Canon 24-70L f/2.8 II focus throw?
Started Nov 2, 2015 | Questions
markodarko
markodarko Regular Member • Posts: 198
Hi guys,
I wonder if I could pick your brains...
Does the Canon 24-70L f/2.8 II have a long 150º focus throw? (I couldn't find any official figures and found that number along with 110º on the net) And... Is it easy (in your opinion) and smooth to manually focus?
Mark.
Canon EF 24-70mm F2.8L II USM
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: Canon 24-70L f/2.8 II focus throw?
markodarko wrote:
Hi guys,
Mark.
The focus throw on the 24-70 f/2.8L II from infinity to .38 meter appears to be a little over 90 degrees. Maybe 100-110 degrees, tops.
Operation is smooth as silk with little drag.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
msowsun
msowsun Contributing Member • Posts: 740
hotdog321 wrote:
markodarko wrote:
Hi guys,
Mark.
Ken Rockwell first says it is about 120 degrees, but later in the review says it is about 110 degrees.  Ken Rockwell EF 24-70 II review
 msowsun's gear list:msowsun's gear list
Canon PowerShot S110 Canon EOS D30 Canon EOS 5D Mark III Canon EOS Rebel SL1 Canon EOS 80D +27 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
'150' deg = typo? the-d-p has 105 deg.
http://www.the-digital-picture.com/Reviews/Lens-Specifications.aspx?Lens=787
hotdog321 wrote:
markodarko wrote:
Hi guys,
Mark.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
markodarko
OP markodarko Regular Member • Posts: 198
Re: '150' deg = typo? the-d-p has 105 deg.
Aha! Thanks.
Hmm. 105º. I was hoping it was going to be 150. Oh well.
Thanks again.
Mark.
markodarko
hotdog321 wrote: The focus throw on the 24-70 f/2.8L II from infinity to .38 meter appears to be a little over 90 degrees. Maybe 100-110 degrees, tops.
Thanks. May I ask what the manual focusing is like wide open at around 50mm and say, 1.5m from your subject? The reason I ask is that I have recently acquired a Sigma 50mm f/1.4 (which as I've just found out only has a 92º focus throw, so 15º less than the 24-70 II) and nailing focus with such a short throw with manual focus is quite a challenge. More of a challenge than I hoped it would be.
Mark.
