anomaly with Oly EPM2 and 16 gig SD cards?
Started Oct 28, 2015 | Discussions
alfredo_tomato
alfredo_tomato Veteran Member • Posts: 4,382
I noticed a block appears in some images. See below:
I thought a defective 16gig card was causing the image anomaly, so I went with an older 8gig. No issues.
So yesterday I bought a new 16gig card, and doggonit, it happened again. Does the EPM2 have issues with a 16gig, or is it something with my particular camera.
It doesn't happen often, but it did ruin a very good image last month.
I also lost some images with my 8gig, which was a bummer. It might have been my fault.
Thanks.
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
Olympus PEN E-PM2
n3eg
n3eg Veteran Member • Posts: 3,316
Re: anomaly with Oly EPM2 and 16 gig SD cards?
I would run a disk check on it in the computer, and if that passed I would reformat in camera.
It ain't easy being me, but someone's gotta do it.
 n3eg's gear list:n3eg's gear list
Kodak DCS Pro 14n Olympus PEN E-PL5 Panasonic Lumix DMC-GM1 Kodak Pixpro S-1 OM System OM-5 +73 more
alfredo_tomato
OP alfredo_tomato Veteran Member • Posts: 4,382
I ran disc utility and it checked out. I reformatted it.
The first thing I did was format the card.
James Sherman
James Sherman Senior Member • Posts: 2,480
It's hard to believe it's a camera error that has only bitten you, but that sure looks like a processing bug. Have you confirmed that it looks that way both on the camera screen and with an external viewer? Very weird, though.
If you lose one sense your other senses are enhanced. That's why people with no sense of humor have an enhanced sense of self importance.
 James Sherman's gear list:James Sherman's gear list
Samyang 7.5mm F3.5 Fisheye Olympus E-M1 Olympus E-M5 II Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +1 more
alfredo_tomato
I guess I should preview them before uploading.
My first thought was the editing software, but it only happens with my 16gig cards.
zuikowesty
zuikowesty Veteran Member • Posts: 4,158
My E-PM2 has a Lexar Platinum II 16Gb usually, but I have also used Patriot LX 32Gb without issues.
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Samyang 7.5mm F3.5 Fisheye +11 more
alfredo_tomato
Both 16's are Sandisk. The 8's a PNY.
I'm going to fire off fifty quick images, then check to see if the problem is in the camera, or shows after uploading to my Photos app.
zuikowesty
Are you shooting RAW or JPG? If JPG, try shooting RAW+JPG to compare, and you can then generate new JPGs from the RAWs in camera.
I only shoot RAW, but have generated JPGs in camera on occasion. I've yet to any corruption on SD cards in my mFT cameras, but have seen it in CF and SD cards on other formats, mostly compacts that corrupt the card when battery dies mid-shot.
alfredo_tomato
Raw + Jpeg might be a good idea.
