Hoping for a 50mm equivalent EF-S small prime lens
Started Nov 7, 2015 | Discussions
Tze Hong Regular Member • Posts: 153
I'm personally looking forward to having a small and light prime lens around the 30mm focal length to give a 50mm FF equivalent. I've been using the EF-S 24mm STM with my 100D for several months and have gotten good results. However, at times it just feels a little too wide.
The 40mm STM and 50mm STM are a little too narrow for the street photography that I like.
Hopefully, I won't have to wait too long. Do you all think Canon have such a lens in the pipeline anytime soon?
PS: I have used the Sigma 30mm f1.4 for a while but feel that it's too heavy and bulky. Also it's focus seems to be inconsistent.
 Tze Hong's gear list:Tze Hong's gear list
Fujifilm FinePix X100 Fujifilm X100S Nikon Z5 Nikon Z 24-70mm F4 +4 more
Canon EF-S 24mm F2.8 STM Canon EOS Rebel SL1 (EOS 100D) Leica SL 50mm F1.4 Panasonic Lumix G Macro 30mm F2.8
Mark1t Regular Member • Posts: 246
Re: Hoping for a 50mm equivalent EF-S small prime lens
easy choice: 35mm f2 is. Its pretty cheap, and at f2.8 there is literally no difference between this and 35L.
Buchanan Senior Member • Posts: 1,124
I had been using my non-IS Canon 35/2. It paired nicely with my SL1 size and weight-wise and while not as good as the newer IS version it really worked quite well on the little camera. Eventually gave in and got the 24 pancake which isn't as close as to the 50 equivalent you desire but I like it. Hope they get you your 30 at some point.
 Buchanan's gear list:Buchanan's gear list
Canon PowerShot S95 Canon EOS 60D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 70D +15 more
arty H Senior Member • Posts: 1,546
I have used the older Canon 35F2 and the new 35F2IS on full frame and crop. They are just about perfect. The new lens has faster and quieter AF, but both lenses are sharp. The new lens has excellent flare resistance.
I have the older 35F2 sitting on my T2i right now. I recommend picking up the 35F2IS, unless you are willing to wait and hope that Canon comes out with an efs version.
thomascantwell Forum Member • Posts: 53
You can get full frame cameras for so cheap now, that you might as well go with the 50 stm on an original 5D (combo costs less than the 35 f2 is) or get a 6D for a little more. A 5D with the 50 stm would give you better quality than any lens on a 100D.
J A C S
J A C S Forum Pro • Posts: 20,544
Another option is M/M2/M3/M10 and the coming 35/1.8.
OP Tze Hong Regular Member • Posts: 153
Hi all, thanks for taking the time to reply.
All of the suggestions given are good and practical. It has provided me with many options. But I'm most inclined to the 35mm f2 non IS as it's the cheapest and most convenient option.
I've thought about the original 5D and 50mm STM option but that would increase the total mass of the setup by a few hundred grams. The 35mm f2 IS is quite expensive over here but I know it's a great lens.
The M3 seems greatly improved over the original EOS M but it's not readily available here.
kotmj Contributing Member • Posts: 571
The old non-IS 35/2 is not as good as the new lenses from Canon. I sold mine solely because of this. It's not bad, but it doesn't compare to the new ones.
Thanks for the advice.
You might read the user reviews of this lens here and on amazon.  Yes it is not equal to the newer 35 but I was surprised how well it did perform on my SL1.  It is also noticeably smaller and lighter which to me is the main reasons I use my SL1.
35 f/2 non-IS :  7.36 oz (210 grams);  Length: 1.67 inch (42.5mm)
35 f/2 IS:        11.82 oz (335 grams); Length:  2.46 inch (62.6mm)
I got mine for $205 several years back during a Canon online store refurb sale and it has been worth the money.  That said, if you want new and IS, and are willing to pay more and don't mind the increased size and weight then the 35 IS is the way to go if you find te 40stm to long and the 24stm too wide.  Just thought you should know there is a viable alternative.
rocky01 Regular Member • Posts: 213
I would think you would be in line for the Canon EF 28mm f/2.8 IS USM since it's rated well.
Abu Mahendra Veteran Member • Posts: 5,312
ctzeh wrote:
PS: I have used the Sigma 30mm f1.4 for a while but feel...it's focus seems to be inconsistent.
An unreliable focus Sigma, what a surprise.
Canon 28IS and 35IS is what you want.
>> I am already lovin' the Canon EF 35L II lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
richro Regular Member • Posts: 244
Can't wait to see the new EF-M primes!
 richro's gear list:richro's gear list
Canon EOS 6D Canon EOS M5 Tamron SP 24-70mm F2.8 Di VC USD Canon EOS M Canon EF 85mm F1.8 USM +11 more
Good idea for another option.  Is between the Canon 35/2 and 35/2 IS in size, weight and price; is sharp and has IS; and as far as being a 50 equivalent on a crop it is off on the wide side by the same amount the 35 is on the long side.
Steve Balcombe Forum Pro • Posts: 15,582
The old 35/2 would be a poor choice IMHO. As well as the very visible difference in image quality, this lens was, until it was discontinued, one of just two left in the Canon line-up which still used the slow, very noisy 'arc-form drive' AF motor*. The new 35/2 IS has Ring USM autofocus so it's in a totally different league.
(* The only one left now is the 50 mm 'compact macro' which may never be replaced as it is a very niche product and probably not worth the investment for Canon.)
stratobill Senior Member • Posts: 2,081
I would opt for wider, I find I really like 40mm on full frame, so long as it's as good as the 35/2,
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
SnappyChappie Regular Member • Posts: 434
The Canon EF 28mm f/1.8 USM has been very useful for me, some people like it, and some people don't but i've gotten some nice images with it - in low light as well as good light - and seeing as it still seems to be holding it's value there must be still something good about it. And it just looks right on the 70D and T4i - size & design - including with the hood.
Hunting the hunters is the best sport.
 SnappyChappie's gear list:SnappyChappie's gear list
Canon PowerShot A620 Canon EF 100mm F2.8L Macro IS USM Canon PowerShot SD780 IS Canon EOS 6D Canon EOS M50 +13 more
