Panny 30mm macro practical on GM1?
Started Oct 29, 2015 | Discussions
Al Bond Contributing Member • Posts: 620
Hi,
I recently bought a second-hand GM1 and 12-32 lens.  I really just wanted the lens (to use on my E-M10) but, as my wife's Canon Powershot G11 had become faulty, I suggested that she tried it out.
The outcome is that it is now officially her camera......
She is generally happy with its performance but she used to take a lot of macro shots with the G11.  The 12-32 is a pretty good lens but it doesn't have close enough focus for her needs.
So, one option is to get the Panny 30mm macro lens.  Obviously, despite being a relatively small lens, I suspect it will still looks huge on the GM1.
Has anyone used the 30mm on the GM1 or GM5?  Is it manageable?
Impulses Forum Pro • Posts: 10,039
Re: Panny 30mm macro practical on GM1?
It's not that bad, that lens it's half an inch longer than any of mine but it's still pretty svelte. Here's a visual:
http://j.mp/1P05mqh
The matching simulator at the official MFT page will give you more angles to look at, can't link directly to a lens/body combo tho:
http://www.four-thirds.org/en/special/matching.html
Depending on how often she does macro and how much magnification she really needs you could also consider the 42.5 f1.7. It won't get you 1:1 but it has a pretty decent minimum focus distance, and you could always add an extension tube or achromat adapter (like a filter) for even more magnification.
The cheaper Sigma 60mm f2.8 works well in this regard too, I like the 42.5mm as a general portrait lens tho, and the OIS helps on a GM1. I doubt the 30mm would present a handling issue tho, so as long as you don't mind how it looks...
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
TheClueless
TheClueless Senior Member • Posts: 2,140
Al Bond wrote:
Hi,
Actually, big-to-huge lenses IMO work better on the GM1/5 - since you can grab it by the lens.
Obviously it defeats any and all pretence of compactness and then you might be wondering why you bought into a camera with such compromised handling, but if it's what you chose then bigger lenses allows more of your left hand to stay off the camera body while holding it more securely at the same time.
 TheClueless's gear list:TheClueless's gear list
Leica Q2 Leica M10 Panasonic Lumix DC-G9 Sony a7R IV Sony Cyber-shot DSC-V1 +71 more
Astrotripper Veteran Member • Posts: 8,676
Check out matching simulator . Yes, it looks huge on GM1.
I would still say this might be an interesting combo for taking close-up shots from unusual angles and/or cramped spaces.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Fri13 Veteran Member • Posts: 3,116
Al Bond wrote:
Hi,
How about a Kooka MFT extension rings kit, 10/16/21mm and then just take the 10mm extension ring in to use?
It will turn the 12-32mm to very good close-up objective with 0.44x magnification. If you would use a 16mm extension ring you can manage to get a 0.63x magnification.
I made quick search around web and couldn't find the Canon G11 magnification value in its "macro mode". But I only found that it has 1/1.7" (1.49cm diagonal) sensor and when mode is enabled the wide angle is used and the camera can focus to 1/4" of the front lens, getting approximately a post stamp size area. That means the magnification ratio isn't 1:1 (1.0x) so it doesn't have a macro function, but it is pseudo-macro or "just" a close-up mode.
That meaning, You should be able to apply the needs of the pseudo-macro feature with the extension ring.
So if it isn't really required to get the 1:1 ratio (17.3x13mm area) it shouldn't be a problem.
I had a few minutes time to test the 10mm extension ring with GM1 (before it was taken from me...) and it offered very nice possibilities.
Here is example of the GM1+12-32mm + 10mm Kooka extension.
It is captured in 16:9 ratio and this is widest possible image. The subject is by size about 4-5mm
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
Re: Panny 30mm macro practical on GM1? Alternative
Big lenses on the GM1 work fine and become the main handle/grip. That's what happens when I use 7-14mm on my GM1
Wildcard alternative, similar in price/cost,  look the at the Panasonic LX7: focus down to 1cm, 24-90mm and f1.4.  As a bonus, you might get your GM1 back
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
LMNCT Veteran Member • Posts: 4,908
Hi.  I use the GM5 with 14, 15, 20, 25, 30, 35-100 and 42.5.  I have also mounted the 45-175 and it balances just fine.  The largest lens that I have mounted on the GM5 is the 100-300 and that lens also worked fine, but it did look a bit strange.  The 30 is not too large on the GM5 and it delivers excellent close up shots.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
OP Al Bond Contributing Member • Posts: 620
Thanks.  Going by the simulation site, the 30mm is a similar size to another of my existing lenses, the Panny 45-150.  She has already used the 45-150 with the GM1 and didn't have any particular handling issues.
Interesting.  I haven't heard of this make of tubes before but they seem to be almost 1/2 the price of the Kenko ones.  What is the interior surface of the tubes like?  I know cheap tubes with a shiny surface can reduce contract and image quality.
I do have some cheap manual tubes but never use them because of the inability to change the aperture and, to a lesser degree, the lack of AF.  I could try them to with the 12-32 to get an idea of how the set up would work.
That is definitely a thought and was on my short list of possible replacements when her Powershot G11 started playing up.  However, there isn't anywhere local that seems to stock it and she wouldn't want to buy it without trying it first.
Looking ahead, she may decide to down size from her Canon 450D and 60mm macro lens to a smaller body lens combination - so the 30mm lens is likely to get used even if she didn't like the handling on the GM1.
windmillgolfer
I was curious as to who still sold the LX7. Amazon have it and with the Distance Buying rules and Amazon's returns policy ,you could try and send it back. A next £235 with the current Panasonic Cashback offer.
http://www.amazon.co.uk/gp/product/B008N8NZDK?keywords=panasonic%20Lumix%20LX7&qid=1446217452&ref_=sr_1_1&sr=8-1
My $30 Neewer tubes have ribbed insides and fully functioning electrical contacts...
Well, that got me looking on Ebay! Is that for the 10mm + 16mm twin tube set? I can't find the Neewer ones at that price but the Viltrox alternative looks ok:
http://www.ebay.com/itm/361113942383
I've already got a Viltrox 4/3 to M4/3 adapter which is pretty good quality.
tkbslc Forum Pro • Posts: 17,527
14-42 PZ + macro adapter?
If you switched her to the Panasonic 14-42 PZ lens, then there is a dedicated macro adapter (DMW-GMC1) for it. I suspect that if she is coming from a G11, she may not miss the 12mm vs 14mm as much. I would not buy either brand new, though, as they are a bit overpriced full retail. here is also one for the Olympus 14-42 EZ (Which is very similar) but that lens does not have OIS stabilization so it may not be as good all around.
It's not a whole lot cheaper than the macro lens, but it is less to carry and maybe simpler for someone new to ILC.
Another thing to consider is that the GM1 can take a lot more cropping than a small sensor Canon and stay sharp and low noise. So maybe cropping or digital TC can assist with getting closer. Depends how far you want to go, though.
If you do go with a Macro lens, I might suggest the Olympus 60mm. Yes it is very long. But it is also very narrow, light, and gives a nice portrait telephoto option to her kit. She already has 30mm covered in the kit lens. The 60mm would give double the reach of the 12--32mm.
Here's how they look on camera. I used the 12-50 in place of the 60mm macro because they are identically sized.
http://camerasize.com/compact/#491.459,491.332,491.397,491.335,ha,t
Re: 14-42 PZ + macro adapter?
Thanks for the interesting suggestions.  She has already noticed the advantages of the larger (newer) sensor - images taken at ISO 800 on the GM1 are very usable whereas she never went much above ISO 200 on the G11.
MOD Tom Caldwell Forum Pro • Posts: 46,353
Al Bond wrote:
Hi,
Probably my most favourite lens on the GM1 - works fine.
Tom Caldwell
Ho ho ho ... lets get back on the soapbox
I think there is a lot of preconception of what is cool to use on a small camera body.  In fact the GM series bodies are just smaller bodied proper cameras and as such are perfectly capable of working with pretty well any M4/3 lens and most of the many other lenses that can be adpated to it.
Yet because it might not be thought to look cool does not mean that there is any problem in wearing socks with sandals - the socks can keep sandal wearing feet warm on colder days.
I have been using much larger lenses than the quite diminuative 30/2.8 macro for nearly two years now.  This includes the 35-100mm f2.8 and the 42.5mm f1.2 Nocticron.  I don't care if those that see me doing so think I am an insanely not-cool escapee from a mad-house.  The combinations work extremely well and lens size coolness is not a necessity of life.
Tom Caldwell
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
How about trying this? Easy snap-on function to put on the existing lens. I'm not sure if it will be 100% compatible in terms of secure placement, but worth trying! Amazon's pretty good with returns.
http://www.amazon.com/Raynox-DCR-250-Super-Macro-Snap-On/dp/B000A1SZ2Y
http://www.amazon.com/Raynox-DCR-150-Snap-On-Macro-Lens/dp/B0007KS7D0/
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
windmillgolfer
Re: Ho ho ho ... lets get back on the soapbox
Any lens with GM1 is fine. Agreed Tom.  Socks with sandals. Nah
TheClueless
It's not cool, it's just one other way of getting around an exceptionally poorly handling (due to the compromiss for the size) camera... while entirely eliminating it's purported advantage at the same time. Still, gives you options.
