Test: cropped Zuiko 75mm 1.8 better than a good consumer zoom (Lumix 45-150) from 75 to 150mm
Started Oct 7, 2015 | Discussions
Robiro Veteran Member • Posts: 6,813
Re: Test: cropped Zuiko 75mm 1.8 better than a good consumer zoom (Lumix 45-150) from 75 to 150mm
D Knisely wrote:
Since that was a little unfair to the 40-150, I lowered the ISO to the same value (2000), which was also the lowest ISO where I could not get significant motion blur (1/50th second @ 300mm equivalent, which is still pretty good). This is a fair representation of how good the 40-150 can be, I think. Still, the 75 or 60 could extend the shooting envelop by a couple of stops and still get the same IQ with up-sampling, I think.
In this second comparison, the 40-150 outresolves the 75.
If you shot it at base ISO, the difference would have been even greater, IMHO.
75 is mightily good. The best m43 lens. But it simply can't outresolve twice the focal length.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
OP greg57 Contributing Member • Posts: 730
New tests at 1/1000 to eliminate shutter shock
Comparison at equal aperture
With the Zuiko opened at 2.0
Well yes, in these conditions the 45-150 at 150 is indeed better than the upscaled 75mm shot from the Zuiko 75mm.
However to reach these speeds with the 45-150 I had to dial down exposure compensation by 1.5 EV (also did it for the Zuiko and then overexposed in post by the same amount) so, in practical terms, the hoops one has to jump through to make the 45-150 work nicely with the em5 make it close to useless to me.
Or maybe I could try to work around it
Interesting to discover the reality of shutter shock in any case!
 greg57's gear list:greg57's gear list
Panasonic GX850 Sony a7 III Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Tamron 17-28mm F2.8 Di III RXD +2 more
Astrotripper Veteran Member • Posts: 8,676
My test with Oly 45 and 40-150 R
Made this out of curiosity. One is Olympus 45/1.8, the other is Olympus 40-150 R II cheapo zoom. Shot at f/5.6.
Both at 45mm
Upscaled to match 90mm. It's pretty clear which is which.
Developed from RAW with lens distortion correction enabled. No sharpening was applied (and I really mean none).
So yeah, don't throw away you zoom lenses, guys
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Michael J Davis
Michael J Davis Veteran Member • Posts: 3,755
The question is really do you want a 16Mp camera or a 4Mp camera?
My first digicam was a Fuji 6900Z - with 3 Mpixels going on 6Mp (because of Fuji's peculiar configuration) and even though I made prize-winning 19"x13" prints from that camera, I have pursued quality since.
The results you show compare - reasonably enough - the sharpness of the lenses at f5.6 - but they do show significant deterioration in the noise level. mFT cameras are now excellent, but I wouldn't want to be handicapped when I want to crop from a 150mm+ lens.
Mike
Mike Davis
Photographing the public for over 50 years
www.flickr.com/photos/watchman
 Michael J Davis's gear list:Michael J Davis's gear list
Panasonic Lumix DMC-G1 Olympus OM-D E-M5 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +6 more
Re: New tests at 1/1000 to eliminate shutter shock
Still, 75mm is heck of a lens.
Welcome, to the shutter shock show...
secretworld Senior Member • Posts: 1,734
Thanks!
I would love to see this comparison at base iso with a tripod and also 75mm vs 75mm again. 45-150 at f5.6 and f8 and 75mm at it's best f stop which is f4-f8 I think.
BTW on recent cameras the shutter shock is eliminated by using the EFC (0s anti shock) or electronic shutter.
 secretworld's gear list:secretworld's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
Re: The question is really do you want a 16Mp camera or a 4Mp camera?
In the par of the world where I currently live I don't get much more light daytime so had to push the iso to 800
I agree it's not ideal
Mike
Mike Davis
secretworld wrote:
Thanks!
You're welcome
I don't think I'll do any more tests but I'll be happy to see the results if someone else volunteers
Yeah, if i keep the zoom, I'll use it with my GX7 and electronic shutter!
Loga Senior Member • Posts: 1,981
You should redo this test...
...with a Panasonic body capable of electronic shutter on a tripod, with 2 or 10 sec timer ON.
This would be the way that could ensure that we really see the lenses performing, not other factors like shutter shock or your randomly shaking hands.
greg57 wrote:
LMNCT wrote:
Are you talking about the inexpensive 45-150 4-5.6? You are comparing a single focal length, fast aperture and somewhat expensive lens to a medium zoom which appears to be designed for light weight and low cost. Of course the 75 will come out on top. I am amazed that the 45-150 came out as well as it did.
Sure this 45-150 is not bad at all
I was trying to see if there was any reason for me to keep it in my bag for long range (did you see the comparison at 150mm equivalent?). And it appears there isn't!
 Loga's gear list:Loga's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 +6 more
Re: You should redo this test...
At these speed I don't think I get shutter shocks or camera shake blur unless I REALLY shake it around!
jwilliams Veteran Member • Posts: 6,400
Thank you for taking the time to prove what I have known for a while. Since getting my 75 I never carry my Oly 40-150. I immediately noticed that the 75 is so sharp that you can crop considerably and get results as good as thethe consumer zooms.
The Oly 40-150 is not a bad lens at all and one I recommend to people without hesitation, but the 75 is just so much better that it can hold up even after a fair amount of cropping. The 75 is a different beast all together, but if you already have one one it really negates the need for the consumer m43 tele zooms.
Jonathan
D Knisely Senior Member • Posts: 2,053
Agree. In a controlled situation (tripod), as a pure lens test, the 40-150 R is better than 75 with doubled resolution.  In practice, it all depends on the shooting conditions.  I personally never feel comfortable cropping severely or upres-ing significantly.  16 Mpixels is just not enough to permit that.  The results with the cropped 75 are better than I would have expected, but I am also incredibly impressed with the $99 40-150R!
 D Knisely's gear list:D Knisely's gear list
Olympus E-M5 II Nikon AF Micro-Nikkor 200mm f/4D ED-IF Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +3 more
At what speed? You definitely got shutter shock at your test.
I redid the tests there at around 1/1000th:
http://www.dpreview.com/forums/thread/3910484/56594317
(unknown member) Regular Member • Posts: 150
Nice test, thanks for doing this! A couple of months ago I wondered the very same thing...
http://www.dpreview.com/forums/thread/3893596
I find my 45-150 to be very hit and miss (more miss actually) but after reading into this thread, will have to pay more attention to being in the shutter shock range even though I do use the 0 second setting.  Add in the potential for shalllower DOF and higher shutter speeds and the 75mm is looking better and better.
Cheers!
Cimarron Regular Member • Posts: 345
I did the same type of comparison with my 75mm and the Oly 40-150 f/4-5.6.  The 40-150 was better at 150 than the cropped image from the 75, both set at f/5.6.
But the 75 was much better from f/1.8 to f/5.0.
 Cimarron's gear list:Cimarron's gear list
Sony a6600 Samyang 12mm F2.0 NCS CS Sigma 30mm F1.4 (E/EF-M mounts) Sony E 16-55mm F2.8 G Sony E 70-350mm F4.5-6.3 G OSS
Aucupium Regular Member • Posts: 280
Just thinking aloud whilst reading this topic - has anyone tried the MC-14 teleconverter on this lens? Its in the middle of the range for the 40-150mm pro, and would result in a useful 105mm equivalent with still a pretty low equivalent  f no. at wide open.
Andrew
 Aucupium's gear list:Aucupium's gear list
Panasonic Lumix DMC-FZ200 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
Andrew
I think I read somewhere it is not compatible. Which really sucks
It sure does!
Andrew
greg57 wrote:
Andrew
Skeeterbytes Forum Pro • Posts: 23,186
Because the MC14 front element juts into the lens, at present it only fits the 40-150 Pro and eventually, the 300 pro.
The EC14 and EC20 for four thirds don't have this physical limitation.
Rick
