Connecting Rebel T2i to computer
Started Oct 19, 2015 | Discussions
Tammar New Member • Posts: 1
I have just purchased a second hand EOS 550D Rebel T2i and didn't receive the EOS Digital Solution disk with the camera or any cables for connections.
I am having difficulty downloading any photos to computer.
Is there a special interface cable  that you need to use or will any USB cable be OK. The computer won't recognise my camera when it is connected. Comes up with error message " The last USB device you connected to this computer malfunctioned and Windows does not recognise it"
I am running Windows10 Pro
I have downloaded EOS Utility and Digital Photo Professional.
I have formatted the card on the camera.
Can anyone help please?
Canon EOS 550D (EOS Rebel T2i / EOS Kiss X4)
imqqmi Veteran Member • Posts: 8,639
Re: Connecting Rebel T2i to computer
See if there's an option for computer connection and change it to PTP protocol, and if it's already on that setting try the other one.
Kind regards
Imqqmi
Links:
View my webgallery
http://www.pbase.com/imqqmi
The DSLR jargon cheatsheet
http://www.jmbfoto.nl/dslrcheatsheet.pdf
Sunset blending tutorial
http://www.jmbfoto.nl/tutorial/blendingTutorial01a.pdf
Wilba's Frequently Asked (beginners) Questions and answers
http://snipurl.com/RebelFAQ
 imqqmi's gear list:imqqmi's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +2 more
mocha123 Senior Member • Posts: 2,497
Hi Tammar,
If your computer has an inbuilt Card Reader, many laptops have these, you can take your SDHC card out of the 550D and plug it straight into your computer and copy the photo's over to your computer.
If your computer doesn't have a card reader these can be purchased separately and only cost a few £/$.
 mocha123's gear list:mocha123's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EF 100mm f/2.0 USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 17-50mm F2.8 EX DC OS HSM +3 more
(unknown member) New Member • Posts: 9
I don't own the camera, but it looks like the interface cable is a USB A to Mini B cable. They should be pretty cheap (i.e. about the same price as a bad tasting hamburger) if you get it from a place that sells all the other types of computer cable.
http://www.dpreview.com/forums/post/54297901
According to the manual, the camera also has to be on and in the image viewing mode for the USB to work. (In other words, plug the camera and computer together while there's a previously-taken image showing on the LCD screen on the back - that's what I needed to do on my old Sony DSLR to get it to talk to the computer.)
kreygscott
kreygscott Senior Member • Posts: 1,285
Whether there is an image present or not the Operating System should recognize the camera as a storage device. I'm not familiar with Windoes 10 and as such would suggest that you follow the advice to get yourself a card reader as going this route will help conserve your batteries.
As in certain cults it is possible to kill a process if you know its true name. -- Ken Thompson and Dennis M. Ritchie
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
ikolbyi Senior Member • Posts: 1,290
Does your laptop have an SD card reader built into it?
For example, many HP and Apple laptops have an SD card reader.  I have the same camera and I pull the SD card out after taking pictures and put the card directly into my laptop and access the pictures using this method - much easier.
 ikolbyi's gear list:ikolbyi's gear list
Sony a6300 Olympus E-M5 III Olympus E-M1 III OM-1 Voigtlander 40mm F1.4 Nokton Classic +10 more
Christianbrobro New Member • Posts: 1
Some people like me, want to download Color presets for filming. I have the same issue I can’t get it to recognize it I’ve tried many cables and I’ve tried different computers
Photonographer
Photonographer New Member • Posts: 7
The USB error you received typically is caused by:
bad cable
damaged USB port (whether on camera or computer)
The first action I'd suggest is trying a new cable. Some cables do not have data channels so you should definitely make sure it does. Other than that, try several ports on the target computer (in the event one has a malfunction).
 Photonographer's gear list:Photonographer's gear list
Canon EOS Rebel T7i Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM
AnthonyL Veteran Member • Posts: 3,686
Firstly the EOS Utility should automatically kick in when the camera is connected and that utility should handle all the downloads and other features.
Did you download the full Canon software suite from an official Canon site eg: https://www.canon.co.uk/support/ if you are in the UK?
There used to be an issue with the Canon software if the camera had already been attached via USB before the software was installed but I don't know if this is still the case and I am going back a few years.
No special USB cable is required.  I don't believe Canon cameras are seen as mass USB storage so that route probably won't work.  If the EOS Utility won't work then you'll have to use an SD card reader.  Canon's ImageBrowser will download from a card reader and keep track of what is new and what is yet to be downloaded though other freely available software will as well.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
rmexpress22 Senior Member • Posts: 2,304
bad cable
All good points. Same thing I was thinking.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
