Problem with some images.
Started Oct 10, 2015 | Discussions
alfredo_tomato
alfredo_tomato Veteran Member • Posts: 4,382
Every now and then a square block is misplaced in my image.  It usually shows near the bottom of the image.
Take a look at this and give me some idea of what is going on. Olympus EPM2.
 alfredo_tomato's gear list:alfredo_tomato's gear list
Olympus PEN E-PL1s Olympus PEN E-PM2 Olympus OM-D E-M10 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +13 more
Olympus PEN E-PM2
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Error in the jpg file.
Either your camera or your memory card is doing something wrong. A tiny error in the jpg file can cause a block to shift.
Suggestion: try a different memory card. Second suggestion: try shooting raw+jpg and check whether it goes wrong with both.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
alfredo_tomato
OP alfredo_tomato Veteran Member • Posts: 4,382
Re: Error in the jpg file.
Thanks. I have noticed some errors with my card. I will change cards and see if the issue reappears.
I usually shoot RAW only.
alfredo_tomato
So far it appears it was the memory card. Thanks for pointing me in the direction of what should have been obvious.
