Dust, separation or fungi?
Started Oct 28, 2015 | Questions
Kurono New Member • Posts: 5
Hello all, I have quite a conundrum and would like better trained eyes to help discern just what is inside my lens.
I just bought a 70-200 f/2.8 IS lens (Canon, MK I) used, and was performing checks on the lens. On the outside the lens seems to be ok, but when inspecting the inner elements I came across some weird dots on (in?) the glass which seems to be almost in the middle of the lens.
At first I thought they looked like bubbles, as they seem to be very evenly spread. My next thought was mold (gasp), but in my experience, mold tends to grow from the sides and looks like little tendrils. Granted, I've seen that mold can look like spots too, but not quite like these.
Anywho, I leave you with the images I took in a hurry right now. In the worst case scenario, I plan to get the lens into maintenance or for appraisal with Canon.
Thanks.
In this image, you can see that some spots are bigger, but those are out of focus (it seems they are on two contiguous elements).
Lemming51
Lemming51 Forum Pro • Posts: 15,278
bubbles?
To me, it looks like little bubble imperfections in the glass. I remember seeing a very similar photo and discussion of this years ago wrt the 70-200 f/2.8L (non-IS? or IS I, maybe the same lens   ) but cannot bring it up with search. I think it was determined to be a non-issue in the optical performance of the lens (but I could be wrong).
here's a similar discussion on the TS-E 24 f/3.5L II:
http://www.dpreview.com/forums/thread/2825122#forum-post-35637678
Thanks.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
dgumshu
dgumshu Veteran Member • Posts: 4,623
Re: Dust, separation or fungi?
Looks like fungus to me.  Fungi secretions will etch the glass coatings and you can't fix it.  If you just bought that lens, you may want to return it if you can.  I always check a lens with a flashlight before buying.  Good luck.
 dgumshu's gear list:dgumshu's gear list
Canon EOS-1D X Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R5 OM-1 +52 more
bed bug Veteran Member • Posts: 3,120
Doesn't look like fungi to me...
Which normally appears as hyphae rather than individual spots.
Regards
Stephen
brightcolours Forum Pro • Posts: 15,885
That is some kind of dust/contamination.
Bubbles in glass do not look like that (and modern lenses do not have bubbles in glass much anymore). And fungus usually starts in a few places and grows from there.
Thanks.
Sammy Yousef
Sammy Yousef Veteran Member • Posts: 4,657
I would err on the side of caution and assume fungus.
If I google "fungus spots on a lens" without the quotes then hit the images tab I see a lot of images that resemble that.
I once had a lens come to me with obvious fungus and a smell that I could only describe as rotten takeaway. (Not all fungus smells but if sniffing the lens makes you cringe that's a good sign). Cost me a bit to post it back but I got the rest of my money back.
Good luck.
Sammy.
My forum postings reflect my own opinions and not those of my employer. I'm not employed in the photo business.
WindwardHaole Senior Member • Posts: 1,550
Since we are all guessing at this point, my first guess is that this is most likely not fungus, which almost always has a tendril or branch-like structure. Unfortunately, if the substance is on the inside elements, the only way to remove it may be to disassemble the lens, a very expensive proposition.
Leigh A. Wax Senior Member • Posts: 1,625
If it's dust, or other foreign matter dry particles, & not tightly adheared, it should move about / change pattern if the lens is "quickly" zoomed in & out.
If the lens will "Push-pull" by gripping the front & "pumping" it a few times, you can look for a pattern change???
Leigh
BlueRay2 Forum Pro • Posts: 14,816
Thanks.
ouch....looks like this lens is toast...it would be expensive to replace those elements!
OP Kurono New Member • Posts: 5
Thanks, everyone. I went with the cautious route and took it to a Canon certified center. Turns out it indeed was fungus, but a very light case of it. The maintenance will be expensive of course (about $150), but most will be covered by the seller (I'll still pay $50, but I guess it's worth it for the lens). No elements had to be replaced, so I guess I kind of lucked out on that.
stratobill Senior Member • Posts: 2,081
You sure did. I lost an L lens to fungus one time, not fun!
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
dgumshu
I'm glad you got it all worked out.
LaszloBencze
LaszloBencze Contributing Member • Posts: 828
$150 for such a repair does not sound expensive to me.
I agree, every camera repair I have had started at $400+
Regards
Stephen
bigd3030 Regular Member • Posts: 177
My 70-200 2.8 non is looks exactly like this. Canon has it and I received a quote to clean it was 414 total. They did not say on estimate if it was fungus or not. I guess my question would be is it worth paying that or just buy a 70-200 new. If it's fungus, is it possible that it will return at a later time ? I did purchase the lens used a year ago, entirely my fault.
Bigd
 bigd3030's gear list:bigd3030's gear list
Panasonic Lumix DMC-FZ200 Canon EF 85mm F1.8 USM Canon EF 70-200mm f/2.8L USM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-S 18-135mm F3.5-5.6 IS STM +1 more
Andy01 Veteran Member • Posts: 5,191
Bigd
The OP hasn't posted anything on DPR since this thread 5 years ago, so doubtful that he/she will see your response (and if they did it is about 4½ years too late)
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
