Help please Canon 400D
Started Nov 15, 2015 | Questions
Dazzabee New Member • Posts: 1
Hi
I have a Canon 400D which I use as a second back up Camera. I had not used it for a while but when I went to use it I put the battery in and the green light( power button) remained lit up even when I switched the power off. I have fully charged the battery and also changed the secondary battery cr2016.
Help please
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X)
WilbaW
WilbaW Forum Pro • Posts: 11,643
Re: Help please Canon 400D
The off switch doesn't open the circuit from the battery to the camera, it just puts the camera into a sleep mode in which the buttons don't cause it to wake up. I guess there is a defect with your off switch 'cos it doesn't even do that. Safe to assume you've tried taking both batteries out, flicked the switch, put the batteries back in...?
Maybe applying some isopropyl alcohol around the switch might help - that often does for shutter buttons the get a but gunky.
Check out the unofficial Rebel Talk FAQ.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
