Mobile RAW Workflow
Started Nov 4, 2015 | Discussions
jakegrahamphotography
jakegrahamphotography Regular Member • Posts: 184
Mobile RAW Workflow
Hi there,
Interested in setting up a fully mobile RAW editing workflow without having to run through a computer. Am currently using the following:
Sony A6000 & LG G4
I shoot raw (ARW files) on my Sony A6000 with a microSD card and can insert into my LG G4.
Since the LG G4 can read DNG files, I should be able to convert the ARW files to DNG (using raw2dng), edit then export as JPEG all while still on the phone... no?
 jakegrahamphotography's gear list:jakegrahamphotography's gear list
Sony a7R IV Zeiss Batis 18mm F2.8 Sony FE 100-400mm F4.5-5.6 Tamron 28-75mm F2.8 III Sony FE 135mm F1.8 GM
LG G4 Sony a6000
Trevor_S
Trevor_S Regular Member • Posts: 443
Re: Mobile RAW Workflow
That to me sounds horrible... editing on a phone.  Perhaps something like the Windows Surface 3 with Lightroom ? A6000 -> Surface 3, edit with LR -> export as JPG.
 Trevor_S's gear list:Trevor_S's gear list
Sony a6000 Sony a7R IVA Sony Vario-Tessar T* E 16-70mm F4 ZA OSS Sony FE 90mm F2.8 macro Sony FE 24-105mm F4 +3 more
jacosta Regular Member • Posts: 224
You don't to convert to DNG, just a RAW developper app that supports ARW, PhotoMate or PS Express come to mind. But I agree that desktop is better suited, especially at high ISO where Android apps are no match to Lightroom and similar. You might as well use the A6000 jpegs.
Fri13 Veteran Member • Posts: 3,116
jakegrahamphotography wrote:
Hi there,
Sony A6000 & LG G4
As you mentioned:
Convert: https://play.google.com/store/apps/details?id=com.fimagena.raw2dng
Convert+Archive: https://play.google.com/store/apps/details?id=com.BrainyLantern.slingShotPortfolio
Edit+Export: https://play.google.com/store/apps/details?id=com.niksoftware.snapseed
So yes, you can do it but on the phone it can be little difficult because so small screen (snapseed does it very easy although).
Fimagena New Member • Posts: 19
Hi there,
Sony A6000 & LG G4
Yes, should work. Three additional comments:
1) If you're a Lightroom on the desktop user, you could consider using Lightroom mobile for editing with the additional benefit of everything (DNGs and edits) syncing back to your desktop.
2) You might want to apply a DCP-file during DNG-conversion, since the app won't know your camera's colour profile. Not a huge difference though.
3) While I haven't tested it with the A6000, raw2dng (I'm the author) supports Sony's Wifi-transfer, so you shouldn't even have to switch your microSD card. (future version will further simplify the setup soon)
OP jakegrahamphotography Regular Member • Posts: 184
Can you please elaborate on the above? I'm not sure that I'm following here - thanks for taking the time to respond!
Many Sony cameras (to my understanding including the A6000) have a wifi-function to transfer pictures wirelessly to a laptop or smartphone.
What I meant to say is that my raw2dng app supports the wifi-transfer of RAW-files from Sony cameras directly (via an access point) to your smartphone. So you don't even have to switch your sd-card from the camera to the phone to access the pictures but can copy them wirelessly via wifi.
Hope that clarifies.
TSGames Regular Member • Posts: 261
Hi,
I'm the developer of Photo Mate and one of the main targets of this app was to be a complete solution for your editing workflow. It allows you to bulk edit and store edits and convert your files later, e.g. when you're back at the charger.
However, it's true that should really use a decent tablet, I usually recommend 8" or even better 10" display.
Also, as jacosta pointed out, Luminance-Reduction is usually worse on a tablet. Photo Mate offers an Ultra mode for decent results, but you have to bear in mind that this will take several minutes per image. Mobile processors simply not that fast.
Regards
Torsten
 TSGames's gear list:TSGames's gear list
Sony RX10 III Sony a7R II Sony FE 90mm F2.8 macro Tamron 28-75mm F2.8 III
