Re: Report: Usefulness of some Lenses Used during a Trip in Paris
FrankS009 wrote:
Have not had a chance to look at your images yet, but was tempted to write now by your comment about the brighter M. Zuiko 7-14mm being used more often for interiors than the Panasonic 7-14mm would have been. And then you said, take brighter lenses if they are not too heavy. The M. Zeiko is certainly heavier than the Panasonic. Did you find that a problem?
The M.Zuiko 7-14mm F/2,8 is at the limit of my goodwill toward heavy and big lenses.
By far, the biggest problem with the M.Zuiko 7-14mm was its automatic/manual focussing toggle ring.
In a future article, I'll write about the effect of anti-terrorist measures implemented in museums in Paris on the best ways to carry lenses. In a nutshell, I had to carry lenses on me (inside different coat pockets) rather than in a backpack.
Because the M.Zuiko 7-14mm F/2,8 has an obvious triangular shape, it's very easy to pull or push that ring accidentally when it's taken in or out of a pocket. So I've missed many shots because it was put accidentally on manual mode.
If I had a suggestion to Olympus, it would be to implement the need to turn and push (or pull) that ring to change its focussing mode (like it's needed to do so with the hood on the M.Zuiko 40-150mm F/2,8).
For a "zoom guy" you must have really enjoyed the Panasonic 25 1.4 to have used it so often.
You know me very well, Frank; yes, I'm a zoom guy.
I was surprised to use the PanLeica 25mm F/1,4 so often. But the reason is simple; F/1,4 is four times brighter than F/2,8. An ISO 1600 shot becomes a ISO 400 shot when a four times brighter lens is used.
Since I never use a tripod during my vacations, I must rely on fast lenses.
By default, my M.Zuiko 12-40mm is set at 16mm (because it is at its smallest size at that focal length). So when I was about to take a shot with the M.Zuiko 12-40mm, my first question was: how does this subject looks at 25mm? So I'd zoom at 25mm.
And if that focal length was perfect, I'd switch without hesitation to the PanLeica 25mm F/1,4 except when the subject was over a bright-lit background (since the the PanLeica 25mm F/1,4 is my worst lens for chromatic aberration. I know that it's easy to correct during post-processing but I prefer to prevent rather than to cure CA).
For example, the Notre-Dame-de-Paris Treasure, the Quai Branly Museum, the Dapper Museum, the Madeleine Church, are very dark places. Fast lenses are a must inside places like that...
That's why even a dye-in-the-wool zoom guy like me had to use that fast prime so often.
