Canon SX40 HS Photo printing problem
Started Nov 18, 2015 | Questions
bronco7923 New Member • Posts: 1
Hello,
New to the forum but a long time SX40 user and have recently run into an issue that has me completely dumbfounded.  Simply put, when I print pictures at Walmart or Walgreens or the like, the photos are zoomed in and parts of the picture are cut off.  It does not matter if I use the upload tool online or I take the SD card directly into the store, it is the same effect.  Is there a setting that would cause this ?  Thanks for your help!
bronco7923
Canon PowerShot SX40 HS
Britney Elvis Veteran Member • Posts: 5,382
Re: Canon SX40 HS Photo printing problem
bronco7923 wrote:
Hello,
bronco7923
Happens way to often with me also... I spend the time to get the exact frame I want and the pics they print crop in even farther...
I seldom print at the costco/Walmart/Walgreens anymore and if I do I put a white border on the photo to keep the machine from deciding to crop
gus
"It is not necessary to understand things in order to argue about them."
~~ Pierre Beaumarchais~~
