Canon 50mm STM
Started Oct 6, 2015 | User reviews
(unknown member) New Member • Posts: 11
Canon 50mm STM
Being a semi pro tog, I was a bit apprehensive over this lens at first but having read other reviews, I decided to put one through its paces. Now I know it'll never beat L quality but after using it continually over the past few days on my 1DS MkIII, I was pleasantly surprised as to how sharp it actually is - as good as but not better than my 24-105L as similar settings. At F/8 it is equally as sharp as the 24-105 and I wouldn't hesitate to recommend it to anyone and a plus is the metal mount not the cheap plastic one on the MkII this lens replaces.
F/8 @ 1/60th ISO 800 on a Canon 1Ds 3
Canon EF 50mm F1.8 STM
Prime lens • Canon EF • 0570C002
Announced: May 11, 2015
Canon shooter1958's score
4.5
Average community score
3.8
Canon EF 50mm F1.8 STM Canon EOS-1Ds
quiquae Senior Member • Posts: 2,265
Re: Canon 50mm STM
Maybe you have a very good copy of the 24-105. In my experience the 50STM kicks the crap out of the 24-105 at any aperture from F4 on down.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
stratobill Senior Member • Posts: 2,081
Re: Canon 50mm STM
As it should since it's a prime, though kicking crap may be a bit strong.
I do have a very sharp version of the 24-105, but yes the 50 is sharper.
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=989&Camera=453&Sample=0&FLI=0&API=3&LensComp=355&CameraComp=453&SampleComp=0&FLIComp=0&APIComp=0
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
J A C S
J A C S Forum Pro • Posts: 20,544
Re: Canon 50mm STM
Here is a better comparison, same FL.
OP (unknown member) New Member • Posts: 11
Re: Canon 50mm STM
I've never had a problem with my 24-105 with sharpness even at F4. The only problem I have is slight vignetting at F4 which is easily corrected in LR. I was once told that at F4, it's sweet, at F8, it'll cut you in half and I can see why, F8 is my particular sweet spot. Regards the 50mm, cracking lens but it had to go as I prefer zooms and just couldn't get on with it, next purchase is going to be 28-300L then 17-40L
