E-M1 PDAF Question
Started Oct 7, 2015 | Discussions
Laslo Varadi
Laslo Varadi Veteran Member • Posts: 5,693
E-M1 PDAF Question
How can I see and adjust (select) the focus squares when in the PDAF mode when using C-AF.  I am using the 40-150 F2.8 which I assume supports PDAF mode and shooting ins C-AF, sequential mode
 Laslo Varadi's gear list:Laslo Varadi's gear list
Sony a1 Sony 1.4x Teleconverter Sony FE 28mm F2 Sony FE 90mm F2.8 macro Sony FE 100-400mm F4.5-5.6 +5 more
Olympus 40-150mm F2.8 Pro Olympus E-M1
Fri13 Veteran Member • Posts: 3,116
Re: E-M1 PDAF Question
Just like in any other mode.
Choose ESP, 9-point, normal or small focus point and then move it where you want.
When you are shooting in H sequential mode with C-AF you can see on the screen the PDAF focus pattern.
and from that you can count the normal focus point grid size. So it is three to horizontally or three vertically from the center point when choosing what point to use.
If you use C-AF+Trk mode with H sequential and if the tracking gate goes outside of the PDAF area it will start using CDAF until it gets back to PDAF sensor area.
Laslo Varadi
OP Laslo Varadi Veteran Member • Posts: 5,693
Fri13 wrote:
Thanks for getting back to me.  I am confused. I think I am doing something wrong.
What is ESP?  When I go into the SCP (Super Control Panel) on the back of the camera, I know how to choose 1, 9 or all of the points.  I can only choose the small size focus box in single point focus and I do that by pushing the info button then the down button on the mutli-direction control on the back, which then toggles between 1, 9 or all points. . If I choose 9 point I get a 3x3 box set that I can move around the screen.  I have them centered.
I do not see the above when I switch to live view by clicking the button to the left of the EVF?
I never use this mode.
Laslo Varadi
As a follow up to my previous reply, I just finished talking to Olympus Tech Support.  Not sure if they were correct and they did not inspire my confidence but the tech said that for MFT lenses like the 40-150 F2.8, all of the points (1,9 or 81) are PDAF when in C-AF sequential mode.
woodybrown
woodybrown Regular Member • Posts: 453
Since Firmware upgrade 3.1, EM 1 utilizes PDAF when in CAF when in H (not L) seq. (but if H seq set to 10 in menu, fps reduced to 9.) L sequential utilizes hybrid contrast + PDAF. This is irregardless of whether you set 1, 9 or all focus boxes
 woodybrown's gear list:woodybrown's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +5 more
Skeeterbytes Forum Pro • Posts: 23,182
I have never seen the 4/3 lens focus point array displayed for a native m4/3 lens. With that said, m4/3 lenses are supposed to use hybrid CDAF-PDAF in CAF mode, now capped at 9fps. I don't use CAF+tr so can't comment on the options there, but SAF uses CDAF only.
Rick
SkiHound Veteran Member • Posts: 3,939
Good question. I certainly don't know how to select a pdaf focus point when shooting in high speed sequential with CAF. Now, perhaps the selection of what I think of as the cdaf focus point is also selecting pdaf focus points. If so, it's a mystery to me. When I'm using CAF and high speed sequential I usually set the focus grid to the group of 9 center point. Since firmware 3 I'm really pretty happy with how it performs in decent light.
Laslo Varadi
Thanks to all that replied  I am als very happy with the A-fc, high or low sequential.  Camera is fast and with the 40-150 the images are razor sharp.  These is from yesterday.
Airmel
Airmel Senior Member • Posts: 1,303
Based on the above, Laslo is using a m43 lens. Your diagram appears to represent the E-M1 display as it appears with a 43 lens mounted.
AirMel
http://www.mel-photo.com
There are 10 types of people in this world.
Those that know binary and those that don't.
 Airmel's gear list:Airmel's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro +18 more
Laslo Varadi
Thanks Airmel.  Yes I don't think you have the option above with an m43 lens, but it is working in PDAF when in CAF, sequential .  By the way the 40-150 F2.8 pro  is working out very well.  Pictures are sharp at F2.8 and smaller aperture at 150mm.  The combination with the E-M1 is fast.
Airmel
I've come to a very similar conclusion. The E-M1 + 40-150 Pro is an awesome combination. I hate to say it, but since I got the 40-150mm Pro, my 50-200mm SWD and 150mm f/2 are quietly collecting dust.
Have fun!
AirMel
Laslo Varadi
Have fun!
I know what you mean.  Now I won't completely give up my Nikon D810 yet.
Have fun!
AirMel
My soccer setup morphs from season to season. This year I'm using two E-M1s, the 40-150 Pro and the 150 SHG with the EC14 or EC20. Fact of the matter is while the 150 is a fabulous piece of glass and the ECs give me the needed reach for long work, the Pro focusing and frame rate are an order of magnitude more responsive, which has me salivating for the 300/4 Pro. We have arrived at the promised land. Okay, almost.
And I'd like to thank Panasonic for teasing the 100-400 in order to shorten the line for the 300. You guys rock!
Rick
At some point I need to invest in a higher quality zoom. I've considered buying a used 50-200 rather than the 40-150 simply because of price differences. Would be interested in hearing more about how the two lenses compare. I'm guessing the 40-150 focuses faster on an E-M1? Any impressions with respect to IQ differences or ergonomics would also be welcome. Thanks. Will probably end up biting the bullet for the 40-150 at some point, but have wondered how the 50-200 would compare.
You see it in C-AF+H-seq while shooting. You get nice roundish area shown.
https://youtu.be/Ol-5ry8SQ8oo like that but not when focusing or using live view normally.
And the C-AF+L-seq is the hybrid mode like always has been, capped to 6.5fps. The new 3.0 presented mode is PDAF only (as Olympus stated that at the 3.0 release).
That is the PDAF focus point areas. And those are used when in m4/3 objective is mounted and C-AF+H-seq is used and you see the focus area on live view when taking photos.
You are not limited to that area as you can choose AF point outside that but then it is CDAF only instead PDAF only. If you take the L-seq then you get the hybrid where PDAF is first used to seek direction and CDAF finish the focus.
I have the earlier, non SWD 50-200. It's reasonably close to the 40-150 Pro in resolution and contrast and like the Pro can be used wide open. Focus response is well shy of the Pro and burst rate is limited in comparison. Of course it has the extra 50mm reach and pairs well with the EC14 to make it 70-283. Noticeable vignetting at the long end needs correction in post.
For action work, I reach for the Pro ten times out of ten.
Rick
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Rick
I have the E-M1 and the SWD 40-200. The autofocus is fast and efficient. I purchased the SWD 50-200 and the EC-14 used from KEH and saved about $1000 over a new MZ 40-150 Pro + 1.4xTC.
I like the fact that I have a bigger zoom range and a longer maximum focal length.
Eric
When the light is gone, the picture is gone ....
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
Airmel
Rick
While the 50-200mm SWD certainly is a lovely lens, its ability to AF on an OM-D body isn't even close to that of the 40-150mm Pro. The 40-150mm AF is 3-4 times faster.
AirMel
Airmel
This is only displayed when using a 43 lens. Not when using m43 glass.
This video only demonstrates live view with 43 lenses.
AirMel
