Flash diffuser for NX3000 flash?
Started Nov 2, 2015 | Questions
Charles Laigo
Charles Laigo Contributing Member • Posts: 608
Just wondering if anyone is using a flash diffuser (DIY or otherwise) for their flash.
 Charles Laigo's gear list:Charles Laigo's gear list
Canon PowerShot SX50 HS Olympus E-500 Samsung NX3000 Google Nexus 6P LG G5
Samsung NX3000
Re: Flash diffuser for NX3000 flash?
There is no point in using small diffusers on flashes, if you want to get soft shadows you need a diffuser (softbox, umbrella, whatever) that is at most 3-4 times smaller than distance to subject. So for diffuser that's 4 inches across (small softbox) you would need to be a foot away.
Might I suggest a different approach? Use either a TTL flash extension cord for NX or a small DIY reflector (I can make a drawing for it if you are interested) for your sef8a flash and bounce the light off the walls / ceiling?
Charles Laigo
OP Charles Laigo Contributing Member • Posts: 608
Sounds pretty interesting! I'd love to see your DIY reflector. I have an old Sunpak 383 which I could use for bounce/diffuser shots but I was hoping for something small and pocketable. Your DIY reflector may be just the thing I need. TIA.
panoc Forum Member • Posts: 74
Until i bought my metz 44 flash for my NX300 i use 2 DIY reflectors for the sef8 flash.
Here is what i used.
its made from super glossy photo paper. Angle 45 degrees. It folds and become a card with dimensions about 12X10 cm.
and
it is from a old film box.
here is a simple drawing i hope you understand it.
keep in mind that you probably have to increase the flash strength a bit.
 panoc's gear list:panoc's gear list
Samsung NX300 Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 12-24mm F4-5.6 ED Samsung NX 45mm F1.8 +1 more
vatazhka
vatazhka Regular Member • Posts: 355
See here.
Check here if your Samsung NX / NX mini camera & lens firmware is up to date!
 vatazhka's gear list:vatazhka's gear list
Samsung NX1000 Samsung NX mini Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +3 more
Anahtar New Member • Posts: 3
Good ideas, thank you!
I am looking for a TTL flash, suitable for my NX300, but unfortunately cannot find one at Adorama, B&H, Amazon, Bestbuy....
Please, advise where I could find such a flash. I suppose yours is Metz 44 AF 1 Digital.
Thank you in advance!
markyboy81 Veteran Member • Posts: 4,778
I recently picked up the metz 26af for around £70 from Amazon and it's fantastic! Comes with a built in macro diffuser and add-on telephoto diffuser.
I've been getting great results using it in bounce mode.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Charles Laigo
Can't seem to find the Metz 26AF on Amazon. All I'm seeing is the Nikon compatible one. Is your unit a dedicated Samsung one?
Yes it's a dedicated samsung flash;
https://www.amazon.co.uk/gp/aw/d/B00NVMR1KG/ref=mp_s_a_1_1?ie=UTF8&qid=1478157015&sr=8-1&pi=AC_SX280_SY350_FMwebp_QL65&keywords=metz+26+a+samsung&dpPl=1&dpID=41YmMW4a0hL&ref=plSrch
