Canon 35mm f/2 IS vs Sigma 35mm f/1.4 Art bokeh comparison
Started Oct 21, 2015 | Discussions
kotmj Contributing Member • Posts: 571
Re: I hear what you're saying, but...
kotmj wrote:
Peter Karbe of Leica said in an interview on the 50/2 M APO that what they tried to achieve with it that was different from most manufacturers is that the MTF needs to fall off steeply away from the plane of focus. That is, the object in focus has great macro and microcontrast -- very high and level MTF curves -- but that the objects infront of and behind the plane of focus have intentionally bad MTF curves. The out-of-focus areas have low contrast and resolution. This difference in contrast between the object in focus and those OOF is what makes for the pop.
He further said the Japanese would never think of doing this.
Leica has had different philosophies in this regard over the decades. Mandler had a piece published where he stated that in what he called "pictorial" photography, even the OOF areas should have high contrast.
Maybe Sigma caught on to Karbe's thinking, or arrived at it on their own.
...the MTF curves measure resolution on the plane at the focal point that runs perpendicular to the line of sight.  If the MTF curves show lower resolution from the center, this could mean the lens sharpness drops off as you describe above (which is a good thing, in my opinion, for central composition wide open) or it could indicate strong field curvature.
Either way, the MTF curves should flatten out as one stops down, becoming sharper across the frame and at top form by f/4 (f/5.6).  The Sigma 35 / 1.4A is a wonderful example of such a curve, although one might argue that lower resolution at the wider apertures in the periphery would have been more desirable.  The 35 / 2 IS, however, would have benefited from greater sharpness in the center at the wider apertures, and, like the Sigma, perhaps a bit lower periphery resolution at the wider apertures.  However, the strong vignetting of the 35 / 2 IS at the wider apertures may serve to give a similar effect.
So, to recap:  an ideal situation with regards to shallow DOF, sharpness, and pleasing bokeh would be near peak sharpness in the central portion of the frame right from wide open, with resolution falling off from the central portion of the frame to the corners as a function of the lens sharpness rather than strong field curvature.  As one stops down, the corner performance steadily improves until it is at top form by f/4-f/5.6 and close to the center performance.
No, no, no. Peter Karbe was talking of MTF outside the plane of focus. Not your father's MTF. He was talking about the contrast and resolution of the bokeh, in particular, how both decrease very rapidly just in front of and behind the plane of focus. This is MTF of areas never published, ever.
He was aiming for standard focal length lenses that shoots like large aperture telephotos.
Great Bustard Forum Pro • Posts: 45,641
OK, sure -- my bad for addressing a different point.
Yes -- I get that, and do not disagree.  Thanks much for correcting me!
markodarko
OP markodarko Regular Member • Posts: 198
Re: Thanks for the experiments
BAK wrote:
Your shots are the best examples I've seen showing the difference in contrast between lenses.
I note the Canon's background is brighter and richer. Red plant on the right edge, and the orange whatever is significantly different in the pix from the two lenses.
The Canon is a great lens, don't get me wrong - especially at f/4. I think the colours are more pleasing to my eye at the same WB. Check out the pale spruce top on the guitar. It has ever so slightly a warmer look to it. Nothing that's so drastic that can't be tweaked in post for the Sigma, of course but both lenses were set to the same manual WB for the shots to keep tests consistent.
So perhaps the lower contrast is what makes the foreground "pop."
It could very well be, or a combination of factors I guess.
Anyway, thanks for your efforts.
Thanks for your kind words, and you are most welcome.
Mark.
markodarko
Re: v2.0 of the Canon vs Sigma Bokeh Test (indoors)
Great Bustard wrote: To be honest, I think we are all picking nits, here -- it's not the equipment that's holding people back from getting great photos.
Amen to that. I guess what I didn't disclose as to why I was looking at the Sigma in the first place over the Canon is that as I'm shifting my main focus to cinematography and so I figured that the extra stop of light from f/2 to f/1.4 could be a real asset for me in dimly lit locations whilst maintaining a low ISO, the "better" (in my opinion) bokeh is a bonus which I thought I'd share as it'd be interesting to photographers.
On the back of this Sigma tests I've done (these being just bokeh tests) I've decided to keep it because I think the extra stop will genuinely be useful now that I know it's still usably sharp wide open with less vignetting than the Canon has at f/2. I've also ordered the Sigma 24mm f/1.4 A and the Sigma 50mm f/1.4 A for those reasons and the reason I never went for the Canon 35L II is because I can get all three for only a little bit more than the 35L II on its own. It's a no-brainer really.
My other concern with the Sigma when I ordered it was how well it would cope with manual focusing with such a short throw (I think it's around 100º) but as it turns out it's actually ok as the focus ring is very smooth and precise with zero slack - which is more than could be said of my recently sold 17-40L! ;-))
I could post some 24mm and 50mm comparisons in the same vein as this one if anyone's interested but alas my comparison lenses are now limited. My other half has a nifty fifty, a 24-105 f/4 L (so could do 24 and 50 on that one) and a 16-35 f/4 L (24mm). Not the best choice of lenses to compare against really as aside from the nifty fifty they're all f/4, but if anyone's interested, let me know.
Mark.
Tiosabas Forum Member • Posts: 83
Great comparisons, thank you. Its strange Ive looked at hundreds of images on flickr from each of these lenses and I always prefer the bokeh from the Canon when viewing web images. But in side by side comparisons that I have seen including this one the Sigma is always the clear winner...weird. I do believe that bokeh cannot be judged at 100%, It can only be judged when viewing an overall image which is why your samples work so well. I am really surprised that the Sigma shows so much more bokeh at the same apertures. However, I have always noticed that the Sigma produces double lines in bokeh areas which has put me off it. I will definitely have to revisit this comparison when I finally do upgrade my original 35 f2 which does not have great bokeh but with which I can get great images btw.
I like the Sigma 24A it seems to have better bokeh than the 35A and its a nice size/weight.
markodarko
You are most welcome.
Could that perhaps be because with the 24mm, one will be closer to the subject due to the wider angle of view, and hence create "more" bokeh, or do you mean that it creates better bokeh if both lenses were taking a picture of the same subject from the same distance?
As it happens, I have 2 x Sigma 24mm Art lenses here but I've not used them. I've only checked them for decentering (they're both decentred) as they arrived in haviliy damaged boxes. One was a replacement for the last which arrived damaged(!). Still, that's what you get from buying lenses from an online store which started out selling books...
Hopefully I shall have yet another replacement tomorrow and it won't be damaged. Fingers crossed!
Mark.
SarahBK
SarahBK Regular Member • Posts: 184
Comparison of MFD?
Do you still have both lenses?
What I am really curious about is how much closer you can focus with the 35mm f/2 IS. Numbers state the MFD for the Canon is less, but I'd really like a real picture comparison to properly demonstrate just how much closer you can get with it compared to the Sigma. Would you ever consider doing a side by side comparison demonstrating this?
My 24mm-on-a-crop lens is my favourite travel/street lens and pretty much stays plastered to my camera when out and about. One feature that's really proven to be handy is a short MFD which I do find myself making use of quite often - don't always have time for a lens change (to say, a macro). Hence, since I'm considering one of these lenses to serve the same purpose as this lens has once I move to full frame, this issue matters quite a bit to me. Don't think it's much of an issue for many since I cannot find any online source making such a comparison.
I do wonder too however, if despite not being able to focus as close with the Sigma, if shooting at f/1.4 from its MFD would still be capable of producing the same fg/bg separation as the Canon would at its own MFD at f/2? (Meaning, could I simply get away with cropping photos taken with the Sigma wide open and still achieve the same composition as I would have achieved with the Canon wide open? That would be ideal, since with the Sigma I'd obviously benefit from better fg/bg separation at further subject distances because of its inherent f/1.4).
(Side note after reading some of the comments on this thread: You don't need to be a working professional to enjoy or preferentially use wide apertures!)
 SarahBK's gear list:SarahBK's gear list
Canon 6D Mark II Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM Canon EF 40mm f/2.8 STM Canon EF 24-70mm F4L IS USM +2 more
Gandolphi Senior Member • Posts: 2,840
Re: Canon 35mm f/2 IS vs Sigma 35mm f/1.4 Art bokeh comparison
timotale wrote:
markodarko wrote:
Hi Guys,
Just in case anyone's interested, I did a quick comparison between my Canon 35mm f/2 IS and a Sigma 35mm f/1.4 Art the other day. All things considered they are both excellent pieces of glass. In real-world-non-MTF-chart-land they are both equally as sharp in my opinion and so I won't bore people with pixel peeping sharpness tests as they're pointless - they're so close. The Sigma is better at closer focusing distances wide open as the Canon ghosts a little at the edges there (if full frame sharpness is important to you at close distances wide open but there are very few instances where this is even an issue as we will usually have a subject in focus and the rest not), but beyond close distances they're very similar indeed. At some apertures (f/4 for example) the Canon is a teeny bit sharper near the centre than the Sigma (at least in these two copies) but not to the point of significance, only if pixel peeping. No lens is perfect.
Aaaaaanyway. One thing which I DID want to see is the bokeh quality between the two of them at the same apertures - or rather, to be more precise, how good the background to foreground separation (or "3D-ness") is between them as in a 35mm lens this is something which interests me.
On paper you'd assume that at f/2 (the lowest common widest aperture) the background to foreground blurry ratio doodaah would be similar, but it turns out they aren't at all.
Here's a shot I set up in a difficult scene (natural backlight light, foliage and lots of noise behind the subject) because as we all know, foliage is one of the worst scenarios for smooth bokeh so if any nervousness was going to rear its head, it would be here.
The following shots were loaded into LR4 and the only thing done to them was vignette correction via the lens profile tool. Distortion correction wasn't touched to prevent any artefacts (if any) appearing in the images. They were both metered individually for ETTR and the focus point is the same for both - the very last fret on the guitar in the centre of the image.
They were taken from approximately 1 metre away from the subject on a tripod and focused manually via Live View. The Sigma looks a teeny bit closer so I guess one of them is slightly bigger or smaller than 35mm (as the tripod and camera weren't moved) but not enough to make a significant difference to this test I'd say, although I could always repeat it and move the sigma back by 1cm or so to accommodate for the frame size difference but I feel we'd be splitting hairs.
Canon 35mm @ f/2
Sigma 35mm @ f/2
Sigma 35mm @ f/1.4 - just to see how much more of an effect the extra stop has
100% Comparison between the Canon (left) and Sigma (right) @ f/2
Canon (left) Sigma (right) @ f/2 side by side
Now, this is all subjective and down to personal preference, and this is an extreme situation for bokeh I know, but in my opinion the Sigma images just "pop" out of the frame because the background / foreground separation is so much greater. In fact you don't even need to stop down to f/1.4 to achieve this as it's lovely even at f/2 (which means hardly any vignette to correct, so less potential noise in the corners if that's an issue for you) but I've included the f/1.4 image just so you can see.
When I looked at the other photos I took in LR, the Sigma matches the Canon's blur (when at f/2) when it's at f/2.8. In fact, at f/2.8 the Sigma and the Canon are very similar it's hard to tell them apart.
Even in the final side-by-side image I've included and viewing them small and on the web, the side by side comparison illustrates this clearly to my eyes. The Sigma just has "something" to it even though the differences are quite small. It's as though your eye's peripheral vision isn't drawn to the rest of the frame when you look at the guitar, but in the Canon image, it is.
So there you go. There have been plenty of reviews of both these lenses on the net but this is one aspect which was missing for me so I hope it's useful for you so that you may draw your own conclusions about the "3D-ness" of these two lenses. Again, this isn't a review of the lenses as a whole and how the Sigma doesn't have IS and the Canon does blah blah, it's just a specific aspect of the two lenses.
Mark.
sigma's bokeh is no match to 35L II!
http://www.dpreview.com/forums/post/56642803
Nor my Leica f:2.8 35mm Summaron and its nearly 40'years old.
 Gandolphi's gear list:Gandolphi's gear list
Leica SL (Typ 601) Hasselblad X1D II 50C Leica SL2-S Leica Super-Vario-Elmar-SL 16-35mm F3.5-4.5 ASPH Leica APO-Summicron-SL 35mm F2 ASPH +2 more
(unknown member) Regular Member • Posts: 484
Re: Comparison of MFD?
Sorry - I don't have access to a Siggy 35mm Art; but here is my Canon 35mm f/2 IS just about as close as I can get with it (OOC JPEG):
I've chosen a reference subject that I hope is familiar to you! The size & weight of the lens are perfect on my 6D for carrying around. It isn't a "bokeh king" but it is sharp, sharp, sharp, and the IS works really well. It is my most-used lens - hardly ever comes off the camera.
J
SarahBK
J
I certainly wouldn't mind if I had a box of those on my desk right now! Thank you for your quick reply too!
Not familiar with that box specifically - but I am familiar with what might be of a similar in size (Celebrations). Looks like that is pretty close (Another contender is the Tamron 35mm f/1.8 actually which apparently closes even closer...!) The Canon seems like a great all-rounder though - even in terms of size and weight in comparison to the Sigma. I could imagine a 35mm lens living on my camera too though - and the Canon is certainly a decent contender for that post.
Alex78 New Member • Posts: 1
I think the following is an interesting observation about the bokeh of the Canon 35mm f2 IS, and can be of value to this discussion. I've been thinking about buying that lens myself, but after seeing this I'm reconsidering my options. I think the Tamron 35mm f1.8 VC looks like the most promising lens right now.
https://flatworldsedgephotography.com/2015/11/15/corner-bokeh-quality-of-canon-35mm-f2-0-is-vs-canon-35mm-f1-4-ii/
Bokeh comparisons of different scenes are all but useless, really, since the bokeh is very dependent on the scene itself.
HFLM Senior Member • Posts: 1,977
J A C S wrote:
markodarko wrote:
J A C S wrote:
You can clearly see that the blur near the center does not differ much but near the borders, the difference is very real.
Hmm, I'm not so sure - take a look at the door frame on the left middle of the frame. Even that seems more blurred out in the Sigma image than the Canon. At least to my eyes.
The door frame is not exactly in the center. On the other hand, the background in the center is more blurred with the Sigma, true, but the difference is not so drastic.
BTW, I was also going to make the remark before that you are focusing too close which may change a bit the effective FL and aperture, the longer lens may appear as being closer, and one can see some of that in your shots. Focus at 2m or so, and those differences would be diminished.
Agree. The Canon shot looks wider than Sigma's. The letters on the stand are much more in focus than the one on the Sigma. Was the angle, focus point  and position exactly the same? It will not make a drastic difference, but with fast wide angles it will make a difference. Otherwise I like the Sigma better. Overall I think the Canon 35/1.4ii is the best 35mm for me.
 HFLM's gear list:HFLM's gear list
Sony a9 Sony a7R IV Sony a9 II Sony a1
SarahBK
That is indeed quite distracting.
BlueRay2 Forum Pro • Posts: 14,816
that review of 35 f2.0 IS is not fair and pretty foolish if you ask me! i have used the best canon and other top brand lenses for background bokeh--they turn out horrid when there are random tree branches and foliage! so, i don't take that unfair review seriously at all!!!
J A C S
J A C S Forum Pro • Posts: 20,544
This is a big generalization. After all, that page has samples of good bokeh with trees and branches, as well.
