24-70 / 4L IS II
Started Oct 15, 2015 | Polls
Great Bustard Forum Pro • Posts: 45,641
24-70 / 4L IS II
If Canon were to make a 24-70 / 4L IS II that were optically as good as the 24-70 / 2.8L II stop for stop, not much larger or heavier than the current 24-70 / 4L IS, would you have an interest in this lens?
POLL
Yes, if it were closer in size, weight, and price to the current 24-70 / 4L IS than the 24-70 / 2.8L II.
38.6% 17  votes
No -- I'd prefer the extra stop of the 24-70 / 2.8L II.
25.0% 11  votes
No -- I'd prefer a 24-105 / 4L IS II, even given that the optics would necessarily be a bit worse (5x zoom vs 3x zoom) and likely be as large and heavy as the 24-70 / 2.8L II.
22.7% 10  votes
No -- I would wait for a third party option (e.g. Sigma 24-70 / 2.8A OS).
4.5% 2  votes
No -- I have no interest in a zoom in this range.
9.1% 4  votes
  Show results
Nikon 24-70mm F2.8E ED VR
halfwaythere Contributing Member • Posts: 893
Re: 24-70 / 4L IS II
Why do you assume that the current 24-70/4 IS is that much worse compared to the 24-70/2.8 II? As I see it differences are marginal and mostly copy relevant.
kevindar
kevindar Veteran Member • Posts: 4,625
I have both lenses, and they are already optically very close,  In fact the f4IS is better at 50 stopped down in the corners.
 kevindar's gear list:kevindar's gear list
Canon EF 85mm F1.2L II USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Sony a7R II Sony a6300 +25 more
Abu Mahendra Veteran Member • Posts: 5,312
Hard to believe, Doc, since, as you know, the 24-70II gets even better stopped down. PZ and DPReview tests are in disagreement with your assertion.
>> I am already lovin' the Canon EF 35L II lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
timotale Contributing Member • Posts: 902
have a look here.
2.8II
http://www.photozone.de/canon_eos_ff/773-canon2470f28mk2ff?start=1
4IS
http://www.photozone.de/canon_eos_ff/798-canon2470f4?start=1
 timotale's gear list:timotale's gear list
Canon EF 24mm f/1.4L II USM Canon EF 50mm f/1.2L USM Canon EF 85mm F1.2L II USM Canon EF 135mm F2L USM Canon EF 16-35mm F2.8L II USM +3 more
Pioneer 10 Senior Member • Posts: 1,442
I have the 24-70 f/4L IS and I like it. When I bought it I was mainly shooting my family and landscapes and stuff, but now that I"m doing mostly weddings I'll probably trade it for the 2.8 II, not for better optical quality, but simply because an extra stop is more practical for weddings. I need 1/60 of a sec or faster anyway.
 Pioneer 10's gear list:Pioneer 10's gear list
Canon EOS 5D Mark III Canon EOS 6D Canon EF 50mm f/1.2L USM Canon EF 85mm F1.8 USM Canon EF 70-200mm F4L IS USM +2 more
kevindar
Photozone figures show the f4 IS turing in a more even performance in the corners stopped down, with better corner figures at f5.6 -f8 at the 3 tested focal lengths.  In my experience, the 2.8 still edges out at 24mm, but not rest of the way at least in the corners.  In ballance, I have found the f4 to be a better landscape lens.
the 2.8 II, has good corners at all focal lengths wide open.  however, esp at 50, it never becomes tack sharp.  both lenses have very good center sharpness wide open.  It may be that the 2.8 does better, but both are very sharp in the center.
To me, the center and off center sharpness maters wide open, and corners matter stopped down. the f4IS, does at least as good of a job, and it has less distortion at 24 to boot.  However, it is still only an f4 lens.
J A C S
J A C S Forum Pro • Posts: 20,544
Not to mention TDP which shows that 50mm is the worst FL for the f/4 and much softer than the 24-70II. It manages to stay softer even at f/8 and that is true for all copies tested there (but the second one is very close). I considered this lens but saw no reason to get it.
timotale wrote:
have a look here.
2.8II
4IS
That's one copy of each lens which hardly relevant and compelling.
The-digital-picture.com has tested 4 copies of the 2.8 II and 3 copies of the 4 IS and except for a slight difference in corner sharpness there's very little in it:
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=787&Camera=453&FLI=0&API=2&LensComp=823&Sample=0&SampleComp=0&CameraComp=453&FLIComp=0&APIComp=0
J A C S
halfwaythere wrote:
timotale wrote:
have a look here.
2.8II
4IS
Switch to 50mm now, which is the reason this is discussed here. The compare the vignetting even to the 24-105.
The biggest competition for the 24-70/4 IS is the 24-104/4 IS not the 24-70/2.8 II. As far as I can see it the pseudo-macro capability is the only reason to get one over the 24-105/4.
In the end I think it all boils down to copy variance and photographic needs. No amount of IS is ever going to compensate the difference between F/2.8 and F/4 when your subjects are moving and the light gets really low.
The jury is still out on the Nikkor 24-70/2.8 VR but it doesn't look very good so far and I'm not sure why would someone buy an optically compromised 24-70/2.8 II IS for stills only. However I can see the benefits for video work.
The case against a 24-105mm lens
The problem from my own narrow personal perspective, buster, is that 105mm is not long enough for travel, the only reason I would lug around a 24-105/4 lens. This raises the issue of what telephoto zoom to couple it with at the long end, and unfortunately all L options are too large and/or heavy for travel, or offer too much overlap as in the case of the 70-200/4 zooms.
The case against a 24-70/4 lens
This one is simple. The 24-70II is just too good at f/2.8, and even better at f/4.
I don't know, Doc. Here are DPReview's test results at f/5.6, showing the f/2.8 lens still ahead in the corners and in the center, save for at 70mm...
J A C S
There is a good case for a stellar 24-70/4 IS, which was the OP's question but the existing one is not that.
OP Great Bustard Forum Pro • Posts: 45,641
Yes.  That 0.7x (1:1.4) max magnification is pretty cool!
I don't think anyone denies the value of an extra stop, either in terms of shallow DOF or noise for dynamic scenes in low light.  But size, weight, price, IS, and magnification can all trump one extra stop.
Another possibility is a 24-70 / 2.8-4L IS to complement the 70-300 / 4-5.6L IS.
KLO82 Senior Member • Posts: 1,527
+1
One more advantage of 24-70f4: if you believe in Dxomark lens tests, 24-70 f4IS has 4 T stops and 24-105mm f4 IS is T5.1.
[I find the T4 rating of the f4 zoom, which has lots of elements and glasses a bit hard to believe. Think about Canon cine prime lenses: 35mm f1.4 lens is rated T1.5, 50mm f1.2 is T1.3 and 85mm f1.2 is T1.3. These T stop ratings of the cine lenses are by Canon. These are prime lenses with less glass elements, and they still lose some light. So a zoom lens with no measured light loss is hard to believe]
 KLO82's gear list:KLO82's gear list
Canon EOS RP Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 24-70mm F2.8L II USM Canon RF 35mm F1.8 IS STM Macro
Surprisingly poor performance...
J A C S wrote:
halfwaythere wrote:
timotale wrote:
have a look here.
2.8II
4IS
...from the 24-70 / 4L IS at 50mm f/4 for all three copies tested.  Even the 24-105 / 4L IS fared better.  Thus the point of this poll:  would anyone be interested in a 24-70 / 4L IS II that performed at least as well as the 24-70 / 2.8L II stop for stop if the size, weight, and price were closer to the current version than the 2.8L II?
Re: Surprisingly poor performance...
J A C S wrote:
halfwaythere wrote:
timotale wrote:
have a look here.
2.8II
4IS
No. Instead I'd probably be interested in a sharper and more consistent copy to copy 24-105/4 IS II. 70mm is just too short to be a true all-round solution while F/4 is too slow for event work.
I don't see who would buy a 24-70/4 IS II at F/2.8 weight and money even if the sharpness is there.
J A C S wrote:
halfwaythere wrote:
timotale wrote:
have a look here.
2.8II
4IS
OK.
That wasn't the premise, though, was it?  In fact, I *specifically stated* that the size, weight, and cost of the proposed 24-70 / 4L IS II would be closer to the current lens than the 24-70 / 2.8L II.
J A C S
I voted "yes" and I see that so far, the majority voted that way. I would gladly trade the extra reach of the 24-105 for a more efficient IS with the IQ of the 16-35/4, for example, and better 24mm. The current one does have better 24mm and IS but disappoints overall.
