Olympus primes: which to keep?
Started Oct 26, 2015 | Discussions
Atsel
Atsel Regular Member • Posts: 265
Now I have got a set of Olympus prime lenses, all are f/1.8: 17, 25, 45 and 75mm. I am sure that I will not have enough time to use all of them. Of course I have some slight preferences already, but preferences change sometimes.
Other Micro Four Thirds lenses I have are excellent 12-32/3.5-5.6 and 35-100/4-5.6 Panasonic zooms, which are the perfect match with my Panasonic GM1 (I will use this body for sure with all my lenses). They are sharp and stabilized.
From my experience I know that 12-32 is better in low light than 17/1.8 thanks to OIS. I think that I will use primes mainly for portraiture (not only head and shoulders portraits, but also environmental), but maybe also for street photography.
So the question is, which lenses would you keep and why?
 Atsel's gear list:Atsel's gear list
Olympus PEN E-PL2 Nikon Coolpix P330 Samsung GX-20 Canon EOS 550D Panasonic Lumix DMC-GF3 +42 more
Impulses Forum Pro • Posts: 10,039
Re: Olympus primes: which to keep?
I would think the 25 & 45 are ideal for what you intend to use your primes for... The 75 is more of a specialist but it's FL still makes it unique. The 17mm is the only one that could be considered semi redundant focal length wise, some people like shooting with both a 35 & 50 equivalent but I've noticed most people prefer one or the other.
The 12-32 gives you an even wider view and OIS, tho sometimes it won't always be the best substitute for a wider aperture, still, the 17 seems like the most likely candidate to shed.
I didn't force myself to choose between 17/25 since I chose the 20/1.7, I do borrow a 25/1.4 sometimes for it's unique look and AF speed but I don't think I'd like the mental juggling involved with constantly choosing between a couple primes in that range. I've lusted after the 75 but I'm not sure I'd use it enough to justify the price...
My trio of primes are the 12/2, 20/1.7, and 42.5/1.7 but I do like shooting wide in general. Having three for low light and social situations seems like enough to me tho, again, more would involve more decisions.
My 2c, it's ultimately personal preference but hearing other's tendencies definitely helps at times.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
addlightness Veteran Member • Posts: 3,641
If you don't have plan to acquire another m43 body with IBIS, then the 17mm (because you already said the 12-32 is better) and 75mm because being longer in FL and physical size, it's going to be worse than the 17mm on a non-IBIS body (like your GM1).
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
Skeeterbytes Forum Pro • Posts: 23,186
I have three of the four, lacking only the 17. I would rethink the prime vs slow zoom at 17 because while you may be able to handhold them on par, the 17 gives you stops more ability to raise your shutter speed and freeze subject motion--something IS cannot do.
Guess I'm no help at all in deciding what lens to ditch.
Rick
Paulmorgan Veteran Member • Posts: 9,499
I`d keep the 17 and 45mm.
traveler_101 Senior Member • Posts: 2,203
+1
17 because you say you are interested in street photography. 45 for portraiture.
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
Atsel wrote:
Now I have got a set of Olympus prime lenses, all are f/1.8: 17, 25, 45 and 75mm. I am sure that I will not have enough time to use all of them. Of course I have some slight preferences already, but preferences change sometimes..
17mm, 45mm and 75mm.
That's close to the set of primes I usually carry. That gives me a wide array of focal lengths, but not too close together. I don't use the 75mm quite as much as the 17.5mm and 42.5mm, but I'm always glad when it's there!
I tend to use my 25mm when going out with only one lens.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
leggeron Senior Member • Posts: 1,077
Frankly i wouldn't sell any of those. But if i had to, maybe just one of the 17mm or 25mm and keep the other. Another option is to sell both the 17 and 25 if the zoom satisfies your needs enough.
** I usually post from my phone so please excuse any typos, inappropriate punctuation and capitalization, missing words and general lack of cohesion and sense in my posts...
______
http://www.flickr.com/photos/leggeron/
Just so you know how good/bad I am at this.
 leggeron's gear list:leggeron's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GH1 Panasonic Lumix DMC-GF1 +14 more
SpinOne Veteran Member • Posts: 4,059
At this point, they're not going to lose any more value. Why not shoot with them for a little while, and see which ones work for you?
jwilliams Veteran Member • Posts: 6,400
Sell 17 & 45 and replace with Pany 42.5/1.7.  I have a Panny 42.5 on its way.  The Oly 45 is great, but no OS on it so I'm swapping mine for the Panny version.  The 25 is a great lens I hear (don't have that one) and is a good fast normal lens even if it is lacking IS.  The 75 as you know has great IQ, but a FL that is sometime difficult to use.  If you are using it enough then definitely keep it.  It seems the 17 isn't that useful to you so let it go.
I find the most useful lens to compliment my GM1 and 12-32 is a 45mm prime.  I have been using the Oly and will switch over to the Panny 42.5 because of the IS.  The GM1 with 12-32 and a 45mm prime really takes care of a lot of situations.  Really just about anything that doesn't require long FL and you have the 35-100 for that.
Jonathan
Elemental Photography Senior Member • Posts: 1,094
Make more time to shoot!
Atsel wrote:
Now I have got a set of Olympus prime lenses, all are f/1.8: 17, 25, 45 and 75mm. I am sure that I will not have enough time to use all of them... So the question is, which lenses would you keep and why?
My first thought is to solve the problem by shooting more but I understand if that may not be possible.
My second thought is to look at what you have used the most.  If you have Lightroom or something similar you can filter your shots by lens and quickly see which lens gets the most use or produces the most "keepers". Your style is unique to you and your actual usage is more important than random opinions on the internet.
If you still want random opinions on the internet, you've come to the right place!  Personally, I'd say sell the 75mm.  It's likely worth the most so you'll get the most money back, and it's also (in my opinion) the most specialized lens with the narrowest usage patterns.  I'd keep the others as an excellent, versatile trinity of primes.
A photograph is a creative interpretation of reality.
 Elemental Photography's gear list:Elemental Photography's gear list
Pentax Optio WG-2 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GH3 Panasonic GH5 +8 more
Ulric Veteran Member • Posts: 4,559
I would keep all of them.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Olympus PEN-F Panasonic Lumix G 20mm F1.7 ASPH +13 more
aliasfox Senior Member • Posts: 1,375
If I'm going on a trip where I'll have time to shoot, this is what I would bring:
- One lens: 25mm. Best all-rounder for me.
- Two lenses: 17mm and 45mm. Better for wide shots on narrow streets, 45mm good for longer shots.
- Three lenses, in a city: 12-32, 17, 45. 12-32 outdoors, 17 and 45mm for indoors or night time. Faster aperture freezes motion, IS does not.
- Three lenses, outdoors/hiking etc: 12-32, 40-150, 25mm. Broader FL coverage for daylight, favorite focal length for night.
- Four lenses: 12-32, 40-150 (in your case, 35-100), 17, 45mm. Two lenses each for daylight and night time.
I rarely bring the 75mm along, but when I do use it, it's glorious.
Basically, my opinion would be to keep all of them.
 aliasfox's gear list:aliasfox's gear list
Olympus XZ-1 Olympus PEN E-PM2 Olympus E-M1 Panasonic Lumix DMC-GM5 Olympus E-M5 II +17 more
Johnny The Greek Regular Member • Posts: 251
I pretty much agree with the folks saying keep 'em all.
Nice problem to have, actually.  But if it were me, I'd probably ditch the 45 and keep the 75, both being excellent but the latter being hailed as one of the best lenses on the market PERIOD.
 Johnny The Greek's gear list:Johnny The Greek's gear list
Olympus PEN E-PM2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +10 more
n3eg
n3eg Veteran Member • Posts: 3,316
I would keep them all.  I have the 3 Olympus kit lenses and the 25mm, along with manual 18mm, 24mm, 50mm (2), 135mm, and 500mm primes.  You can never have enough lenses - unless of course you're looking to sell them so you can buy more lenses.
It ain't easy being me, but someone's gotta do it.
 n3eg's gear list:n3eg's gear list
Kodak DCS Pro 14n Olympus PEN E-PL5 Panasonic Lumix DMC-GM1 Kodak Pixpro S-1 OM System OM-5 +73 more
john isaacs Veteran Member • Posts: 8,443
Keep them all; they are the tools for shallow DOF for subject isolation.
Robert Garcia NYC Senior Member • Posts: 2,200
I like the 17 & 25 out the ones you listed there.
Andersonm Contributing Member • Posts: 954
The 45 is optically excellent, tiny, very fast focusing - and it's also quite cheap, which is good when buying, but means that you get less when selling. It's a good reason to keep it.
With that as a starting point you have to assess: do you need the 75? It's a great lens, but really depends on the need to dispose of some.
Personally, assuming no zoom lenses, I would probably be happy with just the 45 and the 17. I've found that 25 is too constraining in a number of situations.
 Andersonm's gear list:Andersonm's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 20mm F1.7 II Panasonic Leica DG Summilux 15mm F1.7 ASPH
