New App for Sony Cameras: Min Shutter Speed
Started Nov 14, 2015 | Discussions
Piafinho Forum Member • Posts: 91
So,
It seems that it is in fact possible to define a Minimum Shutter Speed in Sony cameras.
There is a new app in http://psafs.pixub.com that allows Sony users to set it.
It is not perfect as:
- you can only adjust it via the app itself
- The setting goes away once you turn the camera off.
But, it is possible to do it
By the way, did any of you Full Frame Users had the change to try out the Bracket App?
If so, do you know if it does save the files in Uncompressed/14 bit mode?
 Piafinho's gear list:Piafinho's gear list
Sony a6000 Sony a6400 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +3 more
ninjapimp Contributing Member • Posts: 524
Re: New App for Sony Cameras: Min Shutter Speed
ya, good luck with that
- I cannot guaranty that there are no side effects of using the applications.
totally flaky website...why not just put camera in S mode so you can control speed, no need for an app.
this sounds like a really bad idea it might brick your camera.
 ninjapimp's gear list:ninjapimp's gear list
Sony a7R Nikon D7000 Nikon D800 Sony a7R II Nikon AF-S Nikkor 14-24mm f/2.8G ED +13 more
Tristimulus Veteran Member • Posts: 9,454
Piafinho wrote:
So,
If the idea is to use the camera for photography then using this app sounds like taking five steps backwards. Not exactly a seamless procedure.
Not exactly the dream app made for me...
kelstertx Veteran Member • Posts: 5,292
Piafinho wrote:
So,
This is interesting.  I hadn't thought of using an app.
And if this site can come up with one by reverse engineering, it seems like it would be trivial for Sony to come up with an official app in the app store...
-Kelly
 kelstertx's gear list:kelstertx's gear list
Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +4 more
OP Piafinho Forum Member • Posts: 91
Trollmannx wrote:
Piafinho wrote:
So,
By default the camera will always default to a min shutter that is too low if we have moving subjects. If the light conditions can change quite fast between each shot, it is hard to get the right exposure using Manual Mode or Shutter Priority.
For sure that on > 99% of my shots I wouldn't use of it.  On the other hand I had a few times where I'm sure I would have enabled it I had the chance.
But maybe that is me and my lousy skills. I must confess I'm not a big fan of shutter priority.
These are Android Apps. I expect them to have the same chance of brick the camera as installing an app on a Android mobile. Or at least, the same as the Sony Apps that are available.
cheng li Forum Member • Posts: 79
Would be nice if there is something like min shutterspeed = 1/(focus length lens X parameter setting).
VLreviews
VLreviews Regular Member • Posts: 248
OK, so I quickly tried this app on an A7II. Summary: It works as advertised!
In Detail: You install it using Internet Explorer (Firefox does not work) and the original Sony Play Memories App Loader. After installing, you can start the app right away. It allows you to clear or set the desired min. shutter speed between 1/15 and 1/4000 of a second by using any of the three wheels on the camera. This value is then the absolute minimum shutter speed - not a threshold. If you set it to 1/15 s, the camera still tries to get the shutter speed down to the regular threshold (which pedends on the lens) as usual. If it cannot get to the threshold, it falls below it until it hits the set minimum. If this is still not enough, it will underexpose the image. You can't even go below your self chosen minimum in M or S mode - which is logical, but may not be the desired reaction. If you shut down the camera, the set minimum is lost and you have to restart the app.
All in all, that's a very nice first step in custom app development and, for me, a pretty useful feature.
http://vintagelensreviews.com/
Reviews of vintage Minolta SR mount lenses and more
Zenjitsuman Contributing Member • Posts: 793
In some cameras for auto ISO you set the Max ISO and the camera sets the 1 over shutter speed for you as the minimum shutter speed.  So for example a 50mm lens, camera sets 1/50 th sec.
A 200mm lens camera sets `1/200 th sec.  and Auto ISO can move sensitivity from base ISO to max ISO you set say ISO 6400.
Does this app allow auto ISO and lens definitions?
 Zenjitsuman's gear list:Zenjitsuman's gear list
Carl Zeiss Biogon T* 2,8/25 ZM Voigtlander 15mm F4.5 Super Wide Heliar Voigtlander 21mm F1.8 Ultron
Like mentioned above, the app set an absolute minimum. But the camera continue to work like before in regards to expected base shutter speed and AUTO ISO range.
Scenario 1:
Let's say that with 1/50 you would get a ISO 3200. But you might get blur with it. So you want to set something higher than that.
If you set the minimum to 1/100 then AUTO ISO would go up to 6400.
However if you set it to 1/200, then AUTO ISO would need to go up to 12800. But it can't as you set a maximum of 6400. So it will take the picture at 1/200, ISO 6400 with -1EV exposure.
Scenario 2:
Let's say that with 1/50 you would need a ISO 12800. Since you have a max AUTO ISO of 3200 the camera will set itself to 3200 and use 1/13 instead of the expected 1/50th of the lens.
That can lead to blur so you, taking in account the situation and maybe IBIS you wanted to force an absolute minimum of 1/25. To do so you set the minimum shutter speed to 1/25.
The camera now cannot drop below 1/25. So instead of 1/13 it will expose with 1/25 and ISO 3200. Leading to a -1 EV.
Robgo2 Veteran Member • Posts: 5,467
Scenario 1:
Scenario 2:
And how is this preferable to switching to Shutter Priority mode and setting the shutter speed where you want it? Though such a technique requires some forethought, it is still possible to do photography in a way that is not fully automatic. I realize that this may be a hard concept for many to accept, but it is true nonetheless.
Rob
Scenario 1:
Scenario 2:
Rob
I recall seeing in the past this same discussion over and over: Min Shutter Speed vs Shutter Priority. Don't know who have won it
For sure there are far more experience guys that can share there thoughts. But I can give you an example on what happened to me when I wanted this feature on my camera:
I want to do a close up with isolation of a moving subject. So wanted an aperture wide open and some minimum shutter speed at least of 1/250.
Shutter Priority = 1/250 and there I go.
However, the subject keeps moves from shade to sun. So, to keep aperture open, I constantly needed to change shutter speed from 1/250 to 1/2000 or something like that..
So I spent my time trying to adjust the exposure than getting the right shot.
If I used aperture mode and set a minimum shutter speed of 1/250 I keep the same settings when my subject moves from shade to sun. So I just focus on catching the right moment.
I only remember 2 times I really wanted to use it. but on those times I didn't manage to take a single picture worthwhile.
But I admit my technic is far from good. So all could be just lack of practice
JunzInc Regular Member • Posts: 472
Scenario 1:
Scenario 2:
Rob
I think minimum shutter speed is very useful for me when for e.g I am taking a picture of my active Toddler, and I want to use F2 always. I have a feeling that I need atleast 1/500 to freeze his motion.
So If I am in Shutter Priority and I put 1/250, depending on the available light the Camera may decide to use F4 or F5.6 because that is enough to give the correct exposure but that is not what I wanted to get the required background separation. So what I can do is to switch to M Mode and Put F2 and Shutter Speed 1/250 on Auto ISO and now depending on the light the Camera may Overexpose because even at ISO 100 it may be too bright. So I may have to keep adjusting my Shutter Speed. The best solution here for me is to set a minimum Shutter speed in Aperture Priority. So the Camera will always stay at F2 and will always use Shutter speeds > 1/250 and knows to increase the ISO if need be to remain at 1/250
Regards
 JunzInc's gear list:JunzInc's gear list
Olympus E-M1 Sony a6000 Olympus 12-40mm F2.8 Pro Adobe Photoshop Lightroom 4 Corel PaintShop Pro X4
AlphaPhotography
AlphaPhotography Senior Member • Posts: 1,974
Thank you for posting this. I have been waiting for this functionality for almost a year now. While it is not a perfect solution, I am very happy with its performance in the brief test I just did. I will likely be using this frequently.
www.SonyArtisan.com
www.flickr.com/photos/sonyartisan/
Scenario 1:
Scenario 2:
Rob
Regards
I don't want to be misunderstood on this subject. I very much would like for Sony to issue a firmware update that would allow one to set a minimum shutter speed. My suggestion for using shutter priority was in response to this new app that would seem to be more trouble than it is worth. But it is true that if you are shooting in M mode, you have to be more alert and involved in getting the settings on your camera right. I do not see that as a huge burden, but others might.
Rob
Does it slow way down?
All the apps I've tried make the camera horribly sluggish.  Is this that same kind of app that slows everything down, or is it a different kind of animal where the camera feels normal, except for the new invisible walls keeping the shutter speed up?
-Kelly
VLreviews
Re: Does it slow way down?
As far as I can tell, the camera doesn't slow down. I don't notice at all when the app is running.
How did you even install it?
How did you even get it installed? With IE8, I get errors on the page and can't get camera info. The details of the error refer to a .js piece that isn't available - the url is missing. Looks like Sony dismantled parts of the site. Prior to trying this, I downloaded the Sony plug-in from the "USB" link on the page referenced on the first post.
lattesweden
lattesweden Veteran Member • Posts: 5,124
On A7RII: Camera Menu #5: ISO Auto Min SS.
Best regards
/Anders
I'm from Sweden, but my pictures are in all languages: http://500px.com/anderslattermann
Rich O Regular Member • Posts: 421
Nice will give it a try.
How about a manual lens app.  One that a user can select a predefined set of lens and select the aperture and focal length using the dials and convince the camera that the lens is attached and relay that information to the attached flash.
I've been using the lens compensation app for this feature, but it has issues:
1. its slow
2 . You can't dynamically select the aperture and focal length.  You have to go back into the menu and change the focal length and aperture in the lens profile.  Not so easy to do when your using a zoom lens.
3.  It doesn't relay the focal length to the flash.  As far as the camera know there is still no lens attached and the auto-zoom function of the flash fails, even though your telling the camera the focal length to use for steady shot
 Rich O's gear list:Rich O's gear list
Sony a7 II Sony FE 28-70mm F3.5-5.6 OSS +13 more
