Very good image quality in a small package
Started Oct 15, 2015 | User reviews
Ali Senior Member • Posts: 1,969
19
I have a Canon 5D3, but I’ve always looked for a compact counterpart for situations where the DSLR is just not convenient enough. I’ve owned a series of Panasonic and Sony compacts with increasing telephoto zooms. While having 20-30x in a small camera has been great, the image quality isn’t very satisfying, especially at “higher” ISOs such as 800 and above.
I was recently eyeing the Canon G3X, but when Canon announced that the M3 would be available in the US, I decided to take a close look at it. I ended up ordering one from Japan, with the EVF, and the 18-55mm and 55-200mm EF-M lenses.
I’ve been using the M3 for a few weeks, and I like it. It has replaced my previous compact (Sony HX50V) for almost all the use cases I had for it, and that was my goal. I’ve also used it in place of the 5D3 in a few cases, with satisfactory results.
Things I like:
- Very good image quality, even at higher ISOs.
- There are prominent physical buttons for setting mode and exposure compensation, and more physical buttons in general than other similarly-sized cameras. This makes interaction more efficient.
- The 24 MP resolution enables significant cropping. See http://www.dpreview.com/forums/post/56548042 for heavily cropped shots from an arena rock concert, where I was sitting pretty far from the stage.
- The camera is small and light, and so are the native lenses. I was able to bring the M3 into the above-mentioned concert with the EF-M 55-200mm detached without any issues.
- Although the rated battery life is poor (250 shots), I was pleasantly surprised to get much more with the “right” settings. In my longest shoot so far I took 430+ shots and the battery indicator didn’t even drop a tick. See: http://www.dpreview.com/forums/post/56537185.
- Ability to use EF and EF-S lenses is a huge plus. Even my 12 year old Sigma 70-200mm EF lens worked flawlessly.
- The menu system is very familiar to users of Canon DSLRs.
- Tilting LCD display with touchscreen ability is handy in some shooting conditions. The external EVF also tilts, which provides flexibility not found with built-in EVFs.
Things I don’t like:
- The autofocus area is too big, which leads to some guessing in intricate focusing situations. Focus peaking can help in some cases, if “AF+MF” mode is enabled.
- Autofocus and shutter speeds are pretty fast, but response time for some operations, such as image display, is slower than a capable DSLR.
- The external EVF is expensive (if bought separately) and adds to the size of otherwise svelte camera.
- Having many physical buttons on such a small camera does mean the buttons are a bit small and close together. Also the On/Off button is a little too buried, but, on the positive side, this does make it hard to hit by mistake.
- Some non-EF-M lenses constantly and noisily “hunt” as you walk around with the camera on. Turns out this is due to “Continuous AF,” which is enabled by default. This setting works well with STM lenses, but not others. Turning it off addresses the constant hunting and probably helps with the battery life.
- I was disappointed to find that a brand new Tamron 150-600mm EF lens doesn’t autofocus on the M3. This kind of risk exists with third party lenses, especially when adapters are involved, but unfortunate nevertheless. A firmware update may be needed.
Lack of 1080p at 60 fps or 4K video isn’t a concern for me since I don’t use video features very often, and when I do, 1080p at 30 or 24 fps satisfies my needs.
I also don’t use the built-in flash or WiFi, so no opinions yet on those aspects. I’m glad to have WiFi, since I suspect I may end up needing it from time to time.
Some photos with a variety of lenses:
Lens: Canon EF 50mm f/1.2
Lens: Canon EF-M 55-200mm
Lens: Canon EF-M 55-200mm, using "miniature" mode
Lens: Canon EF-M 18-55mm
 Ali's gear list:Ali's gear list
Sony Cyber-shot DSC-HX50V Olympus TG-5 Panasonic Lumix DC-ZS80 Canon EOS M6 II Canon EOS R5
Canon EOS M3
24 megapixels • 3 screen • APS-C sensor
Announced: Feb 6, 2015
Ali's score
4.5
Average community score
3.7
bad for good for
Kids / pets
great
Action / sports
good
Landscapes / scenery
excellent
Portraits
great
Low light (without flash)
great
Flash photography (social)
unrated
Studio / still life
excellent
= community average
Canon EOS M3
MikeJ9116 Veteran Member • Posts: 6,955
Re: Very good image quality in a small package
Nice photos and write up.  I would suggest you consider getting the EF-M 22mm.  I bought one recently and find it to be a great compliment to the M3.
Gesture Forum Pro • Posts: 10,236
"- The external EVF is expensive (if bought separately) and adds to the size of otherwise svelte camera."
NICE, BALANCED REVIEW.  VALUABLE FOR FORUMS. I DON'T KNOW IF IT CAN BE DONE WITH APS-C, BUT I LIKE THE WAY PANASONIC TUCKS EVFS INTO THE CORNER OF THE BACK, VERSUS A CENTER BUMP.
fwampler Senior Member • Posts: 1,782
Very nice review. I purchased the 'M' for the same reasons as you did. My experience is spot on with yours. The M makes a nice addition to one's kit.
Fred
 fwampler's gear list:fwampler's gear list
Canon PowerShot G1 Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EOS M3 Canon EOS-1D X Mark II +19 more
Bob 1
Bob 1 Senior Member • Posts: 1,896
Ali.... A very informative review!  Well done... Thanks!  HAGD, Bob
 Bob 1's gear list:Bob 1's gear list
Canon EOS 5D Canon EOS 5D Mark II Canon EOS M Canon EOS 6D Canon EOS 5D Mark IV +9 more
OP Ali Senior Member • Posts: 1,969
Thanks. The EF-M 22mm is intriguing, one of the next lenses on my list to consider.
Ali
kevinplui
kevinplui Forum Member • Posts: 52
Just wanted to know if the AF is an improvement to the previous models? Does the AF speed suffer when using EF lenses? Is it quick like the competitors?
A good photographer can capture a great image with a bad camera/lens, while a bad photographer cannot capture a great image with the best camera/lens. A better camera/lens can only make a photographer's life a little bit easier.
Don't focus too much on what kind of photo equipment you own or wish to have. Instead, focus on your techniques as a photographer. The final result is what really matters!
 kevinplui's gear list:kevinplui's gear list
Fujifilm X-T3 Fujifilm XF 18mm F1.4 R LM WR Fujifilm XF 33mm F1.4 R LM WR
nnowak Veteran Member • Posts: 9,075
Yes
Depends on the lens. STM lenses are all good
No
I didn't use the M or M2, so I can't compare. But the AF on the M3 is pretty zippy, and worked well and fast with pretty much all the EF and EF-S lenses I tried, not just Canon, but also some odd ones like the Sigma 15-30mm, Sigma 120-400mm, and even a 12 year old Sigma 70-200mm.
(One exception is my Tamron EF 150-600mm, which doesn't autofocus at all right now on the M3. I understand it works fine with a firmware upgrade.)
Ali
Tremint Senior Member • Posts: 1,143
Few more samples please
I love a nice blur background and so would love to see few examples esp people with the 55-200 wide open at 150 to 200 mm range. It's to help me to decide if I should get that lens or a prime like 40,50,60mm EF/EF-S lenses
yahoo2u
yahoo2u Contributing Member • Posts: 715
Ali
An excellent buy.
they call me Enzo.
 yahoo2u's gear list:yahoo2u's gear list
Sigma DP2 Merrill Olympus OM-D E-M5 Nikon D610 Nikon D4S Nikon D810
Re: Few more samples please
I will put in another plug for the EF-M 22mm if you like nice bokeh.  Here are a few shots I made just goofing around with it.
Here is an example of how sharp it can be.
Thanks. I do have the 22mm and I like it. I wanted something that will give me a nice compressed background and so I would need something in the range of 150 and above
Just to add very inspiring photos in this thread
Sorry, I got you confused with the OP.
jarnvarg Junior Member • Posts: 28
Actually i bought mine directly from Japan on the EOS M3 w/EVF kit and paid USD$550 including shipping fees, on June, that's a deal, and  I love the image quality, with time the image quality on all brands tend to be better, naturally, but still far from a real pentaprism viewfinder
 jarnvarg's gear list:jarnvarg's gear list
Canon EOS-1D Canon EOS-1D Mark II Canon EOS-1Ds Canon EOS-1Ds Mark III Canon EOS 10D +37 more
4everAnoob Regular Member • Posts: 299
Where / which site exactly? eBay?
 4everAnoob's gear list:4everAnoob's gear list
Sony Cyber-shot DSC-TX5 Sony Cyber-shot DSC-HX50V Sony a5100
I bought my M3 (body with EVF) from the link below about two months ago for $498 with free shipping. It arrived in less than seven days which is phenomenal to me considering it came from Japan to Virginia.
http://www.ebay.com/itm/262006148040
I also bought my kit from eBay from Japan, http://www.ebay.com/usr/ak-wellmart. It worked out pretty well and for a reasonable price. The M3+EVF+18-55+55-200 was $832, shipping included.  Seems like $854 now, still a pretty good price.
Ali
Franz Kerschbaum
Franz Kerschbaum Senior Member • Posts: 1,242
I have more ore less the same use profile!  I use the m3 (and before the m) in parallel to or instead of my 5d3 or 7d2.  The form factor and the very similar results (when raw developed with e.g. the same profile in DXO). make it also a perfect second body in parallel. Then mostly the 11-22 is mounted which is also very nice in touristic occasions.
 Franz Kerschbaum's gear list:Franz Kerschbaum's gear list
Canon EOS 5D Mark II Canon EOS 7D Mark II Canon EOS M6 Canon EOS Ra Canon EOS R5 +30 more
crashpc Veteran Member • Posts: 7,235
Didn´t see this topic before. Wow, awesome pictures, especially the ISO3200 cat one....
I had M + 11-22mm lens, and it was unbeatable for sharpness and detail for the price. Now I´m struggling with Nikon Fx. Hoping to get back with rumored M5.
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
