GX-8 great specs but MFT 100-300 lens not? (for Birding)
Started Oct 28, 2015 | Discussions
alanmcdonley
alanmcdonley Regular Member • Posts: 254
My wife gets phenomenal detail from her 24MP APS-C sensor and 55-300 (450mm eq.) lens, but from a weight standpoint she is at her limit.  She wants more reach without losing detail but does not want to carry the Nikon 80-400 weight.
On paper (and in the DPReview Studio Compare tool) the GX-8 seems to be the closest MFT camera yet to her D5300.  But, when I compare the Dx0 lens scores of her Nikon lens (score 15, sharpness 9) to the Panny 100-300 (score 10, sharpness 5), it doesn't seem like she will be happy.
Any birders want to weigh in?
Birding with FZ200, Wife shoots with D5300
 alanmcdonley's gear list:alanmcdonley's gear list
Nikon D7500 Nikkor AF-S 300mm f/4E PF ED VR
Nikon D5300
Bob657 Veteran Member • Posts: 3,486
Re: GX-8 great specs but MFT 100-300 lens not? (for Birding)
You are correct, the 100-300 has limitations, among them the fact it can only provide bursts of 2-3 fps even if the camera does more.  The Oly 75-300 is a more recent design but wont have In lens IS, although I think the GX8 does have some in body stabilization so it may be ok.
Bob G
Visit my website at:
http://bobgreenberg9918.zenfolio.com
 Bob657's gear list:Bob657's gear list
Sony a6400 Sony a7R IV Sony FE 100-400mm F4.5-5.6 Tamron 18-300mm F3.5-6.3 Di III-A VC VXD
alcelc
alcelc Forum Pro • Posts: 19,003
EM1 & 40-150 f/2.8 + 1.4TC?
Personally not a fan of Oly, but in your wife's situation, EM1 + 40-150 f/2.8 & 1.4x TC (roughly 420mm eq FF) might offer the needed f/stop speed, premium IQ, weatherproof combo, fast AFC, better stabilization and similar reach. Total package would weigh around 1.55Kg.
Sadly Panny 100-300 is slower, an older design doesn't support high burst fps, slower AF and not compatible to GX8's EM5-II rival Dual IS. Would it support DFD for faster AF-C is also not cleared.
Unless waiting for the forthcoming Oly 300 f/4 OIS or the heavy weight Panny Leica 100-400 next year, Oly might have a slightly better edge although a bit bigger and heavier than GX8.
Albert
rashid7
rashid7 Veteran Member • Posts: 7,011
furthermore, with the tendency towards shutter shock, one needs to use Eshutter often.  It is a fine lens, and by all accounts a superb camera, but not for action shots.  But 4k photo should b a nice option!
Keep it fun!
Yannis1976
Yannis1976 Veteran Member • Posts: 6,309
Re: What about 45-200?
Its 400mm at 35 and much lighter than the 100-300. You can find it in ebay at about 200€ or even less in USA.
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
gary0319
gary0319 Forum Pro • Posts: 10,540
Panasonic 100-300 burst rate
I guess I must have a really strange copy of the 100-300 since I routinely shoot it at all burst rates on my Olympus E-M5 II with good results. Here's two shot at 10 fps. Tight crops on both
Below shot with Panasonic 100-300 on an Olympus E-M10 + 2x internal teleconverter ( 1120mm Equiv)
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
Vesku Senior Member • Posts: 2,964
Pana 100-300 is optically very good. It is 600mm ff eq so the air between distance object and camera is bigger quality factor than the lens itself. When shooting at close distances the image at 300mm is razor sharp with my GH4 and Pana 100-300mm.
To get very sharp and clean images with MFT and 300mm you must use low iso, f 6.3-8 and shutter speed 1/500-1/1000s. Sadly it is possible only if the sun is shining.
Advent1sam
Advent1sam Veteran Member • Posts: 9,089
Sadly, you are stuck at a point where Panasonic rather than make a better 100-300 went with a new 100-400 monster, not released until next year! The Oly is a good alternative though and on an em-1 will score 12 and 6, but the scores are very subjective!! Honestly, the em-1 is now at a great price and the 75-300 is very flexible, again would of preferred Oly to make a 100-300 and faster 5.6 at the long end, why did they do this??
I think I'll swap my 100-300 for the 75-300 too, I have an em-10 ii and a gx8 and there is no real increase in detail from 16mp to 20mp that you will be able to see
Martin.au
Martin.au Forum Pro • Posts: 14,339
I would place money that the differences between the 55-300, on a 24MP APS-C, and one of the 300mm lenses on M4/3s will be negligible for birding, where you most probably are working at maximum focal length and have to crop anyway.
In fact, I suspect that the Oly 75-300 will be better, as it's a rather tidy piece of glass for the cost. It's also remarkably lightweight.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
gary0319
Maybe not an exact comparison, but my wife gave up her nearly new Canon 7D Mark II and Canon 100-400 in favor of the Panasonic 100-300 on her Olympus E-M5 II after seeing little or no difference in Image Quality at 100%. Reach is about the same, given the difference in sensor size (about 600 Equiv.)
We both get more keepers hand held just because of the smaller form factor and lighter weight. No going back.
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
5
I would suggest that you stop reading specifications and look at examples. I've said it a few times on here already but I'll repeat there are lots of people out there getting better bird pictures than me. They are easily recognisable by the very large object that sits in front of their cameras which gives them a bad back often accompanied by the necessary tripod.. Also another great id feature is their very empty wallets. I'm happy to compare my G7 and 100-300 output with anybody at a level playing field of weight and cost.
If you're wife gets much better shots than these than yes she will be disappointed and will need to stick to her DSLR or wait and see what the Oly 300mm and Panny 100-400 are like, although pf course the price differential is likely to be huge.
A few recent shots and many more in my Picasa link below
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
jim stirling
jim stirling Veteran Member • Posts: 7,356
The D7100 and D7200 have a 1.3x crop mode I don’t know if the D5300 shares this option. This gives you the same 2x crop factor as mFT. The Nikon 55-300mm is a very cheap low end lens so I wouldn’t expect miracles from it. High quality long telephoto zooms are invariably larger heavier and more expensive. So something has to give
The lens scores are a combination of sensor + lens where the 24mp has an advanatge of the mainly 16mp mFT cameras. Many mFT lenses are excellent quality. The 100-300 is capable of very decent results I think a lot of casual shooters forget the impact of the effective focal length. This link gives good tips on how to get the best from the lens.
https://www.youtube.com/watch?v=RgzLfLa2acA
 jim stirling's gear list:jim stirling's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Nikon D810 +12 more
LMNCT Veteran Member • Posts: 4,908
The GX8 body is excellent, but the 100-300 is an acquired taste.  It requires a learning curve and it also requires and aperture of 7.1 when out at full extension.  If you do not support the lens from below with the left hand it can be a problem.  The OIS in the lens is very good if you learn to work with it.  At the present time, it is the best telephoto for wildlife which is offered by Panasonic.  There is another lens in the wind, but who knows when the 100-400 will become a reality...and how heavy it will be in weight and price.  I should add that I have gotten some very sharp shots at 300mm and I know that the lens is capable of d 'delivering'.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
oldbaldeagle Regular Member • Posts: 356
I'm sorry if I sound rude Trevor but I wont be giving up my d7200 for some of those shots. I am waiting to pair my gx8 to one one of the new teles before getting rid of the 'big' stuff. Personally and I stress personally I find there is a lack of feather detail that is available with the bigger systems. Here's hoping for the new lenses.
 oldbaldeagle's gear list:oldbaldeagle's gear list
Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM
Chris R-UK Forum Pro • Posts: 22,843
Re: Panasonic 100-300 burst rate
Are you shooting using C-AF or S-AF?
The 100-300mm problem occurs when shooting at rates over 2-4 fps using C-AF.  The type of diaphragm used in the older Panasonic lenses cannot open and close fast enough for high speed C-AF.
My 100-300mm could only shoot at 2-3 fps in C-AF mode which is why I changed it for the Olympus 75-300mm.
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
OM-1 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
Trevor Carpenter
No need to apologise. As I said above there are plenty of solutions better than mine just not at the weight that I carry with a total solution cost of < £1000.
dontfret
dontfret Senior Member • Posts: 2,340
Great point Trevor - stop looking at the specs and second opinions, start looking at the results. It's the user not the equipment that makes the image. Granted every camera/lens combo has strengths and limitations, but you have been producing images of this caliber back to the FZ50 + TCON days. Artist makes best use of the equipment, ain't the paintbrush that makes the artist.  For my aging back/neck and wallet FF never was an option, and I also have gotten some great images over the years with FZ and now mft equipment, at a great size/weight/cost balance.  I've been on birding walks/preserves next to someone with the FF Canon 100-400 white bazooka and my back just aches looking at it.  Yes, the feather detail is better, but I'm satisfied with what I carry and come home with.
On a related note I just ordered the German tripod collar for the 100-300 to be able to effectively use a tripod with central balance and get better stability.
Rich
Take many pictures - a few are keepers, the rest are are lessons.
 dontfret's gear list:dontfret's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-G5 Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +12 more
gary0319
Good to know, since I have been shooting only in S-AF, and have been planning to try the C-AF setting this afternoon. I'll let you know how it works out with the E-M5II.
Thanks for the heads up....
Gary
Advent1sam
Note, the OP has a 55-300! Not saying its good or bad but it really is only decent and at 400mm'ish equivalent the 75-300 and 100-300 will be far better wide open and much better stopped down a tad, the 75-300 is better wide open at 600mm than the 100-300 but then it is 6.7 vs 5.6 but even stopping to 8 its not as good as the Oly. Personally, I think the 75-300 is the lens to go for and I will probably pick that up instead of my 100-300 which is consistently only decent and never has any bite to it. If you really want a good 600mm option for the Nikon, the new 80-400 is excellent, but it's very very big and aint cheap and probably needs to be paired with larger bodies too.
007peter
007peter Forum Pro • Posts: 12,933
[counter] GX8 + Panny 100-300 are BIG/BULKY, no weight saving over Nikon
I hate to be the Devil's Advocate, BUT.......I couldn't help point out that:
  • Nikon D5300 is one of the smallest lightest DSLR ever produce
  • Nikon 55-300mm is one of the smallest lightest 300mm zoom ever produce
then you go ahead and pick
  • Panasonic GX8: one of the biggest/bulkiest m43 camera ever produce
  • Panasonic 100-300: perhaps the bulkiest telephoto lens ever produce
I couldn't find the image of Nikon 55-300mm, but its only a tad longer than 55-200mm VR
Also keep in mind is much easier to shoot ACTION oriented BIF with an OVF in a DSLR than using EVF.  I would heavily advice you to look twice and consider a differnt M43 package instead.  For example: a smaller/lighter Panasonic G7 + vernearble Panasonic 45-200mm
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
