Re: Adapting 4/3 lens to M4/3 body with adapter
MaryAnnMachi wrote:
Hi, Looking for input on experience with using an Oly 50-200 4/3 lens on an Oly OM-D E-M5 body with an MMF-2 or 3 adapter. Finding some complaints about focus slowing down to lesser quality images. Any feedback appreciated. (Would be open to experience in general using an adapter with different lens, same body.) I understand the MMF-3 adapter is weatherproof while the MMF-2 is not. Thanks!
I have an E-M5, and also an E-M1. I had both versions of the 50-200 (original and SWD version). The original 50-200 was better on the E-M5, while the SWD version was better on the E-M1. Because no 4/3 lenses are really very good on the E-M5 (and I include the CDAF-optimized 4/3 lenses as well), I sold the original 50-200 and kept the SWD version for use exclusively on my E-M1.
There are advantages to the original 50-200, namely the lens hood is reasonable size (the hood on the SWD version is huge), and the bayonet mount on the front is compatible with the ring flash mount (I have the Olympus ring flash, but have adapted it for use on other lenses).
The images are great as long as you get focus. Auto focus is slow, and will miss often. I almost always touch up with manual focus. Here's how I handle theses lenses on the E-M5:
Set Fn2 to MF. This will toggle between manual focus and auto focus.
Set Record to Magnify. The will magnify the image for manual focus adjustment.
Define a MySet with the mode set to Key Line (art mode 11). This mode simulates focus peaking.
Define Fn1 to switch to the above MySet. You have to hold the button down to temporarily activate the MySet; when you release it you are switched back to the current settings.
I always recommend that people upgrade to an E-M1 if they are going to use 4/3 lenses; the other m4/3 cameras were not designed to handle those lenses. But if you really want to try 4/3 lenses, getting proficient at manual focus will be your friend.
