Problem with still photos with dirty background colors.
Started Nov 3, 2015 | Questions
pooka3 New Member • Posts: 8
I'm not sure where to post this so please excuse if I'm in the wrong forum.  I have a Cannon EOS Rebel T3 EOS1100D.  I have a problem taking pictures to use on Ebay.  Other photos aren't a problem.  I am a beginner.  The problem is getting a still closeup without getting a dark background or too light a background.  I have a light yellow kitchen where I take the photos.  The kitchen is not bright.  I have tried using a tripod, an external movie lamp, flash, no flash, lights on lights off.  The photos always have a brown, grey, or dirty yellow background.  Right now I am trying to take photos of a silver medal enclosed in clear plastic and the photos are terrible.  I have tried different settings and I still take terrible photos.  I have tried changing the WB, ISO, f stops.  I have also tried using different papers as backgrounds, white to black and all colors in between.  I would like to take a photo of the medal with a white background and not a dirty background.  Can anyone suggest what can be done?  I also use Photoshop CC and even that doesn't help.
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
Digirame Forum Pro • Posts: 41,857
Re: Problem with still photos with dirty background colors.
Eventually, someone is probably going to ask you for sample pictures.  If you didn't want to show what you are offering for Ebay at this moment, maybe you could take some pictures of spoons or cups or books or things like that against the different backgrounds.
In the meantime, have you tried spot exposure to see if that helps achieve the look that you want?  Also when you are using the on-camera flash do you change the flash compensation after you view the photos in the LCD screen (if that helps make it better)?
PhilPreston3072 Senior Member • Posts: 2,660
Without seeing the photos, I can only assume it might be the kitchen light making the background off-white.  DSLRs aren't great at White balancing indoor lighting so have you tried shooting Raw and adjusting the WB in raw editing software like Canon's Digital Photo Professional or Adobe Lightroom?  Jpegs are not so good for correcting white balance.
 PhilPreston3072's gear list:PhilPreston3072's gear list
Canon EOS 450D Canon EF-S 18-200mm f/3.5-5.6 IS +1 more
imqqmi Veteran Member • Posts: 8,639
Take control over lighting
Is the object itself the way you want it? If that's the case and only the background is off, you're either using mixed lighting or the painted room you're shooting in is influencing your pictures. You could consider using a photo tent, it's all white and you put a couple of lights on it which should even out the light and white balance. You can do a custom white balance and keep shooting in jpeg, or use raw and set the white balance manually.
Moving to a room with neutral light would also help, or using flash to overpower the ambient lighting, bouncing off pure white surfaces or use the tent or other white shoot through material.
You said that photoshop cc doesn't help, though I suspect you try to do adjustments over the whole picture instead if selectively? Photoshop has powerful selection tools to select the background and make changes using layer effects. You could do some background replacement on the shots you already have or reshoot in better conditions.
Kind regards
Imqqmi
Links:
View my webgallery
http://www.pbase.com/imqqmi
The DSLR jargon cheatsheet
http://www.jmbfoto.nl/dslrcheatsheet.pdf
Sunset blending tutorial
http://www.jmbfoto.nl/tutorial/blendingTutorial01a.pdf
Wilba's Frequently Asked (beginners) Questions and answers
http://snipurl.com/RebelFAQ
 imqqmi's gear list:imqqmi's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +2 more
dzba Senior Member • Posts: 1,680
I see this is your 1st post here.  Welcome to the forum.
You've been given some excellent help.
As others have stated, it would be of help to post examples to what your problems are.
Lots of friendly, helpful people here.
Good luck,
Mike
please do not alter,save, or repost any of my images without 1st receiving my permission to do so.
 dzba's gear list:dzba's gear list
Panasonic Lumix DMC-FZ30 Canon EOS Rebel T4i Nikon D7500 Canon EF-S 18-55mm f/3.5-5.6 II Canon EF-S 55-250mm f/4-5.6 IS STM +2 more
seri_art
seri_art Veteran Member • Posts: 3,063
Re: Take control over lighting
That's excellent advice. A photo tent with inexpensive lights, and custom white balance, is what I use for photos of small objects with white backgrounds.
 seri_art's gear list:seri_art's gear list
Sony RX100 III Canon EOS Rebel T7i Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +3 more
OP pooka3 New Member • Posts: 8
Thank you for your reply.. How would I submit samples of my photos that are the subject of this question?
Thank you for your reply.  I have tried experimenting with the flash but I think it is the lighting and my lack of knowledge as to how to use my camera.  Suggestions have been made to try raw shooting.  I have never tried that but it looks pretty interesting and may help.  As soon as I am able I will post some examples of my problem.
I will post photos as soon as I am able.  I'm going to try shooting raw.  I think there will be a learning curve however.
Thank you for your reply.   have Photoshop cc  and Lightroom cc.    I just got them so I'm still trying to learn them.  I did use Photoshop 7 for a long time but never had to change much.  I had a Sony minicam that was easy to use and took very nice closeups.  My Cannon is very different.  So is Photoshop cc.  I'm going to try using raw tomorrow, it sounds interesting and fun.
example of the problem.  b4 and after ps first one is b4 and the next is after.  not much difference.  I think I used a black paper then white paper and photos were still terrible.
sleibson Regular Member • Posts: 444
With a photo, clarity. You're shooting a highly reflective object and you are getting into the image. I think those are your fingers in the the reflection. The second image looks OK for color, but the reflections of your fingers and the specular highlight of your light are hurting the image.
Reflective objects are really hard to shoot well. Here's a link to a nice writeup of the problem that explains step-by-step lighting experiments and the final result:
https://photoflex.com/pls/creating-double-diffusion-for-reflective-objects
Steve Leibson
www.sleibson.com
Shooting with Canons for 40 years
 sleibson's gear list:sleibson's gear list
Canon PowerShot G12 Canon EOS 20D Canon EOS 60D Canon EOS Rebel SL1 Canon EF 50mm F1.8 II +10 more
It looks like your White Balance was able to be corrected without issue.  The problem I see is that your background is too close.  Are you able to stand up the plaque, and put the background sheet further away from the plaque?  That way the background will be out of focus and less distracting.
To avoid seeing the reflection of your hand and the camera you could perhaps try turning off the room light and illuminating the plaque from the front with a desk lamp or spot light.  As long as you're in the dark, you shouldn't reflect off the glass.
BAK Forum Pro • Posts: 26,020
You nailed it.
You wrote >my lack of knowledge as to how to use my camera.<
Yes, that is the problem.
That can be fixed with a book or two and some messages here, and maybe a bit of Photoshop.
I'm busy doing real work, but I can send you down two paths.
1/ Raw has nothing to do with anything.
2/ The inverse square law has a lot to do with your problem.
To save you Googling, what it means is light gets dimmer as it travels farther.
So if the medal is properly lit, and then illumination flows past it to the background, and gets dimmer as it travels, it is normal that the background will be darker.
SIMPLE FIX ONE:
Can you use one lamp to light the medal, and another to light the background, both to the same intensity?
Set your camera on manual exposure, and take a reading of some mid-toned object at the spot where the medal will be. A photographic grey card is best, but a medium blue sweater would work.
Write down the numbers.
Repeat where the background will be. Write down those numbers.
Compare the numbers, and move the lights in and out until the levels match.
Put the medal in position, and try your luck.
Please report back.
BAK
Thank you for all of the suggestions.  I don't have the resources to build, create, change my shooting area.  I tried different settings and finally decided on grayscale.  Some of the settings improved the photos using grayscale.  When I have more time and resources I will again visit this problem.  I would like to not cop out by using grayscale.  Thank you, everyone, who were kind enough to take the time to suggest different solutions.
Mostly, you just need a piece of black construction paper with a hole cut it it. Poke your lens through that and the reflective surface won't see your fingers or your camera.
Steve Leibson
www.sleibson.com
Thank you for your suggestion.  The link was very helpful and being new to the new version of Photoshop, I used a filter called "camera raw filter".  I have experimented with the settings (starting with what was suggested on the link), and Photoshop and my photos are better.  Not perfect but I have more control now. I don't have the time to build a studio or become a professional photographer so you have been very helpful.
