Samsung 16-50 Power Zoom f3.5-5.6 + NX-1
Started Oct 14, 2015 | Questions
Juxx989
Juxx989 Forum Member • Posts: 73
Hello all...
I have a question regarding the "sticky settings" or "memory" on this lens...
My problem is when I'm in a street photography mood I set the lens to 26-30 mm but when is turned off or goes to sleep it always defaults to 16 mm... Causing a extra step and possibly missing a shot.
Is there a way to make it "remember" and return to its previous focal length after its turned on?
I went through all the menus on the NX-1 and cant seem to find it.
Only work around I can think of is to turn off power save and keep the camera on at all times... wasting the battery when not in use...
Any help would be appreciated:-|
 Juxx989's gear list:Juxx989's gear list
Samsung NX10 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 16mm F2.4 Pancake Samsung NX 45mm F1.8 +7 more
Samsung 16-50mm F3.5-5.6 power zoom
Loquah
Loquah Regular Member • Posts: 109
Re: Samsung 16-50 Power Zoom f3.5-5.6 + NX-1
I've not found a solution to this I'm afraid, but for the relatively small cost of it, I can highly recommend the 30mm pancake lens as a brilliant alternative - sharper, better aperture range and more compact.
Sorry it's not the solution you were after
 Loquah's gear list:Loquah's gear list
Samsung NX1 Samsung 16-50mm F2.0-2.8 Samsung NX300 Sony a7 II Samsung NX 30mm F2 Pancake +8 more
sunnycal
sunnycal Contributing Member • Posts: 780
I would not recommend 30mm for street photography as its AF is not reliable and can hunt a lot if even in slightly difficult situations.
 sunnycal's gear list:sunnycal's gear list
Canon EOS 5D Mark II Nikon D810 Sony a6300 Sony a7R III Tamron SP AF 90mm F/2.8 Di Macro +13 more
Loquah
Fair point, but manual focus or even just relying on wide DOF with smaller apertures works quite well in my experience. All depends on preferences I guess. I just like how compact the 30mm is and how sharp the images are.
sunnycal
Juxx989 wrote:
Hello all...
This is one of the problem with PZ lenses, as far as I know all PZ lenses have this problem (although it should be easy to solve the problem in lens firmware). Look into Samsung's older lenses, like 18-55 and 20-55.
sideburns Forum Member • Posts: 73
Juxx989 wrote:
Hello all...
Don't turn off the camera, switch off the display only. That's the most battery-consuming part of the camera.
Juxx989
OP Juxx989 Forum Member • Posts: 73
This is a good Idea... I just put sleep to 3min it worked fine...I guess...
was out during the golden hour took about 150 pics and the battery dropped to 91%
If curious here is one of my pics...
Santa Monica Sunset cheese!!
