Canon 200-400 F4 or 400mm F2.8 ?
Started Oct 16, 2015 | Questions
nimtree
nimtree Regular Member • Posts: 180
One gives compositional benefits, other gives more light and superb sharpness.
Deciding which one, is a tough question.
Can someone please suggest ?
Usage is mostly mammals, early and late evening and in very dusty conditions.
Does the 200-400 zoom sucks dust? How is the in built teleconverter, useful ? Not sure if I want to use the in built one and make it a slow F5.6.
Thanks.
Cheatdeath New Member • Posts: 24
Re: Canon 200-400 F4 or 400mm F2.8 ?
I would rent or go try out both if possible. Also I would look at the 500mm F4 IS II which is cheaper and probably a better overall lens for wildlife.
 Cheatdeath's gear list:Cheatdeath's gear list
Panasonic LX100 Canon EOS 7D Mark II Canon EF 300mm f/4.0L IS USM Canon EF 70-200mm F2.8L IS II USM Sigma 18-35mm F1.8 DC HSM Art +4 more
Steve Balcombe Forum Pro • Posts: 15,582
Internal or external makes no difference - any 1.4x TC costs a stop of light.
nimtree
OP nimtree Regular Member • Posts: 180
I understand that but in the field there would not be enough time to remove the lens (in dusty surroundings), put a teleconverter and then attached the lens back, by that time, the tiger would be gone home for dinner.
I don't understand what you mean. You said you don't want to "use the built in one and make it a slow f/5.6". As opposed to what, if not an external one? Then you went on to describe the exact benefit of the thing you don't want to use, i.e. that it removes the need to swap in/out an external TC.
Myrgjorf Regular Member • Posts: 464
I don't agree. In my experience the built-in TC takes less IQ hit than the external (Canon x1.4 mk3). Both makes it a 280 - 560 F5.6 though.
I have often used the flexibility of the 200-560mm to get photos not possible with a fixed FL. But I am sure a fixed FL may be better in some scenarios. Though I haven't tried the 400mm F2.8 I think it is a very different beast useful for other workflows. I use my 200-400 with a 7D2 most of the time adding another x1.6 though I sometimes uses it with a 6D.
The 200-400 zooms internally so dust should not be a problem and I haven't had dust problems so far.
 Myrgjorf's gear list:Myrgjorf's gear list
Sony RX100 Olympus TG-5 Canon EOS-1D X Mark II Canon EOS M50 Canon EOS R5 +20 more
For goodness sake, I didn't say anything about IQ. The external TC makes it 27 mm longer and 225 g heavier as well, but I didn't say anything about that either.
RogerZoul
RogerZoul Veteran Member • Posts: 3,243
Little confused here. The OP asked how is the in built TC, useful or not. You said it makes no difference you just lose a stop of light. The other poster said the in-built TC has better image quality, which conflicts with what you said since you *implied* that there is no difference in IQ. Hence, you did say something about IQ.  It also makes very little sense to buy a lens with an in-built TC if you don't plan to use it, or use an external one.
 RogerZoul's gear list:RogerZoul's gear list
Canon EOS R5 Canon EF 500mm f/4.0L IS II USM Canon RF 35mm F1.8 IS STM Macro Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 800mm F11 IS STM +31 more
Sports Shooter
Sports Shooter Senior Member • Posts: 1,648
Thanks.
200-400 . Super sharpness too and the build in TC is made of the same glass as the lens.
or go for the 500 / f4.
You didn't tell us what camera you use...
 Sports Shooter's gear list:Sports Shooter's gear list
Canon EOS-1D Mark IV Canon EOS-1D X Mark II Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF 70-200mm F2.8L IS II USM +14 more
nimtree
5D Mark III is my main body.
Sports Shooter
I would go for the 200-400. The 5D MKIII has excellent high ISO capability to handle low light at f4 or even f5.6.
Phil Shaw Contributing Member • Posts: 620
Given the limited room for changing position in many situations when photographing mammals, the 200-400 zoom would be my choice.  In fact I made this choice a few years ago by buying a Nikon 200-400 plus a Nikon D3 to complement my Canon 500/f4, 600/f4 and 300/f2.8 lenses.  For mammal photography the 200-400 was my go to lens.  I very quickly sold the 500/f4 and the 300/f2.8 got very little use after I bought the 200-400.  The price of the Canon 200-400/f4 is the only thing that puts me off from replacing the Nikon 200-400.  I had just about convinced myself to up-grade (and it is an up-grade) to the Canon lens, when Nikon announced their new 200-500 zoom.  I'm now waiting to try one of these on my D810 before I make a final decision about the Canon 200-400.
bigfatron Contributing Member • Posts: 777
He never said it made no difference, nor did he imply anything about IQ.  He merely pointed out that a 1.4x TC will hit you for a stop of light, whether its internal or external. The confusing part is the original post.
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Canon Extender EF 1.4x III Canon EF 35mm F2 IS USM +3 more
Exactly right - thanks bigfatron.
nimtree
Thanks.
So I made a good choice by buying a Nikon 200-500 for my D7100.
Now shopping for Canon 5D Mark III...hopefully canon launches something simillar soon.
I have a Tamron 150-600 but I am not impressed with the results (as compared to the primes)..usually its a great lens for the price.
kelvin500au New Member • Posts: 10
I have both the Canon 500F4 and the 200-400. You should not under estimate the versatility of the built in extender on the 200-400. I have used the prime for many years as a 700mm and there have been many times a mammal started off framed at 700 but then I found myself reaching for my second camera and the 100-400.
Now with the 200-400, I have an advantage of engaging the internal extender so I start at 560 and can keep using the same lens down to 200 without the need to grab the second camera and with the 70-200.
The quality of the 200-400 is every bit as good as the original 500 and I am happy to shoot at 5.6 all day long. There is no IQ loss engaging the internal extender
 kelvin500au's gear list:kelvin500au's gear list
Canon EOS-1D Mark IV Canon EOS-1D X Canon EF 85mm F1.2L II USM Canon EF 200mm f/2L IS USM Canon EF 300mm f/2.8L IS USM +16 more
