Kalamaki wrote:
I have a Lumix G6 & recently got hold of a Sigma 30mm. The shots from the Sigma highlighted the shortcomings of the 14-42 Kit Lens. I used the 14-42 with a Metz 36 AF-5, at my daughter's birthday party, on Saturday. Generally disappointing shots. The flash seemed to make things worse, rather than better. I tried it with the diffuser, I tried bouncing etc.
Just wondering what I should upgrade the 14-42 too. I don't need a long zoom, just something with a bit of flexibility.
Flash-wise, I'm now not convinced that I actually need it, as the shots without the flash, were much nicer (1 or 2 a little blurred - obviously) & I'm not a pro/semi-pro.
I mostly take shots outdoors - family, scenery, street. Occasionally indoors - parties.
Perhaps I should sell the 30mm & 14-42mm & get the Panasonic Leica 25mm!
you help & advice would be appreciated.
Cheers
Reading through your responses, it looks like the most cost effective option is to get a bright prime to switch off with your 14-42, depending on the conditions. I have the PL25, and while it's a great lens, it's also pretty pricey compared to its younger competition (Oly 25, Panny 25/1.7), while not being significantly brighter. It's also a bit softer at f/1.4 than it is at f/1.8 or f/2, so I end up sitting at f/1.6 or f/1.8 anyway. The lens renders beautifully though, so if your heart is set on it, I'd go for it.
Indoors during daytime you can probably get away with f/2, ISO 1600, and 1/60s most of the time, negating the need for flash. The benefit of ramping up ISO is that not only do you have the subject's face properly exposed, but your background will likely be brighter as well, minimizing the 'pictures taken in a cave' effect that can happen with a flash.
A flash is definitely much better at freezing motion, so if your kids are very hyper from all of that birthday cake, you might still want to keep that Metz with you.
If candids of kids running around is what you're after, the 14-54 II probably won't work for you, and neither would the Panny 20mm. Stories of these lenses being impossibly slow to focus are overblown, but they're definitely slow enough that by the time you've focused, the kid has already moved. Don't get me wrong, my 14-54 II is still my 'serious' lens, it's just not my candid lens.
If you like the 20mm perspective, then you might best be served by the Oly 17mm, which is bright and is insanely fast focusing. The Oly 25mm is cheaper and sharper, and carries the same advantages as the 17mm, but with a tighter crop. I haven't seen images or test results, but it looks like Panny's 25mm/1.7 offers the same benefits as the Oly, but with an even cheaper price. I'd say you couldn't go wrong with any of them, really.
Hope this helps.
