Test: cropped Zuiko 75mm 1.8 better than a good consumer zoom (Lumix 45-150) from 75 to 150mm
Started Oct 7, 2015 | Discussions
greg57 Contributing Member • Posts: 730
7
I have just purchased the Olympus 75mm 1.8 and, although I got it brand new for a cheap enough price thanks to grey market imports, it's still £495 and my goal these days is to go for less lenses, of better quality and preferably not spend much money. Thus I might sell my 45mm 1.8, which is now a bit redundant between the 75mm and the long end of the 12-40. I will also probably sell my Panasonic 45-150. However I wanted to check in a kind of "scientific" way wether or not I'll be losing reach by doing so.
The idea basically is that if the 75mm is significantly sharper than the 45-150, I might be able to get similar magnification by cropping pictures and upscaling them.
Let's see how the comparison went (all pictures shot with an om-d e-m5 @ 400 iso).
Test scene @ 75mm (* compared side by side at 100% at the end of post if you're interested)
Side by side general view
Test scene with the Zuiko @ 75mm and the Lumix @ 150mm:
These are the pictures that will be used for the comparison
Now, in oder to be able to proceed to a fair comparison @ 150mm, I've produced 2 jpeg files from these 2 test shots in the following way:
With the 75mm: picture cropped at 50% and upscaled as a jpeg to the size of the original picture (Lightroom export with output gain set to "normal")
With the 45-150: Lightroom export with no resizing and gain set to "normal"
Side by side comparison @ 150mm equivalent:
At 50%
At 100%
It appears quite clearly that, for the same final perspective, a 50% crop of a picture taken with the 75mm contains more information (texture etc.) than a 100% crop of the same picture taken with the 45-150 at 150mm.
Conclusion: the 75mm is sometimes criticized as a lens lacking flexibility but these tests prove that it can readily replace a good quality consumer telezoom from 75 to 150mm at least (between 45 and 75mm, I will use crops from the 12-40 )
Conclusion (bis): I am putting my 45-150 on eBay tomorrow
Addendum: 100% comparisons at 75mm
Center at 100%
Upper left corner at 100%
Bottom right corner at 100%
Gregory Dziedzic
gregorydziedzic.com/photos
 greg57's gear list:greg57's gear list
Sony a7 III Panasonic GX850 Tamron 17-28mm F2.8 Di III RXD Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +2 more
Olympus M.Zuiko Digital ED 75mm F1.8 Olympus OM-D E-M5 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS
LMNCT Veteran Member • Posts: 4,908
Re: Test: cropped Zuiko 75mm 1.8 better than a good consumer zoom (Lumix 45-150) from 75 to 150mm
Are you talking about the inexpensive 45-150 4-5.6?  You are comparing a single focal length, fast aperture and somewhat expensive lens to a medium zoom which appears to be designed for light weight and low cost.  Of course the 75 will come out on top.  I am amazed that the 45-150 came out as well as it did.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 Panasonic G85 +23 more
Cani
Cani Regular Member • Posts: 386
7
He is comparing the single focal length @ 75mm with the zoom @ 150mm. Have you read the OP?
 Cani's gear list:Cani's gear list
Olympus PEN E-P5 Panasonic Lumix DMC-GH1 Olympus 12-40mm F2.8 Pro Panasonic Leica Summilux DG 25mm F1.4 Samyang 7.5mm F3.5 Fisheye +10 more
kenw
kenw Veteran Member • Posts: 7,095
I think you didn't read his post carefully. He shot the 75 upsized in resolution against the 45-150 shot at 150 and the 75 won. That is very surprising. A 2x digital teleconversion should not beat even a relatively crappy optical solution.
Ken W
See profile for equipment list
 kenw's gear list:kenw's gear list
Panasonic Lumix DMC-GM1 Nikon Z7 Panasonic Leica DG Summilux 15mm F1.7 ASPH Nikon Z 14-30mm F4 Nikon Z 24-200mm F4-6.3 VR +46 more
OP greg57 Contributing Member • Posts: 730
Sure this 45-150 is not bad at all
I was trying to see if there was any reason for me to keep it in my bag for long range (did you see the comparison at 150mm equivalent?). And it appears there isn't!
Robiro Veteran Member • Posts: 6,813
Are you sure OIS was off on Lumix?
Are you sure OIS was OFF on your Lumix lens?
I am having hard time believing it is THAT bad.
Kind of looks like OIS fighting IBIS.
But I could be wrong, of course.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Olympus 40-150mm F2.8 Pro Olympus 100-400mm F5.0-6.3 IS Panasonic 12-35mm F2.8 Sigma 30mm F1.4 for Micro Four Thirds
D Knisely Senior Member • Posts: 2,053
It is a valid perspective, but the advantage might not be quite as much as it appears.  It sounds like you did not optimize the sharpening or structure of each image.  SooC, a superb lens like the 75mm will definitely look better without any sharpening or enhanced micro-contrast, but with a little help, the zoom image might improve more than the upscaled 75mm image (which will be very fragile even though it looks pretty good; pushing it more might result in a worse image).  After all, none of the sample you show is a very good image; they are all fairly soft.
That drawback would be mitigated by using the wider aperture of the 75mm to get a lower noise image with less motion blur, so the 75mm might still come out ahead.
I can only say that I have gotten surprisingly sharp images from the Olympus 40-150 f/4-5.6 "R," although I have not tried this experiment.  My gut feeling is that with only 16 Mpixels, I never ever want to be doing any upscaling of m43 images.    I would just take a pass on the 300mm equivalent.
 D Knisely's gear list:D Knisely's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital 45mm F1.8 Nikon AF Micro-Nikkor 200mm f/4D ED-IF +3 more
Re: Are you sure OIS was off on Lumix?
According to this thread , OIS is deactivated automatically.
Shutter shock at 1/180s?
At 1/180s you are in a PRIME shutter shock territory. That could be the culprit.
75mm is absolutely immune to it because of its massive weight and the fact that it is a prime lens with no zooming elements, while Lumix rattles like hell.
Did you activate shutter shock protection in your camera?
Try the comparison at 1/500s or shorter shutter. You could be surprised.
Lumix can not be THAT bad. There is something wrong with your images, I feel it.
(But, I could be wrong.)
Frasier Krane Contributing Member • Posts: 510
Something wrong with the test or lens...
I don't see a huge difference here between the Oly and Panny when both are at 75mm. They're pretty close. This is an impressive performance for the 45-150.
Now all of a sudden, the lens, for some reason, completely falls apart at 150mm. Again, I think there's either something wrong with the lens or your test procedure.
Admittedly, I don't have this lens, but I do have the 45-175, and I can tell you that it would mop the floor at 175mm with your result here at 150mm. It's actually tack sharp at 175mm.
I do know that the 45-175 is sharper than the 45-150 at max FL, but I find it incredibly hard to believe it's THAT MUCH BETTER.
At 50%
At 100%
Center at 100%
Gregory Dziedzic
So, considering the improbability of your result, could you post the original images with EXIF included.
niekirk Regular Member • Posts: 221
greg57 wrote:
... if the 75mm is significantly sharper than the 45-150, I might be able to get similar magnification by cropping pictures and upscaling them.
Interesting idea and conclusion.  Zooming with that prime works better than zooming with that zoom!
Thank you.
How about trying the 45mm to see how that might compare in the 45-90mm range?
I suspect that you had the 75mm stopped down a bit, and the zoom perhaps wide open, but that's a fair real world comparison.
It makes me wish for a sharp, fast prime of about 150mm.
I take your point, but when you look at the the 100% side by side comparison, there is close to no texture showing on the bricks at all and no amount of sharpening could possibly change this:
vs
Cani
Re: Quality over reach
It reminds me that when I bought the Sigma 60mm f.2.8, I sold the 40-150mm II f/4-5.6.
I never had the opportunity to test the lenses against each other but had in mind the 60mm should be enough to cover my needs for an AF lense in the 45-100mm range.
I have never missed the 40-150mm f/4-5.6 since.
Re: Shutter shock at 1/180s?
Hmmm, I'll try again tomorrow with the 1/8s anti-shock.
Re: Something wrong with the test or lens...
There you go:
and
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Interesting! I might give my 75 1.8  a try against the Oly 40-150 5.6 and my newly acquired Panasonic 45-175
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Sony a7R III Olympus E-M5 III Panasonic Lumix DMC-GM5 Olympus M.Zuiko Digital 45mm F1.8 +15 more
Please do  I'd like to see if these findings can be confirmed or if my tests were botched. Trying tomorrow again with the anti-shock on my side!
Alien from Mars
Alien from Mars Contributing Member • Posts: 580
5
The image from 40-150 has much more vertical blur than horizontal. Take a look at the clock for example. So the shutter shock is a significant contributor to the lack of details in that exact case.
 Alien from Mars's gear list:Alien from Mars's gear list
Panasonic Lumix DMC-GX1 Olympus OM-D E-M5 Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +4 more
Astrotripper Veteran Member • Posts: 8,676
Redo at higher shutter speeds
That shot from 45-150 looks a lot like it suffers from shutter shock. Try to repeat your test at 1/500s and see if you get the same results.
Nevertheless, it's an interesting idea. I'll try this with my 45/1.8 and 40-150 R.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Alien from Mars
Unfortunately 1/8s antishock doesn't help that much. It does introduce the pause between shutter priming (that does induce a shockwave) and exposure start. But it cannot do anything about first curtain hard stop during the exposure (which is the most devastating event when we speak of shutter shock). EFC would really help (AKA 0s AS) but it's not available on E-M5. So I would try 1/8s AS plus much faster shutter speed (1/1000) and see if there is any improvement (75mm could improve too BTW).
