film had it's limitations due to size , but I used the cameras in the rain without a second thought .
Minolta put quite a bit of effort into making these lenses to resolve to quite high degree to make up for that .
So it stands to reason if the lenses for the larger 35mm film are good for APS-C , the APS-H lenses are quite at home .
I have to admit that I was a bit concerned that they might not be up to it , considering how much I paid for the adapter.
I have multiple examples of all the lenses so I will need to find which are the best ones , I've found out of my two 17mm ones , one could not reach infinity focus , but the other went beyond it , as per design .
I think the other needs a shim taking out , surprised I never picked up on this before though . That's what magnified live view , focus peaking , 24 megapixel , and pixel peeping on a big screen does though !
I need to compare my other lenses now though .
On my holiday where I used them as my main kit I tested them out in normal use , rather than test charts and brick walls , I will be interested to try them on a full frame E-mount with A/S .
I found the best camera to use the 400mm reflex on was the a3000 due to the ergonomics , despite the poor EVF , the majority of the shooting was with the NEX 7 .
After using the EVF on the a77ii for a while , I found the NEX 7 a bit more awkward , for focus peaking , if you are focusing from near to away , it was fairly reliable .
If focusing from infinity towards you , quite severe back focus occurred , still more testing is needed to work out how best to use it.
The following links are to the sample pictures on my Flickr site .
I will be putting reviews of the Vectis lenses on the adapted lenses forum when time allows .
In the meantime , all samples have been set up in separate albums for each lens . I have multiple copies of each lens , so still need to test them to use the best .
All shots are from normal use , no test charts or brick walls !
I might be more critical on the final selection .
Minolta Vectis V-Sony E MONSTER Adapter on Flickr
Minolta Vectis 17mm f/3.5 RD
Minolta Vectis 50mm f/3.5 Macro
Minolta Vectis 400mm f/8 Reflex
Minolta Vectis 22-80mm f/4-5.6
Minolta Vectis 56-170mm f/4.5-5.6
Minolta Vectis 80-240mm f/4.5-5.6 APO
More photos will be added as I process them and take more .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Sony Alpha NEX-7
neilt3
OP neilt3 Veteran Member • Posts: 3,008
Re: Minolta Vectis V to Sony E Monster adapter Review .
Just a shot of the Vectis line up .
Both the Black and Champaign Vectis S1's , a couple of DiMage RD-3000's , and a couple of lenses to test out along with some backup lenses !
Apart from the MONSTER Adapter also mounted on the NEX 7 there is an even rarer lens adapter .
Some say it doesn't exist , the Unicorns horn of all adapters , the Minolta A-V adapter (MC-V1 )to mount Sony / Minolta A-Mount lenses on the Vectis V-mount cameras .
The Vectis line up receives 19th year update . From APS film , to 3 megapixel then the 24 megapixel 15 years later !
Two rarity's together !
The MONSTER Adapter with even more elusive Minolta MC-V1 A-mount to V-mount adapter .
A few shots of the Vectis 22-80mm lens on a NEX 7 via the Monster adapter .
Here's a shot of the 400mm f/8 Reflex on a Sony a3000 .
And just a teaser with a Sony 16-50mm f/2.8 SSM lens on a Black Minolta Vectis S1 .
Manual focus only , and aperture controlled via the lever at the top .
The Monster adapter is a bit more advanced !
Ken Sky Regular Member • Posts: 422
I'd certainly be interested in this adapter. Can you say what you paid for it and the maker's contact info. ?
 Ken Sky's gear list:Ken Sky's gear list
Sony RX100 Sony Alpha DSLR-A900 Sony Alpha NEX-7 Sony a6000 Sony a7R IV +10 more
neilt3
Hi Ken .
The adapter costs U.S $250 delivered by EMS .
Delivery to the U.K took just a few days .
If your country charges TAX on imports , you will have to pay that as well .
Imports to the U.K have an extra 20% VAT added on plus a £16 handling charge at customs .
If you are interested in one , P.M me and I will forward on his email address .
Good luck in getting one , he has only had a few made .
I've no idea if he will have any more made , there is quite a bit of interest in them though , so it's possible .
Regards , Neil .
Thomas KP Lee
Thomas KP Lee Contributing Member • Posts: 555
I have 13 Vectis lenses and two RD3000 camera bodies and would love to buy this adapter for making use of these lenses on my A6000 and A7rII bodies. Please see if I can be linked to the maker to enable me to buy the adapter.
Best
Thomas
 Thomas KP Lee's gear list:Thomas KP Lee's gear list
Canon EOS-1D X Sony Alpha a99 Canon EOS 70D Sony a7R Sony a6000 +10 more
neilt3
Hi Thomas , I'm not at home at the the moment but I will P.M you with Johns email across later .
As per my reply to Ken , if anyone wants Johns email address to organise buying one one , they should P.M me and I will forward it on .
The price is also in that above reply .
I have no connection with John other than being a very happy buyer of this adapter .
I don't visit other forums much apart from this Minolta one on Dpreview , and Dyxum , so if anyone wants to contact me , P.M me direct , not posting a reply in a thread .
Thanks .
Regards , Neil .
https://www.flickr.com/photos/neilt3/sets
neilt3
Minolta Vectis V to Sony E Monster adapter , now with Auto Focus
Monster adapter have come up with a new LA-VE2 adapter for using all Minolta vectis lenses and now support Full AF on selected bodies .
Place your orders ! I put mine in for £155 .
The manual focus one I got in 2015 was £250 , so now with AF , a bargain !
Now available on Indiegogo , be aware it's a crowdfunding site , so your not buying something from a shop .
Do your own homework .
https://www.indiegogo.com/projects/la-ve2-minolta-v-mount-to-sony-e-mount-af-adapter/x/30254552#/
Thomas KP Lee
Re: Minolta Vectis V to Sony E Monster adapter , now with Auto Focus
Order placed for the LA-VE2 ! Looking forwards for this adapter on my Sony A1
neilt3
I'm looking forward to receiving mine .
It's been a long wait for AF , the lenses will be getting more use when I get it .
Still waiting to see how my 25-150mm behaves .
Just got mine as well but weather has not cooperated to give it a good trial but AF works better on A7R4 than A6000.
neilt3
Mine arrived on the 19th , but I'm having a couple if problems with some lenses .
The 400mm reflex and 17mm sometimes lock up with the purple square "I can't focus" thing and the camera has to be switched off to reset .
The 25-150mm , which I really want to work , doesn't .
I've three copies of the 400mm to try and two of the 17mm plus a few more 25-150mm lenses , so it could just be there 25 year old lenses that haven't had much use .
However, someone on Dyxum.com has also been having this problem and had the idea of setting the camera to "initialize" .
And it seems to have improved it .
See here ; https://www.dyxum.com/dforum/mirror-lenses-2_topic140930_page7.html
The postman's just dropped off a used a6600 that I've bought , so I'm about to try it on that .
neilt3
Try the "Settings -> Reset -> Initialize" that "Anthills" on Dyxum suggested .
It made a massive difference with my adapter .
The 25-150 was coming up f/90 when first mounted and camera switched on , AF first would move then just lock up with a purple square on both the a7Riv and a6600 .
Since I've "initialised" it the aperture is correct , AF works a treat . Better on the a6600 than the a7Riv , but very satisfactory . In low light at 150mm ( max aperture is f/6.3 here ) it's slower to focus but gets there in the end .
17mm is working fine most of the time , but I need to check it out more in good light .
The 22-80mm , 28-56mm , 56-170mm and 80-240mm all work great . I'm pleasantly surprised with the their performance .
The 50 mm macro lens was whizzing in AF missing everything , but I've put on one of my other copies and that one works great .
Finally the 400mm Reflex .
I have three copies .
The one I've been using on the original Vectis to E-mount is just hunting .
I've figured out why .
The internal baffle on this one has no flocking and is causing a rainbow flare effect , almost as if the rear element of a lens has condensation on it .
This seems to be effecting the AF as light is scattered .
I hope to remedy this by sanding the glaze off it .
(EDIT ; I've just swapped the baffle for the one out of the "macro" reflex , so should work fine tomorrow)
My Second copy needed the front elements taking out for cleaning , which I did years ago , unfortunately when it was reassembled after putting the second lens in that has the secondary mirror on , you ten put the first element back in and as this was screwed in , it turned the second one as well .
This lost infinity focus , in fact it turned it more into a macro lens , focussing no more than 15 feet away . Sharp , but not a lot of use !
I thought I'd stripped it down again to redo it , but clearly not !
A job for another day .
My third copy needs cleaning up as there's signs of fungus under the front element or on the second one back .
I'll count the turns as I take them out to reinsert both these and on the other correctly .
I'll use a bit of thread lock on the inner one and allow it to set before putting in the outer element .
Despite the fungus , AF works grate and it seems a nice sharp lens .
