DP2m: first images, first problems
Started Oct 28, 2015 | Discussions
mclaudio Regular Member • Posts: 264
I started my last thread a long time ago, in the meantime I bought a Fuji X-E1, tested with my short telephoto Voigtlander lens, re-sold it (liked the camera and the color, but not at all the rendering of textures), my DP1s is now frozen with the lens extended (an evident design mistake that Sigma never recognized, this is not serious at all), my DP2 emits strange sounds but it is still working, I decided then to try the DP2m
(•) First images
My first images are accessible following the link below,
**USE UP/DOWN KEY ARROWS OR MOUSE WHEEL TO NAVIGATE**
the gallery (just a collection of images, not a project) is optimized for 1400px wide or wider screens, it works also for smaller screens but you need to rely on the downsizing capabilities of your browser
you can enjoy (I hope) the images and stop here avoiding the bla bla about technical problems
http://www.photografeet.org/2015dp2mfirst.html
(•) First (usual) problems
(1) My main concern regards the purple/green areas in the clouds that I obtain in highly contrasted skies. Following the recommendation found in this forum I tried (in LR5): desaturating the purple/magenta channels; moving the hue of the purple channel towards the blue; using color noise reduction; using local moire/fringe correction. Nothing really works for me, there are some improvements in some cases but the purple/green areas often do not completely disappear, you can find some of them also in the images I posted. Maybe this is linked to the (incorrect) exposure of the photo, even though, honestly, I’m not sure of that. But the exposure is a sort of nightmare with this DP2m. In highly contrasted situations the meter is off up to 2 stops, the live view histogram and the screen preview are totally useless (in some cases the histogram does not change even correcting the exposure of 4 stops, it does not move at all, the same for the preview (my firmware is v1.05, the DP2 is imprecise but it is relatively consistent)) and highlights are quite easy to clip.
(2) My second concern is about micro contrast. In some case it is really too high for my taste, I like better the one of the original DP2. To reduce it I decrease the contrast and the presence (in LR5), but still I’m not completely happy with the results.
(3) The WB and the colors are improved w.r.t. the ones of the DP2. I use AWB that I correct to my taste in SPP, but some times it is quite difficult to find a good WB. I know that somebody hate AWB, but when I try all the other WB options in SPP they are really far from the one I like (in general they have a strong yellowish cast). I never understood if there is a difference to change the WB in SPP or to use directly a specific WB when one takes the image.
Every comment/advice/suggestion is very appreciated. Many thanks in advance.
Claudio
Fujifilm X-E1 Nikon 1 V1 Sigma DP1s Sigma DP2 Sigma DP2 Merrill
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Re: DP2m: first images, first problems
Hello Claudio, I'll let others respond to that. Lin Evans might be able to help.
How about Gaussian smoothing with a fairly low radius? Assuming that LR has it. Have you tried low resolution (never medium) mode? I use it most of the time unless I really, really need high resolution.
There is no difference for the review image in SPP. Either way, WB is set by the values passed as meta-data in the X3F file to SPP. All the WB values are passed so, if you change the WB in SPP, it reloads the X3F using the newly-selected WB's from-the-camera values.
The image in the camera LCD may use different (faster) parameters. You can check that by comparing the X3F embedded JPEG to a JPEG conversion saved from SPP. Someone here will know how to extract the embedded JPEG. There are several methods; I use FastStone Viewer but I think it can be done out of SPP - anybody?
We seem to differ considerably as to WB (I have the SD1 Merrill). I never use AWB, which is easily fooled by many types of scene. I shoot with the in-camera WB selected to my best guess for the scene. Then, in SPP, I color-pick a neutral object in the area of interest in the captured image. I always shoot raw.
Ted
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
marcodadofoto
marcodadofoto Senior Member • Posts: 2,982
Ciao Claudio,
first: always beautiful and "moody" images.
second: I'm not a techie, so Ill share with U some thoughts about the merrills.
Merrills have that great fault (the green/magenta blotches n the underexposed areas). I never succeded in really get rid of them. They particulary hurted me as I often do low light photography and with the Sigmas that's really a challenge. Seems anyway that the way You tried to minimize them are right.
Merrills, on the other hand, have that "wow" or "3 D" factor, part of it is given by the "inner" accentuation of the microcontrast and of the shadows (have You realized how shadows are really deep and black?). I don't condier it a falut, it's part of the Merrill look that I personally appreciate. In Your images, imho, I would not see badly some more contrast.
Anyway, to act on that look You could try in Sigma Photo Pro to set on -1 the fill light (but it doesn't always work well), or - better - in Photoshop using not only the contrast levels but also  working on the medium tones to reduce the effect.
As I said I'm no techie so I'm afraid that all.....
marco
digi2ap Contributing Member • Posts: 887
(•) First images
My experience when starting with the Merrill was that it took a long while to change habits from the pre-Merrill cameras and I still there is a way to go to get the best out of the Merrill files.
With regards to the blotching - I use ISO 100 and with careful exposure find that I can now have the chroma in SPP down/off (slider moved fully left) and have very little purple green noise. If I need to I will use the colour noise reduction (slider moved to about 15) in ACR or Lightroom to fix.
Micro contrast can be too high with some subjects - my approach after all else fails in terms of good exposure, reduction of contrast, levels adjustment etc is to increase the luminance noise reduction in ACR or Lightroom which smoothes the image.
WB is generally best, I find, if I make a Custom WB using an Expodisc.
www.anthonypalmer.me
 digi2ap's gear list:digi2ap's gear list
Sigma SD15 Panasonic Lumix DMC-GH3 Sigma 10-20mm F3.5 EX DC HSM Sigma 18-35mm F1.8 DC HSM Art Sigma 50-100mm F1.8 DC HSM Art
OP mclaudio Regular Member • Posts: 264
many thanks Ted for your help, LR has no Gaussian smoothing, I could try another program, but I'm quite lazy on that, the workflow for merrill files is already quite complex and slow
no, never tried, but I will
ok, then, as I supposed, WB is just a software process on sensor output
yes, I know, I never trust the LCD that indeed is almost invisible outdoor
this makes sense especially if you have a series of very similar images because you need to adjust the WB once, but I often chose just one or two images, the ones I like better, in a series
I always try that, but often it is very difficult to find neutral objects in landscapes even though sometime some stones work
many thanks again
Claudio
Ted
marcodadofoto wrote:
Ciao Claudio,
ciao Marco, grazie mille per i complimenti e i consigli, molto apprezzati
me too
The green/magenta blotches in the shadows do not really disturb me. In addition, for these blotches, the color noise reduction in LR5 works quite well. What really gets me sick are the quite huge purple areas in the skies, these do not seem to me the same blotches one finds in the shadows, they are present also in the highlights. What is strange is that in the Develop module of LR5 (using ProPhoto RGB) these purple areas are much less visible than in the Library module that, if I correctly understood creates sRGB previews. I don't know if the problem is also linked to mappings/translations between color spaces.
the (micro)contrast is a matter of taste, personally I don't like very contrasted and super sharpened images, but this is just me, there is nothing wrong with the approach of Merrills
I tried negative values for fill light, but it is quite difficult to manage this parameter
I don't have photoshop, but I can try to work on the middle tones in LR, many thanks
many thanks again Marco
ciao
Claudio
marco
Anthony,
many thanks...
I'm not referring to the purple noise in the shadows, I'm talking about quite huge purples areas in the skies. The chroma noise in LR5 does not affect these purple areas.
thanks, I will try that, I always set the luminance noise at 0
I know, but I'm not a photographer, I'm a walker with a camera, I'm outside for walking and enjoy the landscape not for taking pictures, and the Expodisc starts to become too elaborate for me.
Many thanks again
Claudio
jande9
jande9 Senior Member • Posts: 1,707
If these are your first efforts with the Merrill I am impressed.  They are beautiful.
Jan
 jande9's gear list:jande9's gear list
Canon PowerShot A650 IS Sigma DP1s Sigma DP2 Merrill Panasonic FZ1000 Sony Alpha NEX-7 +4 more
Hmm I'm not sure I have seen much of these purple areas in my own work. Are you using ISO 200 rather than 100? Are you using Adobe RGB colour space?
Fair point except I'd add 'a walker with a camera' who takes very fine photographs!!
xpatUSA
Claudio, is there anywhere you could put the worst X3F on the web so I can download it for analyis in RawDigger and for converting in RawTherapee?
I would post the conclusions, if any, here for your information of course.
Also there is Kalpanika, have you tried it yet?
Ted
Jan
many thanks Jan
the phenomenon is more evident at iso 200 or 400 but it is present also at iso 100
I'm uploading a X3F file (iso 100) where there are these purple blocks in the sky, I will post the link in few minutes answering to Ted
I export from SPP to 16bit .tif in ProPhotoRGB, and then I work in LR5, but again I'm not really a techie, and I have to add that my monitor is not calibrated (event though I checked with other monitors and I see the same problem)
many thanks Anthony
ciao
Claudio
sure Ted, many thanks for spending some of your time in trying to help me (and maybe somebody else with the same problem)
you can download a .x3f file (iso 100) where I see the phenomenon (it is exposed to preserve the highlights in the white stones on the right, I know it is slightly under-exposed and this probably accentuate the problem, but in highly contrasted scenes is always difficult for me to perfectly expose with this camera)
http://www.photografeet.org/photos/x3f/_P2M0533.X3F
you can also download the .jpg of the same file I obtained by adjusting the .x3f file in SPP 6.3, exporting it as .tif 16 bit in ProPhoto RGB color space, importing the .tif in Abode LightRoom5, and exporting it from LR5 in sRGB without doing anything
http://www.photografeet.org/photos/x3f/_P2M0533.jpg
no, I'm sorry, I'm not a techie, with Sigma cameras the workflow is already relatively elaborate, I would prefer to avoid to add another step (even because I normally adjust quite a lot of parameters in SPP)
many thanks in advance Ted
ciao
Claudio
p.s. I will be offline for the next three days
Ted
xpatUSA
Preliminary Analysis
Here's the X3F opened in RawDigger's RGB render view:
There are your purples and greens in all their glory. RawDigger uses a fairly simple conversion from raw to RGB and includes none of the fancy stuff that SPP applies even before you see it's review image. And, to me, that says there is a LOT of fancy stuff needed by the DP2M
I also opened the X3F in RawTherapee:
I used RT's SD1M 'overcast' input profile. Still, the obvious discoloration looks depressingly familiar. RawTherapee uses conversion code derived from Coffin's DCraw and clearly does not have SPP's fancy bits either!
I have to say right away that none of my SD1 Merrill captures come even close to being that bad - when opened in either RawDigger or RawTherapee. To me, that points the finger firmly at the DP2M and maybe it's shorter lens distance from the sensor and different lens construction than those for the Sigma mount. Glad I sold mine
My conversion in SPP 5.5.3 looks much like yours:
That locks you into SPP for conversion, IMHO, or perhaps giving Kalpanika a try (I lost my copy in my latest computer death). Sometime, I'll reload it and see what it comes up with in your X3F or maybe someone here can give it a shot and post their findings.
Ted
Re: Preliminary Analysis
many thanks Ted... it seems that the purple is real, not just my eyes/screen
I will try to pay more attention to the exposure, but, again in highly contrasted situations this is difficult and in any case some zones of the skies will result necessarily under-exposed, the fog is still worst
maybe, I will end up to use the dp2m (that is my only camera) only for B&W
but this is a pity, I find the colors much more natural than the ones of the original DP2
thanks again, ciao
Claudio
pedrolito Regular Member • Posts: 389
hi,
I was just curious and tried out the xf3-file.
I converted using SPP (values from top downwards: -0.5/0/0/0/0/-0.8/0.4, daylight) then edited in RT 4.2.447 and corrected the wb there also.
What I found was some red fringes but no purple blotches or clouds. None. Period.
You should try again. The photos are great, your cam is fine.
Cheers
P.
pedrolito wrote:
hi,
Cheers
P.
I too developed the X3F and couldn't find any purple discolouration. This is curious.
Saved X3F Settings:
Exposure: -0.2
Contrast: -0.5
Shadow: 0.0
Highlight: +0.2
Saturation: -0.2
Sharpness: 0.0
X3 Fill Light: -0.1
Marek L Contributing Member • Posts: 508
I've converted your image in SPP 6.3 in neutral colour mode with no adjustments and there is no  significant blotching visible on hi-res screen.
The underscore  in the file name suggests  that you're using AdobeRGB colour space in camera settings, instead of sRGB, and the exif confirms that.
half size jpg from spp
full size jpg from spp
what can be seen as uniform colour area in the sky/mist is a result of jpg interpolation of pixels with no signifcant colour difference into a one blop . That's how jpg compression works  to reduce the file size .
 Marek L's gear list:Marek L's gear list
Fujifilm FinePix F30 Zoom Fujifilm FinePix S602 Zoom Sigma DP2 Sigma DP1 Sony Cyber-shot DSC-R1 +28 more
xpatUSA
Can I ask what JPEG quality setting you used for the above image?
Reason I ask is that EXIF for yours says YCbCR 4:2:0 meaning that it has sub-sampling but Claudio's JPEG says YCbCR 4:4:4 meaning it has no sub-sampling and, therefore, no interpolation. That puts his SPP slider setting at 9+ and yours probably less?
No disrespect intended to your raw conversion . . .
Sorry, please forget the question, your original size is in 4:4:4 (not sub-sampled) same as Claudio's. Apparently, DPR uses lower quality when downsizing the original to the post image. Sure fooled me
Ted
Roland Karlsson Forum Pro • Posts: 30,033
mclaudio wrote:
(•) First images
WOW - it seems you have used at least one other camera before I am impressed. Nice images.
The purple/green is somewhat mysterious. Sometimes there is none, and then, all of a sudden you have lots of it. I know why it is there, but I have a hard time predicting when it is a risk for it.
For some mysterious reason, Sigma has chosen to (by default) enhance local contrast greatly for Merrill sensors. In later versions of SPP you are supposed to be able to "fix" that by using portrait mode. OK - that gritty, dirty look when the local contrast is exaggerated has its charm, but gets tiresome in the long run IMHO. BTW, it is not really micro contrast, which is at pixel level, but rather like using "clarity" in Lightroom, adding higher contrast to textures.
Colorwise, the Foveon sensors are strange beasts. White balance is not, like for RGB cameras, a matter of balance between the RGB channels. There are different conversion matrices for each white balance. Many have been the problems seen when trying to fix colors. Now, the later cameras (e.g. Merrill and Quattro) are better than ever regarding color.
So, if you have a strange lighting, you'd better measure it using AWB or using custom WB. Can be a bit tricky otherwise.
/Roland
Kalpanika X3F tools:
https://github.com/kalpanika/x3f
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Sony RX100 III Pentax K-3 Pentax K-1 +14 more
