EM1 continous AF and tracking
Started Nov 3, 2015 | Discussions
Andrew Ellis
Andrew Ellis Contributing Member • Posts: 985
Hi all, quick question please.
I've never used the EM1 before for anything other than single point AF. But we have just bought a new puppy to fill the hole in our lives left by the passing of our beloved cocker spaniel "Jake" a few weeks ago, and I want to document "Charlie's" life in photos and video.
With the advent of the Olympus Firmware V3 (which I have), one of the improvements was CAF and tracking, however there were also mixed comments about needed to have the correct frame rates (Continuous high vs medium), and Tracking vs non tracking etc. and it all got a bit confusing.
The question is then basically for an unpredictable Puppy, what's the best camera settings for CAF  modes, drive modes, tracking etc. from all you experts that have already figured this out ?
Whilst I know that the Olympus will not be as good as the best DSLR set ups, if I can get a 50% keeper rate, I'd be happy with that. I will be mainly using either the 12-40 F2.8 Pro or the 40-150 F2.8 Pro.
Thanks.
Lets make pictures, not war........
 Andrew Ellis's gear list:Andrew Ellis's gear list
Panasonic LX100 Nikon Z7 Olympus OM-D E-M1X Olympus E-M1 III Nikon Z6 II +22 more
Nikon 1 V3 Olympus 40-150mm F2.8 Pro Olympus E-M1
Fri13 Veteran Member • Posts: 3,116
Re: EM1 continous AF and tracking
C-AF + Sequential H and use 10fps (it dropsautomatically to 9fps) for PDAF only continues autofocus. You need to keep subject inside PDAF focus group array on screen, or choose a AF point inside that.
Use 9-point AF grid if you have difficulties to keep small or normal AF point.
Don't use C-AF and Tracking (C-AF+Trk) as it drops camera back to CDAF+PDAF hybrid mode or you get only CDAF like with C-AF + Sequential L.
Oh and E-M1 can beat cameras like 7D Mk2 in C-AF accuracy and speed.  And you don't get back/rear focus problems.
Colin K. Work Veteran Member • Posts: 3,699
Thanks.
IMHO tracking is still not worth using. CAF has improved, but the trick will be to keep Charlie in the focus area. I'd favour 9 point to give a little leeway.
I think the background is important to the rate of keepers - the less clutter the better.
Frame rate? Not sure my results would favour one over the other, for other reasons I prefer a slower frame rate, but probably for a fast moving pup I'd use short bursts at high speed.
Colin K. Work
www.ckwphoto.com
www.pixstel.com
windsprite
windsprite Senior Member • Posts: 2,788
Would you mind sharing the links that prove this?
Julie
 windsprite's gear list:windsprite's gear list
Fujifilm FinePix F100fd Fujifilm FinePix F550 EXR Panasonic Lumix DMC-FZ200 Nikon D2H Nikon D300 +47 more
Chris R-UK Forum Pro • Posts: 22,843
Perhaps you could produce your evidence for that statement.
Do you own a 7D MkII?  Have you shot with one?
I owned a 7D MkI for 6 years and I can tell you that my E-M1 with a red dot sight can shoot most of the things that the 7D could, but there is no way that the E-M1 has better C-AF accuracy and speed than the 7D MkI let alone the 7D MkII.  The lack of cross type AF points in the E-M1 can be a serious restriction for some targets.
I agree with your settings, by the way, but I don't think that you need 9fps for shooting a puppy.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
OM-1 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
I'm not sure about this ... I would suggest the initial acquisition is faster and more reliable than the 7D, but once acquired the 7D holds focus better. But it does very according to subject and conditions. I think this accounts for the variety of reports on relative performance - depends what you shoot I guess.
Chris R
Colin K. Work
www.ckwphoto.com
www.pixstel.com
Colin,
I have been shooting BIF recently with an EE-1 to find out what I can and cannot shoot with the E-M1. Using Sequential L and hybrid PDAF/CDAF the E-M1 is certainly worse at maintaining focus and tends to go in and out of focus as you track the bird. I have therefore switched entirely to Sequential H for BIF using the EE-1.
My impression using Sequential H is a little different to yours - I would say that the E-M1 is probably comparable to the 7D for maintaining focus but is sometimes slower at acquiring the initial focus. Shooting with an EE-1 you have to wait for the focus beep to know that focus has been acquired before starting to shoot and sometimes that takes a while. With the 7D the beep normally came faster and more reliably. I am having particular problems when the bird is coming head on in a very horizontal attitude and that could be due to the lack of cross type AF points on the E-M1 (although I would have thought that it would affect vertical targets more than horizontal).
The EE-1 has its own advantages and disadvantages - you can pick birds up extremely quickly but I get a lot of cut off wings because you can't see the viewfinder. I probably need to learn to shoot at a shorter focal length to allow more room for error. The EE-1 is great fun to use.
All in all, after about 6 months and 3000 or so BIF shots with the E-M1, I am at the situation where I can shoot everything with the E-M1/EE-1 that I could shoot with the 7D and I probably get comparable keeper rates, but I don't yet have the confidence with the E-M1 that I had with the 7D that I can nail a shot when shooting the most difficult targets.  If I was going out on a once in a lifetime wildlife opportunity I would prefer to have my 7D with me (if I still had it) rather than the E-M1, but not prefer it sufficiently to offset the disadvantage of carrying around heavy lenses like the 100-400mm that I used to shoot with.
I think that all this shows is that on-sensor PDAF is probably the way the mirrorless cameras are going to take over from DSLRs for C-AF. I hope that the next generation E-M1 has Liveview at higher fps rates, the option to choose between PDAF and hybrid AF and cross type PDAF focus points.
Chris R
SkiHound Veteran Member • Posts: 3,939
I don't have my camera in front of me but I have a myset set up for this. The main settings I use are CAF with sequential set to  high and 10fps. Actual speed will depend on the lens. Face detect off. There's a shutter release lag time setting somewhere that I set to short. Is off to On (I know, stupid labeling, shutter priority, frame rate to high, manual focus aids to off, CAF lock to normal. I generally set the release priority to on for CAF but you might try both to see what works better for you. And I generally use the 9 box group focus area. Can't compare to good dSLRs but in decent light it works quite well. Practice.
drj3 Forum Pro • Posts: 12,632
Colin,
For horizontal targets that have little height, I flip the camera into portrait orientation, and then it locks focus extremely quickly even for very small targets.  Having the grip makes this much easier.  Some simply tilt the camera so that the target is not horizontal, but I find portrait orientation works more quickly.
Chris R
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Paul Amyes Senior Member • Posts: 1,907
After consulting the collective brains trust on this very subject a few weeks ago I purchased an EM1 for shooting sports. To put it mildly the results were disappointing while the camera quickly acquired focus it quickly lost it with the net result that I was not getting anymore than around 50% of shots in focus. Slightly better than me using manual focus on my OM4. So I bit the bullet and bought a 5d mkiiii and I'm getting much better results in excess of 70% of the shots in focus with a Sigma 120-300 f2.8 and x2 converter.
Micro 4/3s has come a long way but this is one area in which it severely lacking, which is a shame as I would have preferred to use it rather than the dSLR.
 Paul Amyes's gear list:Paul Amyes's gear list
Voigtlander 35mm F2.5 Color Skopar
Colin,
I suspect the big difference here is the target ... mine are generally much larger - usually filling the bulk of the frame.
Colin K. Work
www.ckwphoto.com
www.pixstel.com
The initisl focus can be slower to achieve, but I don't wait focus Lock before release as it slows down IMHE. I start bursts ND in 1-2 first frames can be out of focus if initial focus plane distance is either very close (like 1-3m and subject at 10-30m) or other way around that initial focus plane is at infinity or over and the subject is way closer. Just releasing burst the AF will quickly jump to subject and stay there.
Few months back I was again in one of those situations and I had E-M1 and 7D Mk2 and 7D failed far more often and in one crucial moment failed totally by unacceptable way by focusing further than the whole scene was.
It was easier to get keepers with E-M1 than with 7D Mk2. And I wasn't alone as others had as much trouble too, but can't be sure why as didn't ask when they had calibrated their focusing previously, as I calibrated on previous day to be sure.
I thing that PDAF is just a phase and in future we use more software based focusing with CDAF as it is promising once we get global shutters and we get away from the shutter etc.
It is just question of the time when we get better algorithms and processing power to do it well.
I am somewhat surprised at your 50% rate, but it would differ based on target, lens and camera settings.  I am not really surprised that your Canon/Sigma gives a somewhat better success rate.
My success rate with the Olympus was very poor when I first switched from a DSLR, but with experience with the camera and firmware updates, it improved greatly.
However, for me the success rate for the Canon would be much worse, since I would probably rarely use it, given the size and weight.
drj3
Steve2015 Contributing Member • Posts: 516
Not knowing much about your gear will net you the results you're getting. Others here seem to be getting fantastic results shooting sports.
Have you tried playing around with the CAF lock?
How about the AF point? (small, 9, all?)
I can honestly say that if you're only getting 50% keepers, what were you doing wrong? A lot here think that you only need a camera capable at shooting sports to be able to capture consistantly great action shots. Like with any other genre, it's going to take a lot of practice to get images you're happy with, not a week or two, especially with a new camera.
The big advantage of on sensor PDAF is that it enables DSLR lenses to be used on mirrorless cameras with no focusing speed penalty - that of course if why the E-M1 exists.
That is surely a big factor for Canon/Nikon/Pentax and the timing of any decision to move from DSLRs to mirrorless.
Chris R
Skeeterbytes Forum Pro • Posts: 23,182
Thanks.
Hi Andrew,
Sorry you lost your buddy, but I'm sure you're enjoying your puppy.
E-M1 CAF response with those two Pro zooms is the best I've experienced. I use the 40-150 every weekend for soccer. I don't use tracking, as it's more for a subject crossing the frame while I'm busy following the ball.
I use center nine pattern, high burst rate, mode 2, release priority off, CAF lock low (still researching this setting ) matrix metering. ..half a dozen other settings I'm forgetting.
Folks reporting trouble with this pairing have simply not explored the settings deeply enough. It has taken me months and I'm still learning. Hopefully Don Parrot will check in, he's the acknowledged master of shooting dogs in action.
Good luck!
Rick
The problem is that as of now, PDAF has neither the coverage or sensitivity of higher end DSLRs, so essentially while there is nothing wrong with PDAF in the right conditions, it's simply not as capable overall.
If I were to make a direct comparison, I would say CAF use and performance is not dissimilar to the original Canon 5D taken all round, though there are situations where it is significantly better.
Colin K. Work
www.ckwphoto.com
www.pixstel.com
DonParrot Veteran Member • Posts: 4,968
Well, I shot with the 7D for several momth and i never was able to achieve this kind of long bursts of fast moving subjects:
E-M1 with EE-1 Dot Sight does sighthounds an RC boats.
Can't say anything about the 7D MKII but the MKI's C-SAF definitely is inferior to the one of the E-M1 when equipped with the EE-1 Dot Sight.
I wish I was an OLYgarch
 DonParrot's gear list:DonParrot's gear list
Panasonic FZ1000 Olympus E-30 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GH4 +13 more
Paul, you should have allowed yourself an adapting period. You have to opt for a slightly different approach, when shooting action with the E-M1. For success right from the start, the Panny GH4 with its (positively meant) C-AF for dummies would be the better solution, but if you want the maximum keeper rate, the E-M1 is the way to go.
Do you know whether there is any fundamental reason why on sensor PDAF is always going to be inferior to the sort of PDAF system in a DSLR using a separate mirror assembly and PDAF array?  (Maybe that is one for the Science and Technology forum).
Canon has its dual pixel sensor that first arrived in the 70D and is also in the 7D MkII and that certainly gives PDAF coverage of the whole sensor.  However, as it is currently implemented, it doesn't seem to have as fast AF in Liveview as a top mirrorless camera.  I wonder why that is.  I also wonder why Canon hasn't put it in the EOS-M.
Chris R
