Oly Air + Panny 30mm macro + Nikon ES-1 slide copier?
Started Oct 18, 2015 | Discussions
tesilab
tesilab Veteran Member • Posts: 3,004
I recently purchased an Olympus Air, and for my first ever MFT lens, purchased a Panasonic 30mm macro. One use I would like to put it to is to digitize some 35mm slides and negatives.
I'm planning to buy  a Nikon ES-1 slide copier and a 46-52 step up ring. I'm unsure of whether I will need additional extension to fill the frame. Can anyone help with this?
As for adapting it to copy from film strips, are there any suggestions? So far I've only found a Kaiser film strip carrier at B&H that would take weeks to receive.
 tesilab's gear list:tesilab's gear list
Sony RX1R II Panasonic Lumix DMC-GX8 Sony a7 III Panasonic Leica Summilux DG 25mm F1.4 Sony FE 85mm F1.8 +1 more
Olympus Air Panasonic Lumix G Macro 30mm F2.8
aljudy Senior Member • Posts: 1,208
Re: Oly Air + Panny 30mm macro + Nikon ES-1 slide copier?
I recently used a Nikon ES-1 with my GH4 with a Minolta 35mm/f1.8; I needed an extension tube. Here's a photo of my setup.
Scanned over 1,000 slides with this setup
Amateur Photographer of family mainly
 aljudy's gear list:aljudy's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 ASPH OIS +9 more
tesilab
OP tesilab Veteran Member • Posts: 3,004
From what I could tell from a quick lookup, your lens isn't a macro, so I can understand needing the extension on that side of the lens.
Have you used anything to adapt it to negatives/film strips as well?
Yes you are correct: the Minolta lens is not a macro. I never kept film negatives.
Gerry Siegel
Gerry Siegel Veteran Member • Posts: 3,244
Tesilab, you want something we agree that is fixed and ready to go to work on your slides.
My choice-not the simplest but elegant- was to use a Canon Bellow FL. and later I bought a used Canon Auto Bellows. Both units come with a slide carrier if you get a complete outfit. I paid about $160.00 from Band H. The value of this is that you can attach any older macro lens or enlarger lens and see it on your screen. A lens of suitable enlargement capability encompasses many out there designed to work with the largersize film cameras. So my rig involved a Canon 50 mm macro and sometimes a teleconverter ( oldie) and a 50 dollar LED. In this photo I am really going for half frame. But it gives you an idea. Thing is to be able to slide your camera back and forth to obtain sharp focus. Use any WB that works. No reason an AiR cannot be uses. but I would not want to try such a rig. I would expect your 30mm macro could work, if the bellows allows it... Any bellows will do,I hasten to add, .Hope that offers a second opinion and and idea, sir...I wish you well, gs
I must add I considere an all in one tube like the Nikon gadget, but I wanted more flexibility and I think I achieved it....Well it is an idea to play with....the Auto Bellows has adjustments builtin the carrier and also a film strip module, nice gizmo for sure...if you are into gizmos. Once set up, it is pretty easy to employ..gs
Canon Bellows FL (early model replaced by Auto Bellows) with old 50 mm macro and teleconverter to shoot a 24 X23 mm slide chip
 Gerry Siegel's gear list:Gerry Siegel's gear list
Panasonic ZS100 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 +4 more
Gerry Siegel
I found a shot of my Auto Bellows set up for 35mm slides with the 50mm macro lens and the GH 2 on a little slide. Set white balance to taste on the screen.....I knew I took a photo of this rig. I was lucky to get an Auto Bellows in complete boxed condition with the carrier and clean bellows and whatnot...so for you and any one else interested in duping slides to micro four thirds, this is not bad for the money. But I cannot compare it to the all in one Nikon  ES-1gadget for size. I happened to own a bunch of Canon lenses and converters and tubes...helped. I find this works to my satisfaction.. i will try to find an example of a small slide copied to digital to show you. Now where did I file that one//??
Digital Dick Senior Member • Posts: 2,379
I use the Olympus 12-50 mm lens at its macro setting with the ES-1. It's just about perfect for the magnification.
See https://www.youtube.com/watch?v=aNgAOSlaLSk
Dick
 Digital Dick's gear list:Digital Dick's gear list
Olympus OM-D E-M5 Olympus E-M5 II
Gerry Siegel
Here is a moderately but not extensively retouched 50 year old Kodachrome slide one of a stereo pair of 23 by 24mm using a bellows and a micro four thirds camera.  Either the GH2 or the G-1. I think not bad even at this low res web JPEG cy
tesilab
Very helpful video, thank you.
Tango 55 Contributing Member • Posts: 902
I use your setup...
I use the Lumix 30mm macro lens with the ES-1 and a 46 to 52mm adapter. I works perfectly fine without any additional extensions or hardware of any kind. Although I have the Olympus Air, so far I have only tried with the E-M5 MkII
Since I photographed framed slides, I cannot answer your question about film strips, but from what I can see, the slide holders in the ES-1 could damage the film unless you use some kind of protection. Not difficult to do, but may be more convenient to have them individually framed.
The results are truly gratifying, particularly if you shoot RAW (+ JPEG) and adjust the white balance, etc., which is necessary for optimum results.
BTW, you'll need a bright like source (I use a 100W-equivalent LED light bulb and shoot very close to it with very good results).
Go for it and have fun!
Ricky
 Tango 55's gear list:Tango 55's gear list
Sony a7 IV Olympus OM-D E-M10 II Canon EOS RP Sony a7C +1 more
tesilab
Re: I use your setup...
This is very good to know. I'll pick up this combo today and start with slides till I sort out the film holder issue.
As for light source, I'll have to experiment. I was wondering if it worth trying longer exposures against my MacBookpro LCD set to pure white display. But perhaps it won't penetrate the denser parts of the slide?
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
That's impressive.
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
TomFid Veteran Member • Posts: 4,000
I use one of these Yashica copiers, with a Canon FD 50mm legacy macro:
http://www.ebay.com/itm/Vintage-Yashica-Slide-Copier-35mm-Single-Lens-Reflex-Cameras-w-Box-/381436745051?hash=item58cf66d55b:g:WOkAAOSw14xWHSlg
It has enough adjustment built in to achieve 1:1 (equivalent), though not sure that would also be true for the 30mm.
Gerry Siegel
Trevor Carpenter wrote:
That's impressive.
Thanks. I am pleased with the bellows and slide copier that was part of the original outfit.  It takes some jury rigging if one uses a legacy lens of the FD macro list, and an adapter to attach it to a micro four thirds camera. Which gets into the use of adapted lenses.  For slide copying they are the perfect choice. We do not care about automation nor auto focus. We do care about the qualit of the adapter.  The one I have used is by Vello, but I am going to buy a Metabones glassless FD to m43 adapter which I see fits snugly with little chance of rotation. When on goes from a 35mm format to a 4:3 one leaves some room. Same room permits one to do a little in camera cropping if one chooses.  And as shown to copy half frame or smaller objects. Now with the slide copy attachment that came with the Auto Bellows one can move the SLIDE HOLDER easily and smoothly in an axis, as I suppose moving the slide in the Nikon. A miniscule movement makes a lot of difference.  I point this out to anyone interested in the tradiitional bellows copying advice.  To buy a new kit today is more than we want to consider.  To that end the Nikon ES-1 may be a decent solution.  Just not the only one, for the record. I am not copying a whole collection. Why copy the junk, let my survivors look through the poly sleeves, they need something to discover on their own.  I hope this add on adds some value to the whole business of archiving and mailing family history.  Or one could pay a commercial outfit,I guess.  Happy trails, gs
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
From the Pen world.....
My setup is using Oly Pen cameras.
For a light source I used to use a 20 watt compact fluorescent tube, Daylight brand, bought from a Craft Depot style of store - needle workers use them as they are full spectrum and they can see the thread colour differences. https://us.daylightcompany.com/bulbs-tubes/bulbs.html
The advantage being the regular ES base, the similar Ott lamps have totally weird tube bases.
The lamp was maybe 4 inches from the slide, exposure times were longer but no matter as the slide is "attached" to the lens so no shake issues.
But now I use TTL flash as being much easier. Does the Air do flash?
As an example of flash setup, RC TTL controlled here.......
Monster rig developed over the years to handle 35mm and medium format film/slides.
The flash has later been moved about 6 inches further away from the diffusing sheet behind the slide to better deal with thin slides. The TTL had over-exposure problems at times being that close. The Daylight lamp was mounted where the flash is now in that shot.
Negative film strips are a pain as ideally the light source needs to be different to white, I have yet to sort out a proper filter. Some use a discarded colour enlarger head to get the correct light source for colour neg strips.
Early attempts with 12MP bodies not so good, but now 16MP bodies get all there is to get off a slide.
Some reading at http://scantips.com/es-1.html may also help.
Regards..... Guy
tesilab
I tried it out tonight, I was able to copy a 3-4 slides a minute, and that including cleaning, with >1sec exposures (f5.6, ISO 200, using MacBook LCD screen for illumination).
The issues I encountered are as follows:
I had to collapse the ES-1 to the shortest length, but even then couldn't fill the frame. My step-up ring seems fairly thin, but maybe I could find a thinner one, don't know how much that'll help.
I couldn't center the slides. I could barely get the top edge of the slides into the frame.
The spring on one side has almost no curve-back on top, so it was hard to get each slide into place--I had to pry one side open to get each slide in.
(On top of all that, Lightroom was giving me grief and not importing the raw files, and then Creative Cloud was hanging when I attempted to update.)
Gerry Siegel
Well it was a good try. Back to the drawing board. Does tesi need a longer lens or a longer tube, too late for me to figure. I figured that a FD 50mm macro  full frame lens circa1973 with FD 25-U tube gave 1to 1 nicely.....and even allows cropping and movement in two planes with the auto bellows nifty copier gadget....that was a coup d'etat to find the works in A-1 shape after a long search. Velbon makes a bellow, a so so bellows. RRS is unaffordable but swell... Getting a good rail system or a bellow with rail  is a job to find- read will take patience, sorry- but they are out there. I am sorry this expenditure did not pan out. Now what? I await other ideas. I got my slides fine res with JPEGs using 12 megs, it all you need unless you have great archival ambition, beyond just preservation. I wonder what the pro copy outfits use, just for fun....I will follow this with interest. Kind of a production operation, and can be boring. Idea: Buy a Lumix G-something with a fold out screen Life will be easier, and set WB by eye- less fuss later. I wish you well, sir..
Guy Parsons
The ideal lens to use with the Nikon ES-1 copy attachment is the old 4/3 35mm macro lens, needs an adapter of course to fit to M4/3 mount.
The ES-1 screws straight onto the lens with matching 52mm thread, set lens at around 1:2 and everything works nicely.
The only hint when using a regular Oly M4/3 Pen or OM-D body is to turn off the "reset to infinity at turn off" as it moves the whole ES-1 quite a distance with that 35mm lens when going back to infinity focus, may stress the focus motor if done too often, use manual focus anyway to stop any AF seeking problems.
As mentioned, I wasn't happy with 12MP slide copies, but 16MP does it nicely, there's no more that can be sucked from the slide as 16MP is better than any 35mm slide film.
Some have used setups as simple as a macro lens and a few hours work with timber scraps and a bit of diffusing plastic behind the slide/film. True macro lenses are always recommended due to their better flat focus field ability.
Here's one slide from a temple in Kathmandu....
And now a 100% crop of a bit.......
That was done with an E-PL5 and the 35mm lens, but now I use the 60mm macro lens. Using my dedicated film scanner at 4000 dpi maybe gets a bit more pixel peeping detail clarity (at a terribly slow scan speed penalty). Any normal view or print would never see the difference. I also checked the slide with my old lab microscope and could see no more real detail in the slide than you can see here.
All good fun but the 16MP sensor is all that is needed for really fast slide copies.
Note to self: Must extract the digit and copy the rest of the the zillions of slides cluttering the house.
Regards......... Guy
Right - the Canon FD 50 macro is 2:1, and 1:1 with the native tube. Due to the crop factor, a slide fills the frame at 2:1, no tube needed. So it should be just a matter of getting the right distance for focus. Per the ebay link I posted below, the old Yashica copiers work great and the price is right. I can snap a photo of the setup later, if helpful.
rodriguezPhoto
rodriguezPhoto Veteran Member • Posts: 4,260
I just got the ES-1 but haven't set it up yet.  I do however plan on occasionally copying from film strips.  My plan for that is to dig through my darkroom equipment.  I'm pretty sure I have some unused cardboard slide mounts there.  If not, I'll probably cut my own with a mat cutter.  I've done something like that before when I couldn't find glassless negative carriers in the size that I needed.  I won't cut the film strip apart, I'll just use the slide mount as a frame around the negative I want to copy, to support and protect it in the copier.
 rodriguezPhoto's gear list:rodriguezPhoto's gear list
Olympus E-1 Olympus E-3 Canon EOS 6D Olympus E-M1 Olympus E-M1 II +55 more
