Panasonic GX8 with Olympus 40-150 f2.8 ?
Started Oct 15, 2015 | Discussions
ajamils1
ajamils1 Senior Member • Posts: 2,131
Does anyone has any experience using GX8 with Olympus 2.8?  How effective is the IBIS at the long end? Also, is the IBIS effective with TC as well?
After a long hiatus I'm thinking about picking up m4/3 again and GX8 seems to check all feature boxes that I'm looking for. With GX8 I plan on getting just the 12-40 and 40-150 f2.8 lenses as I already have full selection of Nikon glass which will be my main system.
 ajamils1's gear list:ajamils1's gear list
OM-1 Olympus 12-100mm F4.0 Olympus 25mm F1.2 Olympus 45mm F1.2 Pro Olympus 17mm F1.2 Pro +2 more
Olympus 40-150mm F2.8 Pro Panasonic Lumix DMC-GX8
brianric Veteran Member • Posts: 8,980
Re: Panasonic GX8 with Olympus 40-150 f2.8 ?
I have that setup. With the 40-150/2.8 with lens at 150 mm (300 mm fov) I have gone as low as 1/30 sec with no problems. Haven't tried lower than that or go that low with the 1.4 TC. I rarely use the 1.4 TC as it really isn't needed for my type of photography (event).
 brianric's gear list:brianric's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX8 Sony a6400 Sony a9 II +6 more
ajamils1
OP ajamils1 Senior Member • Posts: 2,131
That's good to know. I would also like to know how it works with TC. If you get a chance, could you test it ?
I've booked marked this post. It will be at least three weeks as I have four Making Strides Against Breast Cancer Walks, two soccer games, and a baby shower at McGuire AFB-Ft Dix to shoot. I'll PM you when I get a chance.
Snapshot NY USA Forum Member • Posts: 62
Quick Question:  Is there any way to assign the Fn buttons on the m.Zuiko lenses when mounted on a GX8?  I hear that there was, but have yet to find an answer (as of 12/26/2015).
 Snapshot NY USA's gear list:Snapshot NY USA's gear list
Nikon D4 Panasonic Lumix DMC-GX8 Nikon D850 Olympus OM-D E-M1X Olympus E-M1 III +15 more
ajamils1
If there is, I haven't found a way to do that.
Not that I know of.
