Canon 70-200 f/4 IS image stabilisation quality
Started Nov 7, 2015 | Questions
markodarko
markodarko Regular Member • Posts: 198
Hi all,
I've owned the 70-200 f/2.8 IS II so I'm aware of its capabilities. I'm just wondering - is the IS on the f/4 as good and/or quiet as that of its bigger brother?
I know the f/4 IS is 5 years older than the 2.8 IS II so I presume that the 2.8's IS is a newer design(?), but my interest is to use it for video, not photos.
Those of you who own the f/4 IS, have you had any problems using it for video? I know that the 2.8 IS II was super smooth - and especially useful when on a tripod to cancel out any tiny shakes due to small tripod movement in windy conditions etc. Is the f/4 IS good for this too?
Thanks for your help,
Mark.
J A C S
J A C S Forum Pro • Posts: 20,544
Re: Canon 70-200 f/4 IS image stabilisation quality
markodarko wrote:
Hi all,
Never used it for video and I own the f/4 and have used the f/2.8II. The f/4 has a noisy (but very efficient) IS. I would say that the IS effect is at least as good as with the f/2.8 II but I can hear it all the time.
Abu Mahendra Veteran Member • Posts: 5,312
It is an honest four stops, but it is noisy. You can hear it wizz on and off.
>> I am already lovin' the Canon EF 35L II lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
markodarko
OP markodarko Regular Member • Posts: 198
Thanks for your prompt replies
Thank you J A C S and Abu for your quick replies. When you say that it's noisy, is it significantly noisier than the 2.8 II's IS?
Also, I notice that the f/4 doesn't come with a tripod collar as it's quite light compared to the 2.8 IS II, comparatively speaking, however, weight aside, it is still a long lens. Do you feel that it needs the (ridiculously priced) tripod collar to counter the length and improve stability (and lessen the strain on the camera mount) or is it fine as is for mounting on a tripod via the camera?
Thanks again,
Mark.
J A C S
Re: Thanks for your prompt replies
Yes. Mu guess would be that you will hear it in a video.
I bought that lens when I was shooting with a Rebel. Then I was convinced that I needed the collar and bought a less expensive version for another Canon lens but physically the same. I think that Canon is not selling those anymore. The lens felt front heavy on the Rebel and I was using the collar a lot. On my 5D2, I do not use it anymore. It feels stable enough. If I have it in my bag, I would still use it though.
markodarko
Thanks for your replies.
Just placed the order for the 70-200 so in a few days time I shall find out for myself about the noise level etc.
Thanks again,
Mark.
Mark1t Regular Member • Posts: 246
Is it actually like 4 stops? Wow. I was thinking of getting the non-is, but maybe I'll save a bit more then.
Dave Sparks Senior Member • Posts: 1,350
Thanks again,
Mark.
I got a collar for my 70-200 f/4 IS at 1/3 of Canon's ridiculous cost:
http://www.bhphotovideo.com/c/product/822976-REG/Vello_TC_AW_Tripod_Collar_A_Black.html
I wanted one for occasional use with a monopod for my 70D.  Fits and works great.
 Dave Sparks's gear list:Dave Sparks's gear list
Canon G7 X II Canon EOS 90D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM +18 more
markodarko
Thanks for the heads up. I did some searching and found an aluminium one with good reviews for less than £10(!). It's coming on a slow boat from China, but worth a punt at that price I'd say...
http://www.amazon.co.uk/gp/product/B00KS4W5WO?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
Mark.
MutantLabs Regular Member • Posts: 222
Thanks again,
Mark.
I've got an even cheaper one (€17), works just fine. But I don't use it much if at all, because the lens isn't that heavy.
www.flickr.com/mutantlabs
 MutantLabs's gear list:MutantLabs's gear list
Sony RX100 Canon G7 X II Canon EOS 6D Sony a6000 Canon 6D Mark II +10 more
Yes, it is noisier than the 70-200II. I've mounted it on a tripod sans collar, no problem. Collar, of course,  would be more stable.
Yes, honest, real-world four stops. 1/13 at 200mm gives quite acceptable results. Save. It is a great lens, a little pony workhorse.
stratobill Senior Member • Posts: 2,081
Mark.
The first time you use it take a look and make sure it's not scratching the lens especially when you rotate it. I had a cheapie that did that.
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
markodarko
stratobill wrote: The first time you use it take a look and make sure it's not scratching the lens especially when you rotate it. I had a cheapie that did that.
Will do, cheers. That is, when it arrives from China in around a month...!
Jestive New Member • Posts: 1
Thanks again,
Mark.
Mark, what was your conclusion after buying the lens? I've bought a second hand one and am trying to decide whether the IS is working as expected. Compared to the 2.8 II it has quite a significant wobble on it!
